Thermoquad Adjustment
#2967932
09/27/21 07:08 PM
09/27/21 07:08 PM
Posts: 2,385 White Plains, NY
VCODE
White Plains, NY
1971 340 Cuda surges while driving steady. I think I can adjust the Rods with the center screw to help with the surge. Which way to turn the screw, cw or ccw to raise the rods out of the jets. Thanks Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: Thermoquad Adjustment
[Re: TJP]
#2968013
09/27/21 10:15 PM
09/27/21 10:15 PM
VCODE
White Plains, NY
The car runs very good and does not ping. I will check the total timing and vacuum again. Don't think it's that but I could be wrong. Bob
[Re: VCODE]
#2968248
09/28/21 09:01 PM
09/28/21 09:01 PM
Posts: 608 TN
1DGEMAN
TN
If it has a 71 TQuad on it metering rods do not adjust that is a 72 and later.
Real Men shift for themselves
[Re: 1DGEMAN]
#3030958
04/05/22 02:51 PM
04/05/22 02:51 PM
VCODE
White Plains, NY
Back after the long winter and just looked at my carb. TQ K0 4973S Oct 1970 340 auto and it has a adjusting screw on the metering rod bridge. Whats with that? Any info Bob
[Re: VCODE]
#3031055
04/05/22 08:54 PM
04/05/22 08:54 PM
Posts: 15,438 Omaha Ne
TJP
Omaha Ne
Back after the long winter and just looked at my carb. TQ K0 4973S Oct 1970 340 auto and it has a adjusting screw on the metering rod bridge. Whats with that? Any info Bob A pic may help
[Re: TJP]
#3031108
04/06/22 01:07 AM
04/06/22 01:07 AM
Posts: 16,153 Mesa, Arizona
dart4forte
Mesa, Arizona
Back after the long winter and just looked at my carb. TQ K0 4973S Oct 1970 340 auto and it has a adjusting screw on the metering rod bridge. Whats with that? Any info Bob A pic may help Yes. Depress the metering rod primary piston until it lightly bottoms in the bore. Hold it there. With a small screwdriver, turn the screw counter clockwise until the primary piston stops going down. Then, slowly turn the screw clockwise taking note where the primary piston starts to move up. From the point it begins to move up, turn the screw 1 1/2 turns clockwise. This is a starting point. From there you can fine tune it by turning the screw clockwise to richen the mixture and counter clockwise to lean it. https://www.youtube.com/watch?v=Dwh6SQ7kV6E
Abe Lincoln
[Re: dart4forte]
#3031275
04/06/22 02:43 PM
04/06/22 02:43 PM
Posts: 19,488 north of coder
moparx
yes, that is how that screw is used for adjustment. it rides on a cam that is in the base plate. lots of adjustments on a T-Quad. at one time, carter had a great book on choosing, adjusting, and tuning the T-Quad. this book also listed all the base plate numbers and what those numbers were installed on. jets, metering rods, and other parts were also listed. as that book has been out of print for a while, i don't know where you would get a copy. chrysler also published a book under the master technicians service conference series. it was titled "The '72 Thermoquad Carburetor", reference book 72-1. that has some good info in it as well, but again, i don't know where you would get a copy. i would offer to put these books into a PDF file and send them out to those interested, but it would be a while, as i'm having hip surgery tomorrow. maybe if anyone is interested, i can do this in a few weeks. PM me then to see if i am able to get around good enough to do this.
[Re: TJP]
#3031294
04/06/22 03:26 PM
04/06/22 03:26 PM
VCODE
White Plains, NY
Back after the long winter and just looked at my carb. TQ K0 4973S Oct 1970 340 auto and it has a adjusting screw on the metering rod bridge. Whats with that? Any info Bob A pic may help Well after taking the picture, I can now see it is not a screw slot on bridge but the way it's made.
[Re: moparx]
#3032226
04/09/22 10:09 PM
04/09/22 10:09 PM
Posts: 1,762 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
...chrysler also published a book under the master technicians service conference series. it was titled "The '72 Thermoquad Carburetor", reference book 72-1. that has some good info in it as well, but again, i don't know where you would get a copy. Great advice moparx! I've got a pile of the Carter TQ literature here, some of it scanned already. A few of these are up on my web server, you can get them here: 1) TQ Service Manual2) 1982 TQ Tech Guide3) 1972 TQ Reference BookNOTE: if you try the above links and you get nowhere, try again a bit later, I may have the web server down for some maintenance of changes.
[Re: Diplomat360]
#3032277
04/10/22 09:07 AM
04/10/22 09:07 AM
VCODE
White Plains, NY
Thanks for all the great info Bob
