Launch opinions #2968632
09/29/21 09:59 PM
09/29/21 09:59 PM
Gravataí, RS, Brazil
360tripleblack77 Offline OP
Hello Guys,
Since I started to share my videos a lot of members help me a lot to improove my 60ft. I started from 1.79 and now I'm doing 1.44 of 60ft.
Car still having some boucing at the launch and I would like some opinions how to fiz that. I'm posting a video (Sorry, not a good quality) and I will share what is the suspension configuration.
Footbrake, 4200 converter, Calvert Split monoleaf, sliders, hoosier stiff sidewall 28x10.5 (12psi), Viking DA front and rear, slant six torsion bars, front end travel over 5".
Front Shocks:
Compression: 15
Rebound: 2
Rear Shocks:
Compression: 5
Rebound: 10
'77 Brazilian Dodge Charger R/T - Street Car
Footbrake, Pump Gas, SB Mopar 360" N/A
3300lbs, Leaf Spring + Assassin Bars
Best 1/8 mile ET
1.50 60' / 4.31 330' / 6.73@102.54mph
Re: Launch opinions [Re: 360tripleblack77] #2968658
09/30/21 01:27 AM
09/30/21 01:27 AM
Stiffen up the fronts all the way and see if that helps your sixty foot times or not. It is bouncing due to the shocks topping out, I think scope
I would also try stiffening up the rears after getting the fronts set up the best you can up wrench
Re: Launch opinions [Re: Cab_Burge] #2968675
09/30/21 07:18 AM
09/30/21 07:18 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
My car is setup almost exactly like yours in the suspension area and it runs about the same times. I have an R1 block with W2 heads so the nose weight is likely heavier than yours. I recently went from old lakewood 90/10 shocks in the front to Viking DA shocks. With the old setup you could see it unload the rear tire right when the front topped out which was very quickly. Moving to the DA shocks fixed it and my first 3 passes ad the same 60ft of 1.4500(EXACTLY the same 60). I started with them set at 4 on the rebound and 12 on compression and I currently have them set at 5 and I have not tried anything more stiff yet but I plan to.
I don't know about going full stiff but you might try 4-6 and go from there. If someone can get on the starting line and do a slow motion video with an Iphone you can see soooo much more of what the car is doing.
This video was before the shocks
https://youtu.be/RUBhPsx8ZFg
The slow motion on this video starts a little late but the only change was the front shocks. I had the compression to loose on this pass and it really crashed the front down, I moved it up to 12 and it is way better.
https://youtu.be/1YJX0QfQKWE
68 Barracuda Formula S 340
Re: Launch opinions [Re: Bad340fish] #2968683
09/30/21 08:08 AM
09/30/21 08:08 AM
an8sec70cuda Offline
If the Cal-Trac bars aren't in the lower hole of the front bracket, I'd put them there.
I agree w/ stiffening the rebound on the front shocks, but I'd go about half way. twocents
Looks and sounds great! Very snappy!
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Launch opinions [Re: Cab_Burge] #2969725
10/02/21 07:37 PM
10/02/21 07:37 PM
Thanks Man! I think you're right about stiff a little bit the front shocks. I will try this.
Best 1/8 mile ET
Re: Launch opinions [Re: Bad340fish] #2969729
10/02/21 07:46 PM
10/02/21 07:46 PM
Whoowww. Very impressive how your car launch much better from the first to the second video. I will try a close setup as yours. Looks like that your and cab_burge ideas are in the same way. I really appreciate.
Best 1/8 mile ET
Re: Launch opinions [Re: an8sec70cuda] #2969734
10/02/21 07:54 PM
10/02/21 07:54 PM
Thanks Man! Really appreciate your kind words. I'm running with Assassin Bars and them are slightly angled down on the front bracket. I will post a Picture that you can see better.
Best 1/8 mile ET
Re: Launch opinions [Re: 360tripleblack77] #2969907
10/03/21 10:13 AM
10/03/21 10:13 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
A Brazilian Dodge Charger? Never seen one. Never knew one existed. But wow, that is one nice ride!
Re: Launch opinions [Re: 360tripleblack77] #2969926
10/03/21 11:03 AM
10/03/21 11:03 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I would agree that it is acting like a dog on a chain, either shock, spring or something in the suspension is running out of travel before the launch has used up the energy. Just like a running dog that reaches the end of its chain. Don't forget to look at things like tight ball joints and control arm bushings.
And it is a really neat looking car, I guess it is based on the A body mopar, like we had in the USA, just built in South America ?
Re: Launch opinions [Re: 360tripleblack77] #2970206
10/04/21 08:28 AM
10/04/21 08:28 AM
Definitely go tighter up front. It's leaving hard and topping the front out way too quickly.
CHIP
