'91 Grand Caravan 3.3V6 fuel delivery issue question #2967362
09/25/21 06:02 PM
09/25/21 06:02 PM
N.E. OHIO, USA
A12 Online content OP
A12  Online Content OP
N.E. OHIO, USA
The old "it ran when I parked it", Yes it's been sitting out of the way for a while (+1 year) and yes it was running and running great (that 3.3 V6 is a nice engine). New battery and cranks but just won't fire or even pop. Suspect the fuel pump seized but it seems to or sounds like it's working but no evidence of fuel in the cylinders? Sprayed a little contact and starter fluid in the air intake and still nothing. Going to check for spark but ran across a youboob video that claims it might just be a relay for shutting down the fuel??? It wasn't specific as to which or where it is but I got the impression it is one of the three in the attached photo?? If it is I'll jump it if I can figure out how but first I have to figure out if it even is one of these or if I'm wasting time. Thanks in advance as usual for Moparts help up
Mike
Re: '91 Grand Caravan 3.3V6 fuel delivery issue question [Re: A12] #2967369
09/25/21 06:17 PM
09/25/21 06:17 PM
Florida STAYcation
dOOc Offline
The village idiot's idiot
dOOc  Offline
Florida STAYcation
B-13 .... a 91 Carrotvan? eek
As a famous and wealthy owner of a C14,car .... isn’t it time you MOVE UP in the Mopar world with at least a 01 or so ?
No fire with starting fluid ? ... no sparky is the issue tsk
Re: '91 Grand Caravan 3.3V6 fuel delivery issue question [Re: A12] #2967370
09/25/21 06:29 PM
09/25/21 06:29 PM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
A service manual for your van is your helpful friend. It should show what relay is for the fuel pump. You can remove the return line and jump the fuel pump relay to see if its pumping.
