E.T. Prediction and Weather Station #2971317
10/06/21 12:58 PM
10/06/21 12:58 PM
Anoka County, MN
Leigh Offline OP
Leigh  Offline OP
Anoka County, MN
What is everyone using? No CompuTech. Thanks in advance.
Re: E.T. Prediction and Weather Station [Re: Leigh] #2971323
10/06/21 01:15 PM
10/06/21 01:15 PM
Performaire Eclipse , 20years+ up
Re: E.T. Prediction and Weather Station [Re: Leigh] #2971324
10/06/21 01:19 PM
10/06/21 01:19 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
We've been using an old TAG with O2 sensor. It's surprisingly accurate once it's built up a decent data base. If you a re constantly tweaking the combo like we do, it will skew the figures by giving more more of a "predicted deviation". We usually reset the data base if we have made a big change in the combo, we aren't proper bracket racers. We are usually chasing an ET's in a bracket class, as over here there aren't many heads up classes but it's the best way to run on a good track.
Re: E.T. Prediction and Weather Station [Re: Leigh] #2971325
10/06/21 01:23 PM
10/06/21 01:23 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Been using this, its free and works good. You can use it on any track, just select the track and it gives you current numbers. DA, temp, water grains, etc, etc
https://play.google.com/store/apps/details?id=com.dragtuner.dragracingweather&hl=en_US&gl=US
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: E.T. Prediction and Weather Station [Re: B3422W5] #2971338
10/06/21 02:00 PM
10/06/21 02:00 PM
Windsor ,Ca.
K
Keith Richards Offline
K
Windsor ,Ca.
Performaire Eclipse here as well, need to send it in though for update as the wind speed sensor they added years back has pooped out but other than that still running strong.
Re: E.T. Prediction and Weather Station [Re: Leigh] #2971361
10/06/21 02:50 PM
10/06/21 02:50 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I've never used that one, but you would be surprised at who does.
Ask the guys in the dot 90 classes. They live or die by the weather.
Working on the car to make it consistent, know how to predict the track, cloud cover, wind, etc, and how it affects your car is most of it. Predictions usually get fudged by those things.
Re: E.T. Prediction and Weather Station [Re: CMcAllister] #2971384
10/06/21 03:33 PM
10/06/21 03:33 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I use a Perfromaire Pro with a pager and also incorporate Crew Chief Pro. If I were a daily only bracket racer not sure all thats really necessary but multiple day events and especially for NHRA .90 stuff its almost a must have. Although I went to a few finals in .90 with a hand held Tag.
Re: E.T. Prediction and Weather Station [Re: Leigh] #2971808
10/07/21 06:34 PM
10/07/21 06:34 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Used an old TAG for years. It’s predicting was very accurate.
Re: E.T. Prediction and Weather Station [Re: Leigh] #2971873
10/07/21 09:09 PM
10/07/21 09:09 PM
Dunnellon, FL
longram60 Offline
longram60  Offline
Dunnellon, FL
I too get my weather online:
https://airdensityonline.com/tracks/?filter=222
I have an PreformAir handheld, but rarely use it.
For ET prediction, I use Family Software ET Predictor:
https://www.ifamilysoftware.com/etpPRO.html
1979 AMC Spirit, NHRA Q/SA
Re: E.T. Prediction and Weather Station [Re: longram60] #2971916
10/08/21 12:35 AM
10/08/21 12:35 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
How about an old B&G racing computer, some decent instruments and a log book.
Figure out ET/Air Density change ratio, throttle stop ratio, vapor pressure fudge factor, track, wind, clouds, watch everyone in front of you to see what they're doing, figure out how you want to race the guy in the other lane, and throw a number in it.
Worked pretty well.
Re: E.T. Prediction and Weather Station [Re: Dabee] #2972081
10/08/21 02:44 PM
10/08/21 02:44 PM
Anoka County, MN
Leigh Offline OP
Leigh  Offline OP
Anoka County, MN
Thanks for everyone’s opinions. I’m pretty certain, I’m going to use Family Software. I’ll need to talk to Bob, to decide what air sampler to get. I currently have a CompuTech race air sampler and Sharp hand held computer. The sampler has a failed humidity sensor, and they can only sell me a replacement, for $475. The sampler has failed twice. I realize it’s old, 2004, but it’s low use and always in the case, in my home when not being used. I can’t trust it anymore. Thanks again.
Re: E.T. Prediction and Weather Station [Re: Leigh] #2972262
10/08/21 11:56 PM
10/08/21 11:56 PM
MO.
CROWBAR Offline
CROWBAR  Offline
MO.
Just curious about your CompuTech Not happy with it ?
Re: E.T. Prediction and Weather Station [Re: CROWBAR] #2972298
10/09/21 07:35 AM
10/09/21 07:35 AM
Anoka County, MN
Leigh Offline OP
Leigh  Offline OP
Anoka County, MN
The air sampler has failed twice, and I’m not giving them $475 again. Granted, the first time they fixed it under warranty, but it’s failed twice out of the blue, without warning and when I needed it the most. I’m sure it’s anecdotal, and that’s fine, but I don’t trust the architecture.
