Re: 360-1 RP smallblock heads (Indy) ???
[Re: RyanJ]
#296669
04/24/09 09:35 AM
04/24/09 09:35 AM
Posts: 541 South Carolina
a408swinger
mopar addict
mopar addict
South Carolina
EVERY INDY CNC Chamber motor I have done.... does'nt matter what piston shape, what compression, what fuel.... has made best power with 38-42 timing. Looking at the burn patterns on pistons & chambers off of used ones they have real good burn, but like alot of spark lead......
Sounds like it picked up at least 30 HP over what seemed to be some pretty radical hand ported -1's. Hopefully you can find even more, glad you finally got the piston hassles etc ironed out.
I basicly got screwed on the pistons and had to use them. They cut way too much off of them and they wound up being 16 grams lighter than my old ones. After they re-cut the valve reliefs they went from a +4.85cc dome to a -.685 dome which dropped my compression to about 11.8 to 1 from 14.5 to 1 with my old heads and pistons. Thats why I was surprised to see that it picked up HP from the old motor. I know I can pick up at least 10-15 more HP with just some more fuel and then I would like to try some more timing also. I know 2 degrees (33 to 35) picked up 10hp to the tires.
[Re: a408swinger]
#296670
04/24/09 10:19 AM
04/24/09 10:19 AM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
That's good to know. I recently ran my 422 with 360-2 heads for the first time with 34* timing. I didn't get to do any tuning but it sounds like there is plenty of power left just from timing. Your car runs good. Got any pics?
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
[Re: SB449VALIANT]
#296675
04/24/09 06:38 PM
04/24/09 06:38 PM
a408swinger
mopar addict
mopar addict
South Carolina
.060 off, v/c are moroso.
I milled mine .030 and they were still 67cc's. I was a Ross piston man until I got screwed over. They made my pistons wrong which I didn't find out until after I assembled my motor. They were supposed to be the exact pistons I had before but just cut to allow for the bigger intake valve so I assumed they were correct. Instead of making me new ones I had to dissasemble the motor and send them back and they cut waaaaaayyy too much off of them. It killed my compression and they were 16 grams too light and they said "Dont worry, it will be fine". I can now feel a vibration over 7000 rpms I never had before. Ill never use them again. Its funny when you pay for a specific custom piston and you dont get anything like what you ordered but are forced to use them because thats all they are willing to do even though it was their mistake.
[Re: a408swinger]
#296677
04/26/09 11:38 AM
04/26/09 11:38 AM
Posts: 1,499 San Antonio,TX
440W8 Duster
San Antonio,TX
Tom how did you(car) do this weekend?
70 Duster W8 motor. 1.29 60ft 5.79 1/8 at 120 mph glide with 1.80 gear @3170 lbs.
[Re: mr. 63plymouth]
#296679
04/27/09 07:53 AM
04/27/09 07:53 AM
Posts: 5,000 Tampa Florida
dc426
gotta keep'm separated
Tampa Florida
461 small block in a 68 Barracuda with indy heads made 741hp and 638torque on pump gas, naturally aspirated,single 750holley timed at 33. Car went 9.75@139.88mph on a 10" tire
Boy, I sure would like to hear more about this combo......that's kickin! DC
#296680
04/27/09 11:37 AM
04/27/09 11:37 AM
Posts: 1,418 Mcallen, TX
SB449VALIANT
Mcallen, TX
461 small block in a 68 Barracuda with indy heads made 741hp and 638torque on pump gas, naturally aspirated,single 750holley timed at 33. Car went [Email]9.75@139.88mph[/Email] on a 10" tire
WHAT??? THERE MUST BE SOMETHING WRONG THERE, THAT CAR SHOULD FLY WITH ALL THAT POWER
[Re: 440W8 Duster]
#296681
04/27/09 11:59 AM
04/27/09 11:59 AM
a408swinger
mopar addict
mopar addict
South Carolina
5.60's @ 124. Still creeping up on it. I think Im gonna swap the front struts from Strange to QA1's.
#296682
04/27/09 12:00 PM
04/27/09 12:00 PM
a408swinger
mopar addict
mopar addict
South Carolina
Are they the CNC heads? What does your car weigh with you in it race ready?
[Re: Otherlane]
#296685
04/27/09 02:50 PM
04/27/09 02:50 PM
Posts: 273 Edmonton alberta Canada
mr. 63plymouth
Tried a 950 on dyno, only picked up 11hp, so left the 750 on with the 1 3/4" headers and smaller cam. Bigger carb would be more efficient with bigger headers and cam!Car is very mello on the street, idles excellent!! Thats with 5000feet air!!!
