Re: Hole size for Remote door mirror cables
[Re: patosmith]
#2972469
10/09/21 06:45 PM
10/09/21 06:45 PM
Posts: 18,157 Mass
DAYCLONA
Mass
I am adding bullet door mirrors on my 72 Challenger. The driver side mirror is remote so it needs the hole for the cables to run through. Right now I have a standard manual chrome mirror and the door does not have the hole for the cables to pass through. Does anyone know what size hole I need and do you have a pic of the door before the mirror is installed? Thanks in advance. Go with the hole size in the gasket?.....
[Re: patosmith]
#2972474
10/09/21 06:57 PM
10/09/21 06:57 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
Large eńough to get the joystick throught. Not necesarilly the gasket hole size, since as far I recall you can't remove the gasket from the mirror assembly
