Mopar Magnum M1 Intake question
#2967348
09/25/21 05:21 PM
09/25/21 05:21 PM
Posts: 1,819 Middle of A Field
OrangeProwler
Middle of A Field
I have a 79 Lil Red Express truck with a 408 Magnum stroker in it. The specs on the engine are 10.5.1 compression, Edelbrock ported heads, Hughes Hydraulic Roller (Custom Grind); 228/236 @ .050 .550/.565 on a 108 LSA w/ degrees of advance and Crower 1.7 rockers. Has about a 2500 stall in it now along with 3.55 gears. Currently has an Edelbrock Performer RPM Air Gap with a Holley 770 Street Avenger. My brain was wondering with this combination if the Mopar M1 4bbl intake with a rebuilt 850cfm Thermoquad if it would be a better runner in the mid range and up top? Just something I was throwing around in my head at this point.
Re: Mopar Magnum M1 Intake question
[Re: moparmarks]
#2967477
09/26/21 10:48 AM
09/26/21 10:48 AM
Posts: 20,185 Park Forest, IL
slantzilla
Park Forest, IL
Personally I'd put a looser converter in it and leave the motor alone.
[Re: gzig5]
#2967820
09/27/21 01:18 PM
09/27/21 01:18 PM
Posts: 4,953 Houston, Texas
TheOtherDodge
Houston, Texas
I don't know much but I'm betting that the capability of the heads is going to affect the outcome with the different intakes. If they are restrictive with respect to feeding 408 cubes, I bet you won't see much difference. Those Eddy heads are a pretty decent head, especially ported (assuming good port job) so I doubt they will be any restriction.
[Re: TheOtherDodge]
#2967853
09/27/21 02:36 PM
09/27/21 02:36 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
That's very close specs to the engine I built for my dakota R/T, it had a little more midrange with the RPM air gap than the M1 single plane. The single plane did give me a little more top end butt not much, I actually switched them because it was impossible to hook up and I wanted to knock out a little mid range in trade for more RPM.
