Re: 727 accumulator piston
[Re: lancer493]
#2969478
10/01/21 11:22 PM
10/01/21 11:22 PM
Posts: 9,861 MI, usa
dvw
MI, usa
My car runs 9.O-9.1 @ 3350lbs. The stock parts are; servos, accumulator, input and output shafts, pump gears sealing rings. 3 pin planet carriers. It has 750+ passes with these components unchanged. Current clutch frictions and bands have over 400 passes. What has failed in 750 passes? 2 stock front planet carriers. One I caught on inspection. One stranded me. Cured with a steel planet carrier. The aftermarket aluminum rear clutch carrier had the clutch hub splines pull thru it. Easily remedied by adding a snap ring to protect the aluminum from wear. This failure stranded me. Wore out 2 reaction shaft support ring grooves and sealing rings. Cured by lapping the ring grooves in the support. This was caught during inspection. So in 9 years it's stranded me twice. Doug
[Re: lancer493]
#2969644
10/02/21 02:32 PM
10/02/21 02:32 PM
Posts: 25,899 Rio Linda, CA
John_Kunkel
Rio Linda, CA
IMO, the only time the accumulator piston needs upgrading is if it's plastic.
