Any plumbers here? #2966662
09/23/21 12:03 PM
09/23/21 12:03 PM
BDW Online content OP
BDW  Online Content OP
It looks like my hot water heater is leaking at the connection to the house.
2 questions:
1) Tank is 17yrs old, should I bite the bullet and spend the $500 to replace it myself, or just fix this connector?
2) What kind of connection is it, it's PVC with no give, so how would I remove and replace it?
Re: Any plumbers here? [Re: BDW] #2966669
09/23/21 12:15 PM
09/23/21 12:15 PM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
Not a plumber but my guess is CPVC - and gas water heaters aren't designed to last 17 years, usually 10-12 i think
Ride eternal, shiny and chrome
Re: Any plumbers here? [Re: BDW] #2966676
09/23/21 12:33 PM
09/23/21 12:33 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
I’d replace the tank. 17 years is old. Unless you are broke and the tank is located outside where a major leak would not be a problem.
Re: Any plumbers here? [Re: Pacnorthcuda] #2966679
09/23/21 12:42 PM
09/23/21 12:42 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
And when they replace it, have them put a) shutoff valves and b) unions on those water lines this time.
Who ever did the install 17 years ago cheaped out just straight-piping it like that. If you ever need to mess with it in the future, shutoff valves and unions make things a lot easier--and only for a few bucks more.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Any plumbers here? [Re: wingman] #2966680
09/23/21 12:47 PM
09/23/21 12:47 PM
Well, "them" is me.........I'll be doing the work.
So how do I replace what,looks like rigid CPVC, that doesn't appear to have any give?
Cut off everything there and use flex lines?
Spoon feed me, the electric not an issue, need to know how to handle the piping.
Re: Any plumbers here? [Re: BDW] #2966690
09/23/21 01:34 PM
09/23/21 01:34 PM
Back In Iowa
belv2vert66 Offline
belv2vert66  Offline
Back In Iowa
2 questions:
I would replace it, but if it is working just change the fitting.
Cut the horizontal pipe near the elbow
unscrew the fitting from the water heater.
use a thread pipe to sharkbite fitting back on the water heater. Use teflon tape with a little pipe dope over it on the threads.
stick in a length of cpvc
gauge where the new sharkbite elbow goes by the height of the horizontal pipe. Allow length to insert into shark bite elbow
insert length of cpvc into horizontal part of elbow
trim horizontal cpvc to length allowing for insert into the shark bite repair union to connect to the horizontal pipe (It is a fitting that allows you to slip it on and the into the other fitting) (Google shark bite repair union)
Re: Any plumbers here? [Re: wingman] #2966712
09/23/21 02:53 PM
09/23/21 02:53 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
Shut off valve on the hot water TO the house? Doesn't make sense. All you need is a shut off of the cold to the tank. Once that's shut off there's no hot water pressure to the house.
Re: Any plumbers here? [Re: Fat_Mike] #2966721
09/23/21 03:33 PM
09/23/21 03:33 PM
O
oldjonny Offline
Don't argue with me.
oldjonny  Offline
O
wow...I thought nobody used CPVC anymore. That stuff is a leak waiting to happen.
Never, ever argue with an IDIOT. They will drag you to their level and then beat you with their years of experience
Re: Any plumbers here? [Re: Fat_Mike] #2966741
09/23/21 04:46 PM
09/23/21 04:46 PM
RWG75
RWG75
Comes in handy when swapping the tank - keeps the lines from draining back when you disco the tank. My copper stubs have shuts offs with NPT adapters then braided stainless NPT to NPT hoses to the tank. Kinda like this but with a water heater:
Re: Any plumbers here? [Re: ] #2966867
09/23/21 10:38 PM
09/23/21 10:38 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
When you drain the water heater prior to replacing it, whatever water is in the lines drains back also. I'm not saying a valve on the hot side is a a bad idea, just very unnecessary.
Re: Any plumbers here? [Re: BDW] #2966877
09/23/21 11:42 PM
09/23/21 11:42 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Replacing it is the right action but...
U better check for the latest pricing, water heaters cost and availability has changed significantly due to increased market demand and Covid..
Just my $0.02... wink
Re: Any plumbers here? [Re: Sinitro] #2966886
09/24/21 01:10 AM
09/24/21 01:10 AM
Here
Here
Especially here in NJ with the recent catastrophic flooding. Our HVAC guys have replaced so many units!
Re: Any plumbers here? [Re: oldjonny] #2966887
09/24/21 01:12 AM
09/24/21 01:12 AM
Here
Here
Especially on the hot line
Re: Any plumbers here? [Re: DirectSubjection] #2966901
09/24/21 06:42 AM
09/24/21 06:42 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Yes the prices have shot up. I’ve never seen cpvc used like that or a fitting like that. The tank should have two 3/4” male nipples sticking out of the top. They make two types of flexible lines. I use stainless steel flex lines with female ends on both ends. On the hot side, just cut off the cpvc coming out of the wall and glue a 3/4” male adapter to iron pipe fitting. Install the flex line with two female iron pipe ends and your fixed. On the cold side, you need a cutoff. I don’t see one in the picture. I’d glue on another male adapter and install a 3/4” brass ball valve on the pipe coming out of the wall. Put in a 3/4 x 2” brass nipple in the out side of the ball valve. Now you can install the same flex line with two female ends on it as well. Don’t over tighten the lines. They have thick rubber washers inside. The fittings compress the rubber to seal. It does not seal on the threads. Cpvc uses special glue. Let it set up for a couple of hours before you apply pressure to the system. Hope this helps.
Re: Any plumbers here? [Re: DirectSubjection] #2966902
09/24/21 06:48 AM
09/24/21 06:48 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Cpvc is for the hot side only. PVC is for cold. The t and p valve is always plumbed with Cpvc. It’s just so out of date. Everyone uses Pex now. It’s flexible, cheaper than copper and you don’t have to hire a security guard to watch your building site after hours because thieves take it before the slab gets poured.
Re: Any plumbers here? [Re: fastmark] #2966913
09/24/21 07:38 AM
09/24/21 07:38 AM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
Where is your hot water heater located? An issue I ran into when I replaced an OLD unit is that the new units are bigger around due to increased insulation. The new unit worked just fine, but other mods had to be done because of the size increase.
twocents
John
Re: Any plumbers here? [Re: fastmark] #2966963
09/24/21 10:33 AM
09/24/21 10:33 AM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
^^^^^ This.
Re: Any plumbers here? [Re: pushbutton] #2966997
09/24/21 11:59 AM
09/24/21 11:59 AM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
My gas water heater is 32 years old and zero issues. I cook with gas also, approx 28 year old stove....$14 a month and $9 is the service charge. Heat with gas with 30 year old furnace, total bill in the coldest of winter $55.
Id fix it.
I get calls all the time about upgrades to my gas appliances from my gas company but yet every month they send out usage reports vs 100 close neighbors... im always in the top 5%.
A fluke, luck...who knows.
STOP POTATO HATE!
Re: Any plumbers here? [Re: BDW] #2967034
09/24/21 01:34 PM
09/24/21 01:34 PM
CO
Redbird Offline
Redbird  Offline
CO
You have demonstrated the workmanship of your plumbing skills.
What do the brake lines in your car look like?
Re: Any plumbers here? [Re: Redbird] #2967091
09/24/21 05:10 PM
09/24/21 05:10 PM
Lot of good inputs, much appreciated.
Looking at prices and availability of a new tank, I think I'm going to attempt a repair.
I'll report back the results.
Thx
