what oil to lube cyls with #2967123
09/24/21 07:43 PM
09/24/21 07:43 PM
RapidRobert Offline OP
eng has been idle for a year & might be for another year. what should I use/spray in the spark plug holes? thank you for your time.
Re: what oil to lube cyls with [Re: RapidRobert] #2967145
09/24/21 08:53 PM
09/24/21 08:53 PM
5 or 6 squirts of 5W20 wt. non synthetic engine oil and then spin the motor with all the plugs out five to 15 revolutions and do that again once more before putting the plugs back in up twocents
Re: what oil to lube cyls with [Re: Cab_Burge] #2967176
09/24/21 11:31 PM
09/24/21 11:31 PM
Thanks Cab, you're always the man up
Re: what oil to lube cyls with [Re: RapidRobert] #2967243
09/25/21 10:46 AM
09/25/21 10:46 AM
Canada
O
orange Offline
orange  Offline
O
Canada
I've used Marvel Mystery oil in the past and had great results.
Re: what oil to lube cyls with [Re: RapidRobert] #2967248
09/25/21 10:50 AM
09/25/21 10:50 AM
IMGTX Offline
IMGTX  Offline
When possible I also spray an air nozzle into the spark plug hole to distribute the oil and coat the cylinder with the oil.
Don't breathe the oil mist though. Can't be good for you but neither is most of the stuff we spray.
Re: what oil to lube cyls with [Re: IMGTX] #2967272
09/25/21 11:44 AM
09/25/21 11:44 AM
A727Tflite Offline
A727Tflite  Offline
Fresh battery, plugs out, spin the motor over and spray fogging oil down the carb.
You should see a light mist come out of the plug holes, when you do you are done . Install the plugs and close off the carb.
Re: what oil to lube cyls with [Re: A727Tflite] #2967607
09/26/21 07:06 PM
09/26/21 07:06 PM
very good info much appreciated, thanks guys up
