3.23 vs 3.91 #297219
04/23/09 09:58 AM
04/23/09 09:58 AM
AZ
FM370RR Offline OP
mopar addict
FM370RR  Offline OP
mopar addict
AZ
how much will you pick up going to 3.91s in the rear in the qtr.also how much increase in the rpms at fwy speeds.28-29 tall tire.
Re: 3.23 vs 3.91 [Re: FM370RR] #297220
04/23/09 10:11 AM
04/23/09 10:11 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I ran a best of a 13.55 @ 89mph with 3.23's and 235-60 tires. I installed 4.10's and 29X10.5" slicks and ran a best of 12.71 @ 106mph.
I think that is a little better than average. I have heard that you will only gain up to a half second with a gear change.
Re: 3.23 vs 3.91 [Re: burdar] #297221
04/23/09 10:25 AM
04/23/09 10:25 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
What you'll win in time is mainly dependent on the car's current weight.
A heavy car will benefit more from a gearchange than a lighter car.
Re: 3.23 vs 3.91 [Re: FM370RR] #297222
04/23/09 11:06 AM
04/23/09 11:06 AM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Not worth it for me I went down for now. 3.91 to 3.55 but I have a shorter tire.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: 3.23 vs 3.91 [Re: HealthServices] #297223
04/23/09 11:25 AM
04/23/09 11:25 AM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Depends on your setup and what youre running
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: 3.23 vs 3.91 [Re: burdar] #297224
04/23/09 12:24 PM
04/23/09 12:24 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
something doesn't add up....what else did you change on the car? there's no way you picked up 17 MPH with just a gear change. your MPH should be pretty close to the same independent of gear ratio.
assuming 29" tall tire, and no converter slip RPM at 70 MPH will be 2620 for 3.23's and 3175 for 3.91's I'd assume 5-7% slip, which would raise the RPMS to 2750-2800 RPM's for the 3.23's and 3334-3400 RPM for the 3.91's.
2017 Grand Cherokee Overland
Re: 3.23 vs 3.91 [Re: FM370RR] #297225
04/23/09 12:27 PM
04/23/09 12:27 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
depends...w/ slicks and the correct stall a ton. I went from 14.11's in a 383 charger to 13.48
Re: 3.23 vs 3.91 [Re: Mr.Yuck] #297226
04/23/09 12:47 PM
04/23/09 12:47 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I don't know what to tell you. That's what it ran. It was a stripped down 82 Cordoba that still weighed over 3400 lbs. I had a 360/904 with a 3500 stall convertor in it. 235-60 BF Goodrich drag radials and 3.23's. The best I could do was a 13.55 at 89mph. During the winter I put in 4.10's and a spool and ran Hoosier 29X10.5 slicks. I might have also put a Holley electric fuel pump on it that winter too but that was it.
My first pass on the slicks I left easy and then hit it after 60 ft and it went 13.06 @ 102mph. The next pass it jumped out of gear at the end of the track. After I adjusted the shifter cable it went 12.91 @ 103mph.
At the track I usually ran at I got it to go the 12.71 @ 105.8mph early in the morning. It usually ran between 102 and 103 mph during the rest of the day.
Re: 3.23 vs 3.91 [Re: burdar] #297227
04/23/09 01:32 PM
04/23/09 01:32 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
the fuel pump could explain it. sounds like the old fuel pump wasn't keeping up and feeding the beast at high RPM, and the engine was laying down some on the big end of the track, keeping your ET & MPH down. playing with an online calculator,
http://www.dragsource.com/index.php?navselect=calculators&calctoview=4
assuming 3600 lb with driver, an 89mph trap and a 15.31 ET yield the same HP estimation. a 106 trap and a 12.83 yield the same HP estimation.
Re: 3.23 vs 3.91 [Re: Mr.Yuck] #297228
04/23/09 01:45 PM
04/23/09 01:45 PM
BRawls Offline
super gas
BRawls  Offline
super gas
Slicks will make a bigger difference than the gear change in my experince.
Re: 3.23 vs 3.91 [Re: BRawls] #297229
04/23/09 02:52 PM
04/23/09 02:52 PM
Lost in the ozone again
stubbs300 Offline
Vacation
stubbs300  Offline
Vacation
This is pretty cool! You can crunch the numbers yourself and see what happens. http://vexer.com/68rt/speed.html
Re: 3.23 vs 3.91 [Re: patrick] #297230
04/23/09 05:44 PM
04/23/09 05:44 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
This is it exactly - the fuel pump. A gear change might add 1 mph. Look at the old 60 ft, and compare it to the new 60 ft, multiply that difference by 1.5, and that is about the net benefit of just the gear/tire change.
