E-body, change radiator from 22 to 26 #2972553
10/09/21 10:07 PM
10/09/21 10:07 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Wondering what individual pieces of sheet metal need to be changed
to go to the bigger radiator. I was looking for an exploded diagram but
can't find one.
One option, if I were to just cut and weld, I could go with even a bigger core.
I'm looking at the car and can't quite tell what is welded to what.
Re: E-body, change radiator from 22 to 26 [Re: hemienvy] #2972565
10/09/21 11:54 PM
10/09/21 11:54 PM
Colorado
spk2go Offline
spk2go  Offline
Colorado
You need a 70-74 E-BODY / 71-74 B-BODY 26-INCH RADIATOR CORE SUPPORT BRACKET CONVERSION. Sorry for the caps copied from an ebay add. Use one in my Challenger and work well.
Re: E-body, change radiator from 22 to 26 [Re: spk2go] #2972570
10/10/21 01:10 AM
10/10/21 01:10 AM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Hmm, so the drivers side is the same, the 26" radiator is only wider on the passenger side.
Re: E-body, change radiator from 22 to 26 [Re: hemienvy] #2972572
10/10/21 01:21 AM
10/10/21 01:21 AM
Colorado
spk2go Offline
spk2go  Offline
Colorado
You are correct only the passenger side needs to be changed
Re: E-body, change radiator from 22 to 26 [Re: spk2go] #2972596
10/10/21 08:03 AM
10/10/21 08:03 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
if you are not worried about total correctness. you can just cut the passenger side support and drill 2 holes for the radiator to mount to and the job is complete.
90% of the people looking at the car will never notice the difference once everything is assembled.
perception is 90% of reality
Re: E-body, change radiator from 22 to 26 [Re: Mr T2U] #2972608
10/10/21 09:16 AM
10/10/21 09:16 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
I think both sides are different, We opened up the passenger side only on our 70 Charger to find that the fan was not centered in the shroud.
I think if you look at the part Nos., the drivers side sheet metal also has a different part No.
Just our experience....Joe
Re: E-body, change radiator from 22 to 26 [Re: hemienvy] #2972718
10/10/21 03:03 PM
10/10/21 03:03 PM
I would look at replacing the radiator core support, but that is your choice work scope
Re: E-body, change radiator from 22 to 26 [Re: Cab_Burge] #2972724
10/10/21 03:25 PM
10/10/21 03:25 PM
Long Island, New York
57Fury440 Offline
57Fury440  Offline
If you do change the radiator support just be aware that it has the V.I.N. stamped into it.
Re: E-body, change radiator from 22 to 26 [Re: 57Fury440] #2972736
10/10/21 03:56 PM
10/10/21 03:56 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
The face plate of the core support is what can be changed... not the entire radiator support (unless you want to).
Re: E-body, change radiator from 22 to 26 [Re: Mopar Mitch] #2972738
10/10/21 03:58 PM
10/10/21 03:58 PM
Mopar Mitch Offline
Mopar Mitch  Offline
Another option is to contact US RADIATOR... I believe they have a conversion adapter bracket for mounting 26 into 22. They also have a video on doing this swap.
Re: E-body, change radiator from 22 to 26 [Re: Mopar Mitch] #2973530
10/12/21 02:57 PM
10/12/21 02:57 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
...........OR just recore your 22 in rad with a high efficiency core ( talk to GLEN RAY ) and dont change any sheet metal . I have had one for over 10 years on my 500ci sixpack engin with oem type cluch fan and it runs perfect even on 110+ deg days . Keep it simple !
Re: E-body, change radiator from 22 to 26 [Re: THESHAKERPROJECT] #2973613
10/12/21 05:19 PM
10/12/21 05:19 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
ShakerProject,
I like that idea, good to hear that it works.
Re: E-body, change radiator from 22 to 26 [Re: hemienvy] #2974613
10/15/21 11:36 AM
10/15/21 11:36 AM
London, England
Gavin Offline
Gavin  Offline
London, England
Yes I believe that both sides are different but mainly the PS. I fitted a 26" rad into my 22" core by drilling the extra holes and just spaced it back very slightly to not block off an air path to the extra width.
