Winter oil change?? #2968670
09/30/21 06:29 AM
09/30/21 06:29 AM
tboomer Offline OP
tboomer  Offline OP
It won't be long until winter hits us here in Iowa. My car currently has VR-1 20-50 racing oil in it. My garage is not heated. Would it hurt to put a 5-20 oil in it for winter storage? Thanks! Ted wave
Re: Winter oil change?? [Re: tboomer] #2968678
09/30/21 07:45 AM
09/30/21 07:45 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Why? Are you going to fire it up during the winter?
69 GTX 68 Road Runner
Re: Winter oil change?? [Re: JERICOGTX] #2968684
09/30/21 08:12 AM
09/30/21 08:12 AM
tboomer Offline OP
tboomer  Offline OP
It's possible Jeff. wave
Re: Winter oil change?? [Re: tboomer] #2968687
09/30/21 08:28 AM
09/30/21 08:28 AM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
I like a quart of Lucas Heavy Duty Oil Stabilizer in there. Really clings to metal and helps with "dry starts". Been working great on my cars that sit too much.
Re: Winter oil change?? [Re: tboomer] #2968743
09/30/21 11:52 AM
09/30/21 11:52 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Why? Unless it's in a climate controlled garage, all it's going to do is create moisture. Let it sit until it warms up again.
Re: Winter oil change?? [Re: JERICOGTX] #2968795
09/30/21 03:14 PM
09/30/21 03:14 PM
tboomer Offline OP
tboomer  Offline OP
I changed the oil before you drove it the last time. It has only backed out of the garage a couple of times since. I thought I should change it before it gets acidic. shruggy
Re: Winter oil change?? [Re: tboomer] #2968809
09/30/21 04:27 PM
09/30/21 04:27 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
If you have only a couple starts on the oil, I'd leave it alone.
One of my friends is convinced that his engines have to be run every month regardless of the season. His reasoning is:
1) Exercises the valve train rather than letting it sit stationary in one position.
2) Keeps the carbs freed up with the swill they now call gas.
3) Keeps all the seals, front timing cover, rear main, water pump, free so they don't seize up.
4) Better than a battery tender for the electrical system.
Now he runs them until they come up to temperature and then about 15-20 minutes more. So far it's worked for him.
Me? If the oil is relatively new (less than 100 miles or so on it) I just leave it alone. That's worked for me with the exception that I've had carb problems in the spring.
twocents
Re: Winter oil change?? [Re: tboomer] #2968815
09/30/21 04:44 PM
09/30/21 04:44 PM
I run 5W20Wt Valvoline petroleum based oil in my street car year around up
Re: Winter oil change?? [Re: Cab_Burge] #2968836
09/30/21 05:14 PM
09/30/21 05:14 PM
tboomer Offline OP
tboomer  Offline OP
In the winter I go out every once in a while and turn the engine over by hand. I just put a couple of gallons of fresh race fuel in it. up
Re: Winter oil change?? [Re: 6PakBee] #2968870
09/30/21 07:07 PM
09/30/21 07:07 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Oil temperature tracks engine load, not water temperature. Unless it's actually driven and producing significant power, the oil now contains combustion byproducts including sulfuric acid, decomposed petroleum fractions, and water vapor.
Starting an engine from dead cold is the worst wear it ever sees. Ricardo discovered 100 years ago that the worst ring and wall damage is nearest TDC when cold.
Unless you're going to use it, don't start it at all.
Boffin Emeritus
Re: Winter oil change?? [Re: polyspheric] #2968953
09/30/21 10:58 PM
09/30/21 10:58 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I always change my oil in all my summer cruisers before I put them away for winter. That way they aren't sitting all winter with used oil with contaminants and fuel in them all winter. Probably does not effect anything if you don't but I do it anyway.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
