1970 Dart clutch pedal hardware question #2970105
10/03/21 09:34 PM
10/03/21 09:34 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
Would anyone happen to have a photo of the clip that retains the clutch pedal to the pedal box assembly? Is it just an ordinary "e-clip" or is it something different? This would be that clip that slips into the groove in the shaft at the top of the clutch pedal. TIA!
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
Re: 1970 Dart clutch pedal hardware question [Re: MadMatt] #2970164
10/04/21 01:39 AM
10/04/21 01:39 AM
New York
DartS Offline
DartS  Offline
New York
Re: 1970 Dart clutch pedal hardware question [Re: DartS] #2970462
10/04/21 04:24 PM
10/04/21 04:24 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
I was able to look at a car locally and it looks like this clip is what the factory used.
https://www.classicindustries.com/p...9eOwE_1xPXv4DvdUVe6hhLKiEqxoCDh0QAvD_BwE
Re: 1970 Dart clutch pedal hardware question [Re: MadMatt] #2970521
10/04/21 06:37 PM
10/04/21 06:37 PM
New York
DartS Offline
DartS  Offline
New York
Call Brewers Performance he will tell you what you need.
PH: (937) 947-4416 or (937) 698-4259
Re: 1970 Dart clutch pedal hardware question [Re: MadMatt] #2970583
10/04/21 09:42 PM
10/04/21 09:42 PM
IMGTX Offline
IMGTX  Offline
That clip is used to clip the clutch adjustment rod to the bellcrank/Torque Shaft, and each end of the rod from the Bellcrank/torque shaft to the the pedal.
I believe your first post described the shaft holding the pedal to the dash structure and that would be the e-clip DartS showed you.
He was correct for the description and correct to call Brewers. Brewers knows his stuff.
If you go to http://www.brewersperformance.com and use the search option to search for Clip. Look about #8 and #10 to see the parts in question.
Hope that is some help.