Re: E.T. Prediction and Weather Station [Re: longram60] #2972343
10/09/21 10:36 AM
10/09/21 10:36 AM
MO.
CROWBAR Offline
CROWBAR  Offline
MO.
How “Dead on” is Family Software ET Predictor? Thoughts on people using it Thanks Randy
Re: E.T. Prediction and Weather Station [Re: Leigh] #2972405
10/09/21 02:03 PM
10/09/21 02:03 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Respectfully, don't expect accuracy in any ET predictor until your combo is more in line with what you have, what you paid for/built. This is what you gave in another post: 'Thanks everyone. Ted, tires are junk. Under 25 passes, but almost 6 years old. It’s a 388” B1BA, R1 tall deck roller motor. It’s always been an underachiever by .25 or so. 620hp and 535 pounds feet, on a stingier dyno. Should have gone closer to 10 teens at 130 @3150 with driver.'
something is off that it could pick-up in 'bad' weather...I hope you get what I mean without typing every possible scenario. Between this community and the names you listed helping you, you can dial it in better which I have no doubt will allow the prediction software to help you go rounds. Respectfully.
Re: E.T. Prediction and Weather Station [Re: HardcoreB] #2972407
10/09/21 02:06 PM
10/09/21 02:06 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
I knew there was something else I forgot... unless these tires were exposed to sunlight or poor storage. I doubt they are bad at all. I know of MANY successful racers who report way longer idle periods and use and have no trouble with their slicks. Share your combo and info and we'll dial you in in no time!!!
Re: E.T. Prediction and Weather Station [Re: CROWBAR] #2972411
10/09/21 02:10 PM
10/09/21 02:10 PM
Dunnellon, FL
longram60 Offline
longram60  Offline
Dunnellon, FL
I've been happy with it, and it's gotten me a Win & RU in some NMCA Stock/Superstock combo races. Usually if it doesn't run the number it can be attributed to other factors (ie, driver error, quick changing weather, etc).
It's not too user friendly for index racing. I used it many years in NSS running an index. Here I had to determine the horsepower corrected weight to run dead on my index, then adjusted weight to match the HP corrected weight with the new conditions.
Re: E.T. Prediction and Weather Station [Re: CROWBAR] #2972418
10/09/21 02:25 PM
10/09/21 02:25 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
How "dead on" is anyone's ET prediction software? Really?
Is anyone using it without fudging the numbers for any of the hundreds of variables besides the weather every run?
I tried in a .90 application where the car needs to be adjusted to an index every run. LIke herding cats. Especially if you travel. Tracks are all different. Gave up on it.
Focused on getting a good handle on what a weather change did to the car. Humidity, grains of water, vapor pressure or whatever you are using to measure water in the air, is the hardest thing to deal with, especially with a small cubic inch, relatively low compression deal like I was using. Especially as it increased above ~ 60-70% and the performance loss really started to spike..
.01 ET change/100' DA change is what we want to know.. Use the first hit of the weekend, not the last 50 runs, as a baseline to see where the track is and work from there. Multiple day events are where knowing your car well pays off.
A data base with a bunch of runs from different tracks, different lanes, different areas, etc is junk to me. I adjust from the last run, unless it was a flyer and/or was way off without a good reason. Happens.
Throw in a throttle stop to deal with and it really gets to be fun.
Re: E.T. Prediction and Weather Station [Re: HardcoreB] #2972421
10/09/21 02:40 PM
10/09/21 02:40 PM
Anoka County, MN
Leigh Offline OP
Leigh  Offline OP
Anoka County, MN
Also respectfully, you are combining posts that don’t relate. I didn’t say the CompuTech Race Air is inaccurate, just unreliable. Meaning, inoperable.
Also, my car is very predictable. It doesn’t pick up in bad air, exactly opposite. I only indicated that I feel it is always been .25 slow, regardless of weather.
Again, respectfully, after a couple dozen sets of PH362 Phoenix (Firestone Drag 500, in the “old days”), once they get used, and then sit for more than 6 months, they loose that nice soft, suppleness. I can tell, as there isn’t any debris stuck to the tread face. When they are fresh, they actually make a heck of a mess, there is so much debris that sticks driving back after a pass. Anyway, that’s my take. Thanks!
Re: E.T. Prediction and Weather Station [Re: Leigh] #2972541
10/09/21 09:29 PM
10/09/21 09:29 PM
[quote=HardcoreB]
I found just the opposite with a set of 16x33x15 Goodyears that had been on my current S/P car for over 6 years in Tuscon, AZ stored inside, they had been well used but had a little over 1/2 the wear indicators left even with one set of the cords on the side walls being broken.
I put a 650+ HP E 85 bracket motor in the car and did one long burn out and they work very well shock shocked the hell out of me shruggy
I have had similar experiences with the old Firestone drag tires when I ran NHRA stockers back before 1989, 50 runs max and replace and sell them at a swap meet for 1/2 price whistling realcrazy
I had friend who would put 15 to 30 runs on them and then put new ones on due them starting to slow down a little bit each run after they quit hooking well whiney
