Unlocking Steering Column
#297125
04/23/09 12:43 AM
04/23/09 12:43 AM
Posts: 1,647 IL
71383beep
IL
A friend of mine just bought a 72 charger rallye. He is thinking about restoring it. Unfortunately it came with no keys. The steering wheel is locked straight.
Is there a way to open the column and remove the lock without the keys?
'73 GK6 Challenger Rallye - 340 4-Speed
Re: Unlocking Steering Column
[Re: KMPX2]
#297128
04/23/09 08:41 AM
04/23/09 08:41 AM
Posts: 1,647 IL
71383beep
IL
Ok then.
I'll bring the keys for my bee and the shop manual with my wheel puller.
Is it possible to put the column back together with out the lock? That way we can turn the wheels to work on her.
[Re: 71383beep]
#297129
04/23/09 09:14 AM
04/23/09 09:14 AM
Posts: 11,543 chicagoland,usa
buildanother
chicagoland,usa
If you have to turn the wheel RIGHT NOW, you could try a little trick we used when doing police towing etc, you push down and towards direction you want to turn it, at the same time with your left hand at about the 7 oclock position of wheel. Then with your right fist, pound away from you on the top of steering wheel repeatedly and it should bump around for you. Did this all the time, and fords were the most cooperative. I know it's hack, but it may work.
[Re: buildanother]
#297130
04/23/09 10:10 AM
04/23/09 10:10 AM
Posts: 1,647 IL
71383beep
IL
No we don't have to turn it right now. I'll loan him a set of my dollys actually...or he may buy some this weekend at Jefferson. It's not a huge deal really i guess. He's going to get started pulling all of the soft parts out of it this weekend so he'll be moving it back and forth into the garage.
