Does anyone know which jets on a 4500 #2972811
10/10/21 07:32 PM
10/10/21 07:32 PM
WI. U.S.A.
DusTed74 Offline OP
DusTed74  Offline OP
WI. U.S.A.
I am looking for information on a 4500 series carb. This is going on my 499 motor. Im running them with both with the power valve turned off.
So what I am looking for is what jets to run in this for the first time.
Thank you ................Ted
Re: Does anyone know which jets on a 4500 [Re: DusTed74] #2972819
10/10/21 07:44 PM
10/10/21 07:44 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Re: Does anyone know which jets on a 4500 [Re: Leigh] #2972836
10/10/21 08:22 PM
10/10/21 08:22 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Sorry, I would start at +8, and then jet for 1330 egt, or lamba stoically. Then, that being safe, would jet for max mph.
Re: Does anyone know which jets on a 4500 [Re: DusTed74] #2972842
10/10/21 08:45 PM
10/10/21 08:45 PM
Do you know if they are still stock or honked up before you got them work shruggy
I've used several different stock Holley 1050 CFM Dominators for bracket racing, the original List # 9375 worked really well for a single 4 barrel single plane intake on my bracket 440 motors with stock jetting ( either #91 or #92 (CRS blush) front and back up) and no power valves up
I'm planning on using them ( I have 3 or 4 of them now boogie grin) on my next big HP bracket B1 motor on a fabricated sheet metal tunnel ram intake also up
Re: Does anyone know which jets on a 4500 [Re: Cab_Burge] #2972928
10/11/21 09:11 AM
10/11/21 09:11 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I would also jet up to about a #96 square or #97 and start there...All my 1050's end up there or bigger, but I have not been using an old #9375 Dommy..
