340 bore size #2970172
10/04/21 03:14 AM
10/04/21 03:14 AM
New Zealand
dart6 Offline OP
dart6  Offline OP
New Zealand
Is a 340 with a 4.100 bore size at it's max?
Re: 340 bore size [Re: dart6] #2970174
10/04/21 03:43 AM
10/04/21 03:43 AM
California
BigDaddy440 Offline
BigDaddy440  Offline
California
I would think so. That's .060" over, which typically for any production block is pushing it.
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: 340 bore size [Re: dart6] #2970175
10/04/21 03:54 AM
10/04/21 03:54 AM
Kirkland, Washington
Pacnorthcuda Offline
Yes…and it should have been sonic checked prior to the last build.
Re: 340 bore size [Re: Pacnorthcuda] #2970177
10/04/21 04:34 AM
10/04/21 04:34 AM
New Zealand
dart6 Offline OP
dart6  Offline OP
New Zealand
Ok cheers guys i'll steer clear
Re: 340 bore size [Re: dart6] #2970205
10/04/21 08:26 AM
10/04/21 08:26 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Stock is 4.040. They only recommend a .040 overbore as max. 4.10 would be way over that. I’ve had a .060 over block develop a pinhole. They are pretty thin.
Re: 340 bore size [Re: fastmark] #2970224
10/04/21 08:53 AM
10/04/21 08:53 AM
an8sec70cuda Offline
iagree I have one that is .030" over currently and it will need at least 4 sleeves to go any bigger.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 340 bore size [Re: BigDaddy440] #2970244
10/04/21 09:35 AM
10/04/21 09:35 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree But just to clarify the above, there are other Mfr's blocks that will go .125. But even then, sonic testing is recommended beer
Re: 340 bore size [Re: TJP] #2970293
10/04/21 11:30 AM
10/04/21 11:30 AM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
Also... there is nothing wrong with a sleeved block... in fact, some racers prefer sleeved blocks as the walls become thicker.
Re: 340 bore size [Re: Mopar Mitch] #2970300
10/04/21 11:41 AM
10/04/21 11:41 AM
Except for the cost of creating one!
Re: 340 bore size [Re: Pacnorthcuda] #2970318
10/04/21 12:14 PM
10/04/21 12:14 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have a 340 laying around. I was thinking about making a winter project out of it. Good thing is if it needs any sleeves I can just stay after at work and machine and install them.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: 340 bore size [Re: Pacnorthcuda] #2970441
10/04/21 03:36 PM
10/04/21 03:36 PM
iagree Exactly. If I was still in the machine shop business, I'd have already fixed it, lol.
CHIP
Re: 340 bore size [Re: an8sec70cuda] #2970616
10/04/21 11:11 PM
10/04/21 11:11 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
i did a 340 for a friend at 4.100 and it powers his 74 cuda to 12.5 et s ???
been together for 5+ years now , street engine , pump gas , drive anywhere .
no sleeves !
Re: 340 bore size [Re: calrobb2000] #2970755
10/05/21 08:26 AM
10/05/21 08:26 AM
Originally Posted by calrobb2000
hi
no sleeves !
Did you sonic check it? I'm sure there's a bunch running around at .060" over and are just fine. So many variables to consider.
As much as the 440 blocks vary in thickness, I'm sure the small blocks were no different.
CHIP
Re: 340 bore size [Re: an8sec70cuda] #2970929
10/05/21 01:22 PM
10/05/21 01:22 PM
hi
no sleeves !
iagree
I bought a sonic tester for that reason after cracking a cylinder in my first 400 stroker build, the driver side had massive core shift and the cam side of those cylinders were all less than .060 thick whiney puke
It was so thin sleeves wouldn't seal at the bottom whiney
I sonic test every block now before sending them to the machine shops for work up You should too twocents
Re: 340 bore size [Re: Cab_Burge] #2970962
10/05/21 02:33 PM
10/05/21 02:33 PM
Mopar Mitch Offline
Mopar Mitch  Offline
The sonic testers do have good merit... especially when they show extra thin walls... something then to consider.
