Re: Leak Down Test Problem on #2 Cylinder
[Re: n20mstr]
#2970977
10/05/21 02:57 PM
10/05/21 02:57 PM
Posts: 4,684 Wichita
GY3
Wichita
Yikes! And here I figured the cast crank would be the first to go!
How much boost were you throwing at it?
[Re: n20mstr]
#2970986
10/05/21 03:11 PM
10/05/21 03:11 PM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
Ring Gap looks to be a little too big. Thats why your leakdown was excessive Only to be made worse by the too large gas porting.
[Re: Cab_Burge]
#2971080
10/05/21 06:17 PM
10/05/21 06:17 PM
Posts: 3,085 Michigan
A727Tflite
Not sure where that piston came from originally, doesn’t look at all like this Chinese piston.
😂. Ah So.
[Re: Blusmbl]
#2971129
10/05/21 08:50 PM
10/05/21 08:50 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Wholly meltdown Batman!! Sorry to see that.
[Re: dvw]
#2971250
10/06/21 09:01 AM
10/06/21 09:01 AM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
It actually shocks me how little it was smoking for how big that hole was!!!!
What you're looking at is a custom made Diamond Piston specific for my turbo application. 2818 material, Thick crown, ring is down a bunch, etc... Certainly no fault of the piston.
It had hurt the converter at Monster Mopar earlier this year, and wouldn't 60ft at all. So I was leaning on the tune pretty hard to get it to run 10.0 for the shootout (about 20-21psi of boost). Went 9.98@139.7mph on the last pass.
It's a little bit strange because the A/F wasn't excessively lean on the data logger, nor do any of the other cylinders look like they had anything wrong with them. #1 and #2 cylinders always run the hottest on this car, so as I was adding boost/timing, I was watching #1 carefully. Whoops... should have been watching #2 apparently!
We will see if the block is going to clean up. Hopefully I can just slap another set of pistons in it and go... but we'll see.
It is absolutely amazing to me that the piston can take that kind of abuse, and the stock block/cast crank still survives!!!!
[Re: GomangoCuda]
#2971386
10/06/21 03:39 PM
10/06/21 03:39 PM
dizuster
Oakland, MI
Sharp edge on the valve notch likely caused that. I 100% agree. No doubt the radial edge of the valve pocket makes this the thinnest area. I hand "massaged" these the best I could to minimize any sharp edge, but at the end of the day every part has a weak point somewhere. Running standard off the shelf Cometics.
