I got two questions #296693
04/22/09 07:18 PM
04/22/09 07:18 PM
NE Oklahoma
71valiant Offline OP
NE Oklahoma
First off, my buddy's building a 440. Its got a edelbrock torqer intake and 750 dp and manifolds. What cam would you recommend. He wants good power all the way up. Its a street strip motor.
Second, I'm trying to tune my 360sb. Ive got a holley 750 DP. I've got 72/84 jets in it. It seems alittle lean on the front two. You think I should step up?
Re: I got two questions [Re: 71valiant] #296694
04/22/09 07:29 PM
04/22/09 07:29 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
First question:509 or 484 hydraulic .Second question:Are you running power valve in the primary?
Re: I got two questions [Re: B G Racing] #296695
04/22/09 08:38 PM
04/22/09 08:38 PM
NE Oklahoma
NE Oklahoma
Honestly I dont know if I am running a power valve or not. Im a novice at this stuff. How can I tell.
Re: I got two questions [Re: 71valiant] #296696
04/23/09 08:37 AM
04/23/09 08:37 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Check the center of the metering block for a 1" nut with a diaphram on the one side and a spring valve on the other.
