carb and intake
#297148
04/23/09 03:57 AM
04/23/09 03:57 AM
Posts: 63 minnesota, USA
greenfire
minnesota, USA
i have a 74 satellite serbring with a 318 # matching engine, duel exhaust, auto tranny. i picked up a early to mid 70s period correct edelbrock duel plane none egr aluminum intake, before the performer series. ld series i think. will bolt right up, good match as far as fit goes. also i have a edelbrock 600 cmf 4 bbl carb #1405 square bore none egr as well. what kind of results should i expect? and is this a reasonably balanced combination of parts? thanks and input welcomed, ohh ya what type of adapter will i need between the carb and manifold?
proud new owner of a 1974 plymouth satellite sebring plus in decent shape, let the fun begin
Re: carb and intake
[Re: greenfire]
#297149
04/23/09 08:14 AM
04/23/09 08:14 AM
RapidRobert
If it has the same port size as your 318 as opposed to larger 340/360 ports, it'll be an excellent combo for you. I'm assuming it's a spreadbore intake if so just use the flat adapter that looks like a thin metal base gasket: a gasket, then the metal plate, then another gasket, then the carb.
Re: carb and intake
[Re: RapidRobert]
#297153
04/23/09 03:29 PM
04/23/09 03:29 PM
greenfire
minnesota, USA
what are the adapter's with the 4 hole's used for? just curious?
Re: carb and intake
[Re: greenfire]
#297154
04/23/09 08:57 PM
04/23/09 08:57 PM
Posts: 565 IA
landon1
IA
4 hole spacers are supposed to increase the velocity i believe - that's what i have on mine - never tried anything different
'71 Satellite Sebring 440
Re: carb and intake
[Re: landon1]
#297155
04/23/09 11:37 PM
04/23/09 11:37 PM
greenfire
minnesota, USA
i heard some where that the adapter's with the 4 round holes were good for low end-response and the open square adapter's were more for top end? anny help?
