Trans. pan gasket #2968357
09/29/21 09:16 AM
09/29/21 09:16 AM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
I need to put a new trans. pan gasket on a 727 and was wondering what gasket is recommended these days. It's been probably 20 years since I last changed a trans. gasket and at that time I tried one of the Mopar rigid, reusable gaskets and it leaked quite a bit so I think I'd rather try a conventional cork or rubber type gasket. Recommendations?
Re: Trans. pan gasket [Re: 6PAX] #2968369
09/29/21 09:41 AM
09/29/21 09:41 AM
A727Tflite Offline
A727Tflite  Offline
The only reason that gasket leaks is because the pan is not flat. Or a crack in the flange of the case.
Lay the pan on a very flat surface. You will probably see some or all of the bolt holes bell mouthed. Flatten them out.
You should not be able to get a feeler gauge of more than .013” (if memory is correct) between the flange and surface.
Don’t use any sealers, just clean the trans and pan with thinner and bolt it together.
You can’t over torque this gasket, you will just strip threads.
Re: Trans. pan gasket [Re: 6PAX] #2968378
09/29/21 10:24 AM
09/29/21 10:24 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
These new style oil pan and tranny pan gaskets are heavily embossed with sealing ribs. This seems to seal well against the machined surfaces of the block and tranny cases. But do not do a good job sealing against the stamped steel pans that have their own stiffening ribs. I use those gaskets with Hylomar on the pan side of the gaskets with good success. Non hardening Permatex would probably also do a good job there. twocents
Master, again and still
Re: Trans. pan gasket [Re: DaveRS23] #2968505
09/29/21 03:52 PM
09/29/21 03:52 PM
A727Tflite Offline
A727Tflite  Offline
Can’t speak about all stamped pans but the ones from Chrysler conform to the PIP seals and their contour.
I’m thinking if you check a 62 727 pan against a 2007 48RE the beads are probably identical.
Re: Trans. pan gasket [Re: A727Tflite] #2968516
09/29/21 04:18 PM
09/29/21 04:18 PM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
I ran the silicone/metal gasket on the pan of my 64 300's 727, no leaks, but I did end up heli-coiling all the pan bolt holes because most of them were stripped due to incompetent "mechanics" and I just did them all while I was there.
Re: Trans. pan gasket [Re: DaveRS23] #2968594
09/29/21 07:49 PM
09/29/21 07:49 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
I neglected to mention I will be replacing the factory pan with a deep cast aluminum pan. The last time I used the Mopar hard gasket that I mentioned in my original post that leaked was on my 71 Road Runner that had the factory steel pan on it. So maybe this time I will have better luck. Still tempted to use some sort of sealant though as I hate having leaky oil and trans. pans.
Re: Trans. pan gasket [Re: 6PAX] #2968595
09/29/21 07:54 PM
09/29/21 07:54 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Re: Trans. pan gasket [Re: 6PAX] #2968618
09/29/21 09:17 PM
09/29/21 09:17 PM
A727Tflite Offline
A727Tflite  Offline
Clean both surfaces and put it on dry.
You will be happy with the results.
Re: Trans. pan gasket [Re: A727Tflite] #2968660
09/30/21 01:35 AM
09/30/21 01:35 AM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
The new gaskets Mppar hard gaskets with the O Rings on a Summit or B&M aluminum pan with no sealer of any kind works.
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Trans. pan gasket [Re: A727Tflite] #2968715
09/30/21 10:38 AM
09/30/21 10:38 AM
A727Tflite Offline
A727Tflite  Offline
Forgot to mention, this gasket used longer bolts in production due to it being thicker.
Be careful using the standard bolts.
Re: Trans. pan gasket [Re: A727Tflite] #2968729
09/30/21 11:21 AM
09/30/21 11:21 AM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
Like Transman pointed out, the newer gasket needs a different bolt. Its like 2 threads longer. Not much but enough to strip out holes in the case if they are not used. The dealer can hook you up with those. Same goes on the 904 and its derivatives.
Carl Kessel
Re: Trans. pan gasket [Re: CKessel] #2968733
09/30/21 11:30 AM
09/30/21 11:30 AM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
Other than the Mopar hard gasket, are there any others that anyone would recommend?
Re: Trans. pan gasket [Re: 6PAX] #2968747
09/30/21 12:32 PM
09/30/21 12:32 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Given that you have two machined surfaces, it doesn't get much better than the style gasket being discussed here. At least, in my opinion.
Re: Trans. pan gasket [Re: 6PAX] #2968758
09/30/21 12:50 PM
09/30/21 12:50 PM
IMGTX Offline
IMGTX  Offline
I am old school. I use cork or if I have to use it I use rubber with great results.
1. Make sure pan flange is flat. Often mechanics think tighten it more and it'll fix it and the dimple the pan at the bolt holes causing more leaks.
2. Add a little trans fliud to the pan and use it to coat the gasket. This will cause the gasket to swell a little and prevent it from sticking to the metal making removal less of a mess.
3. Install the pan snugging the bolts a little bit. I use a 1/4" ratchet to prevent going overboard. Repeat the bolt snugging process around the pan repeatedly until the gasket starts to squeeze out or the bolts stop getting snug. Every pass the pan around will cause the first bolts to be loose by the time you get to the last ones. You are done when they stop getting snug.
I pretty much never have pan leaks. Can't get that darn seal on top of the shift lever to not leak when the torque convertor drains back into the trans case but the pan doesn't leak.
I will say that I do like the newer style trans gaskets that are rigid and reusable but since a cork gasket comes with the filter I use them and save my money. Only a couple bucks but I am cheap.
Re: Trans. pan gasket [Re: 6PAX] #2968764
09/30/21 01:09 PM
09/30/21 01:09 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
A&A transmission sells a cork gasket on a steel frame. I have had great luck with them.
68 Barracuda Formula S 340
Re: Trans. pan gasket [Re: Bad340fish] #2968789
09/30/21 02:49 PM
09/30/21 02:49 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
Just got a valve body from turbo action came with a cork/rubber gasket. what the heck if its good for turbo action should be good for me, went to service manual torque specs 150 inch pounds, tighten up gasket split around most bolt holes and pushed out pan rails.
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Trans. pan gasket [Re: IMGTX] #2968794
09/30/21 03:07 PM
09/30/21 03:07 PM
SWFL
Tie Rod Garage Offline
SWFL
Originally Posted by IMGTX
[quote=6PAX]
Most manual shafts have a ton of play. This solves it: https://superiortransmission.com/product/superior-k071/
1941 Dodge WC, 493 cid twin turbo FAST XFI
2002 Dakota R/T RC
Re: Trans. pan gasket [Re: 6PAX] #2968805
09/30/21 04:10 PM
09/30/21 04:10 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
I've got this Moroso 93110 gasket between my 727 and the deep MP aluminum pan.
Love it...steel core, with rubber around it!
Re: Trans. pan gasket [Re: Diplomat360] #2968951
09/30/21 10:53 PM
09/30/21 10:53 PM
A727Tflite Offline
A727Tflite  Offline
Look at the ad a little closer - it says not to be used with standard steel pans.
Wonder why.
