For those considering spraying N2O #2969879
10/03/21 07:50 AM
10/03/21 07:50 AM
Md.
carnut68 Offline OP
carnut68  Offline OP
Md.
Since this has come up in a few threads. What kit /kits would be good for someone who has never used it? Say starting at 100, 150 or 200 shot.
America First!
Re: For those considering spraying N2O [Re: carnut68] #2969884
10/03/21 08:22 AM
10/03/21 08:22 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
A 100-125HP shot is a good place to start. I prefer the anodized plates vs. powdercoated (holley) and if you can get one that does not have the discharger tubes mounted in epoxy even better. Check Induction Solutions, ZEX, and NX Express.
What are you spraying?
Re: For those considering spraying N2O [Re: carnut68] #2969899
10/03/21 09:19 AM
10/03/21 09:19 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Induction solutions has nice plates . Saturday night special , Holey moly
Also NX billet cross plate is nice .
One thing to remember , it’s always better to have better than you need . In other words buy a plate and solenoids that can go higher than you initially need because most times they can be jetted smaller .
Also always consider a ball valve and nitrous gauge in the car . This gives you ability to turn on nitrous just before a run , and turn it off at the end of a run . This minimizes the pressure on your nitrous solenoid plunger and greatly extends its life . Also safe and make sure you not leaking nitrous into an engine that’s not running .
Induction solutions probably has the best customer service out there .
....BAD A$$ STREET CAR.....
Re: For those considering spraying N2O [Re: n20mstr] #2969904
10/03/21 09:51 AM
10/03/21 09:51 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Once you start your just can't stop. Just don't get too geedy and you will be fine.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: For those considering spraying N2O [Re: 6PKRTSE] #2969908
10/03/21 10:16 AM
10/03/21 10:16 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Good point on the bottle shut off. I have one in the GTS. You might consider the NOS mini progressive if you do not have an ignition with window switch capability. That will also allow you to digitally monitor bottle pressure.
You will want to add a WOT switch to the carb/throttle body also. If you are really serious about consistancy a heater system controlled by a pressure transducer is the hot setup.
Re: For those considering spraying N2O [Re: Jeremiah] #2969916
10/03/21 10:32 AM
10/03/21 10:32 AM
Md.
carnut68 Offline OP
carnut68  Offline OP
Md.
If I was to spray it's a 446, Ross pistons, EZ heads 13to 1. The shut off is a great idea. Induction Solutions kit looks like you get everything needed. I'm just an ET chaser looking to up the game a bit.
America First!
Re: For those considering spraying N2O [Re: carnut68] #2969956
10/03/21 12:05 PM
10/03/21 12:05 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
I’m using a 20+ year old NOS Cheater. Served me well. I’m sure there are better options now days.
Re: For those considering spraying N2O [Re: gsmopar] #2970075
10/03/21 07:41 PM
10/03/21 07:41 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I bought the Nitrous Express Mainline kit. It's pretty inexpensive and the plate is a one piece billet. It is capable of up to 250 hp. The limitation being the size of the nitrous solenoid.
It was a great kit for a beginner.
That said, the Induction Solutions stuff is what I plan on upgrading to. Probably the Holey Moley kit.
One item you might want to consider is a small board with relays and fuses built in. I bought the Leash Electronics single stage board. It makes wiring and hook up simple and clean.
I started off with a small 100 shot, then graduated to 150, 200 and now 250. The 505 takes the 250 shot like it's nothing.
I built a small board that has a DeWalt dock on it for cordless batteries that power the bottle heater. A pressure switch shuts it off when it gets to 950 psi.
'63 Dodge 330
11.19 @ 121 mph
Re: For those considering spraying N2O [Re: GY3] #2970093
10/03/21 08:41 PM
10/03/21 08:41 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
So I understand you need some special "window" switches to operate nitrous on a stick car. Has anyone here used the bottle on a stick car? I have thought about it for high gear only when you didn't hit a shift just right so I don't think you would need any special switches with that.
Gus beer
64 Plymouth Savoy
Dana 60
Re: For those considering spraying N2O [Re: fourgearsavoy] #2970106
10/03/21 09:34 PM
10/03/21 09:34 PM
California
BigDaddy440 Offline
BigDaddy440  Offline
California
I've ran two entry level nitrous systems way back when. Both were low hp, but impressive performers.
I ran a typical wet kit on a Tune Port 350 EFI Formula Firebird, auto trans. I ran the 100HP jetting as the car was 100% bone stock. The car went from running 14.70s to 13.50s and picked up 7 or 8 mph.
I also ran a kit on a 5.0 Mustang with a 5 speed trans. I used a special programmable device that allowed you to prevent the kit from activation in first gear via RPM control. Basically the system wouldn't function until after I had shifted to 2nd gear as it armed itself once I had reached my shift RPM once. After that RPM had been reached (say 6,000) the system would function from there on out at WOT. I think you could set a delay after that first RPM point before activation as well. It worked, but I didn't keep the car for that long once installed. The technology is so much better now, so I would assume much better devices are available.
-Dan
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: For those considering spraying N2O [Re: n20mstr] #2970210
10/04/21 08:34 AM
10/04/21 08:34 AM
an8sec70cuda Offline
I agree w/ what everyone else has said. Don't buy a little small system for a couple reasons. If you decide to get rid of it later, the small systems are harder to sell. The bigger kits can usually be jetted down small. My kit from Induction solutions has jetting from 150 all the way to 500 hp.
The billet plate kits are the way to go...like the IS holy moly. I should have gotten that b/c they're more durable than the plates w/ epoxied in spray bars. I have the NOS Crosshair plate, flowed by Induction solutions.
Leash electronics has some great wiring boards. Induction Solutions has a lot of good stuff too. Steve at IS is AWESOME at helping his customers. up
CHIP
'06 GMC 2500HD LBZ Duramax
Re: For those considering spraying N2O [Re: an8sec70cuda] #2970238
10/04/21 09:15 AM
10/04/21 09:15 AM
UK
rb446 Offline
rb446  Offline
UK
I ran an old cheater kit on my 340 Cuda, jetting in those days was way rich on the P jet, 7>8 sizes larger than the N jet which is the complete opposite today, still managed to go 8 10ths faster with the 150 tune and 1.4 secs faster with the 250 shot. Similar with my 440 Cuda, that had a Big Shot kit, went from 10.7 NA to 9.96 with a 175 shot. Both systems had a separate blue pump for just the fuel, not needed really but I wanted to play with fuel pressure like down to 4psi and made sure I had a good supply. Things have come a long way since those days.
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: For those considering spraying N2O [Re: fourgearsavoy] #2971580
10/06/21 11:25 PM
10/06/21 11:25 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Gus beer
Bottle? Check!
Face plated a833? Check!
Gus I use a NOS bramd mini profressive. It has a built in window switch among otber features.
Re: For those considering spraying N2O [Re: n20mstr] #2971630
10/07/21 09:16 AM
10/07/21 09:16 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I run 2 quarter turn valves and gauges inside of my car for both kits.
