Big Block Motor Plate - Bolt to ideas? #2968739
09/30/21 11:44 AM
09/30/21 11:44 AM
Memphis, TN
MoparJason0O0 Offline OP
Memphis, TN
My motor plate on a big block 500 CI stroker motor just bolts into the block by the water pump and bolts.
Does someone make one that bolts all the way down further on the block or a couple bolts further down? Anyone tackled this idea?
Re: Big Block Motor Plate - Bolt to ideas? [Re: MoparJason0O0] #2968771
09/30/21 01:51 PM
09/30/21 01:51 PM
N
NITROUSN Offline
NITROUSN  Offline
N
I had one that also used some timing cover bolts.
plate
Re: Big Block Motor Plate - Bolt to ideas? [Re: NITROUSN] #2968958
09/30/21 11:08 PM
09/30/21 11:08 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I made mine to bolt just to the water pump housing bolt holes. However, I also have a miplate as well. It also mounts to my snout bars and ties to the frame rails as well.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
