New Comp Cam lifters #2965275
09/18/21 04:02 PM
09/18/21 04:02 PM
Valley of the sun, AZ
2
2JcodeChargers Offline OP
So I've installed a new Comp Cam and get the lifters out of the box... and here's what 7-8 of them look like. [censored]!!! I don't know if this will cause problems or not. At least the faces of the lifters are nice but these sides look like crap. I want to get this back together but would you guys use these?
Re: New Comp Cam lifters [Re: 2JcodeChargers] #2965276
09/18/21 04:03 PM
09/18/21 04:03 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
No.
Re: New Comp Cam lifters [Re: Pacnorthcuda] #2965283
09/18/21 04:18 PM
09/18/21 04:18 PM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
Back to the great and powerful and the worlds worst QC for over 15 years..... Drum Roll................. Junk Axx .... Comp Cams.
Id send it all back and buy a diff brand.
They are like ebays worst seller that ebay still lets sell.
It happens with %50 of comp products I used to buy.
Crap in a box.
STOP POTATO HATE!
Re: New Comp Cam lifters [Re: 2JcodeChargers] #2965287
09/18/21 04:24 PM
09/18/21 04:24 PM
MN
W
Willie68coronet Offline
W
MN
If they drop in and turn, I'd say they're fine. I'd personally return them and buy Howards or some other brand.
If you can't wait, maybe WD40 and emory them smooth? But you shouldn't need to with new lifters
'68 Coronet 500 w/ Indy EZ-1 headed 446, 727 trans, 9" rear
First day at the track with SUV street tires and no traction: 1.688 60', 7.24 @ 101.79 in the 1/8 mile
Great customer service from: DominicThumper Carbs, B3 racing engines, Porter Racing Engines, A-1 torque converter's, Quick Performance, Racer Brown Cams, R&R Performance, Manton pushrods
Re: New Comp Cam lifters [Re: Willie68coronet] #2965290
09/18/21 04:27 PM
09/18/21 04:27 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
They look like they have been in storage for years and years. I'm doubting they came right out of production like that and I wouldn't use them
Facts are stubborn things.
Re: New Comp Cam lifters [Re: larrymopar360] #2965295
09/18/21 04:39 PM
09/18/21 04:39 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
If you’d like to put it together instead of waiting for parts, a little PB Blaster and some scotchbrite would probably take care on that in short order.
Re: New Comp Cam lifters [Re: larrymopar360] #2965297
09/18/21 04:42 PM
09/18/21 04:42 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Comp is just a label for an LLC. Forget any history with them, it's the lowest quality they can pawn off. As far as those lifters go, I'd send them back.
Re: New Comp Cam lifters [Re: Skeptic] #2965302
09/18/21 05:14 PM
09/18/21 05:14 PM
2
Yes, they look to me as if they have been in a box for years. Surprises me, because regardless of cam specs these are the "generic" mopar Comp cams lifter. They must sell more than a couple of cams a month so I would think the lifters would be going out to customers on a regular basis. Pretty disappointing and another reminder of why after 40+ years of doing this stuff, I'm really running out of patience with the older car scenario. Years ago you could go to the local NAPA and get things like lifters and not have to worry about quality. Now, it seems the vast majority is second rate and it's a crap shoot if you can use it or not.
I thought about the scotch-brite and lube clean up, but it really deflates me to thing I even would have to do this.
I bought the cam kit from Summit Racing, so I think I will call them and see if they can ship me just a set of lifters since the cam is already installed and lubed and the timing cover is back on.
Re: New Comp Cam lifters [Re: larrymopar360] #2965317
09/18/21 06:15 PM
09/18/21 06:15 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
In this case… that could be a good thing.
My buddy lost 2 comp cams on a run stand almost immediately. 3 weeks apart same part number. Both from Summit Racing.
I sold him an old MP cam I had that dated pre 2000.
No issues…. Been in car driven regular for over a year.
I have a Comp cam in my Barracuda bought in 2010. Still good.
Re: New Comp Cam lifters [Re: autoxcuda] #2965365
09/18/21 08:54 PM
09/18/21 08:54 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree
how long have you had them and where were they purchased ?
Maybe they're cleaning out old inventory shruggy I sure wouldn't put it past them. Run em or not? Roll of the dice. If there are any pits could be some addition oiling there whistling
shruggy beer
Re: New Comp Cam lifters [Re: TJP] #2965442
09/19/21 09:32 AM
09/19/21 09:32 AM
God's Country Maryland
GODSCOUNTRY340 Offline
If the outside looks like that what does the inside look like? There are moving parts on the inside and if there's rust in there it could interfere with the plunger, metering disc and spring inside the lifter. If you're in a hurry, take the lifters apart and make sure there's no rust inside, clean them up, coat with oil and use them.
Re: New Comp Cam lifters [Re: GODSCOUNTRY340] #2965513
09/19/21 05:00 PM
09/19/21 05:00 PM
Guitar Jones Offline
They look like most of the new Mopar parts we used to get, Mostly Old Parts And Rusted.
Re: New Comp Cam lifters [Re: fast68plymouth] #2965531
09/19/21 05:56 PM
09/19/21 05:56 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
iagree
Re: New Comp Cam lifters [Re: 2JcodeChargers] #2965585
09/19/21 09:45 PM
09/19/21 09:45 PM
Prospect, PA
BSB67 Online content
BSB67  Online Content
Prospect, PA
Who did you buy them from? Did you buy direct from Comp?
Re: New Comp Cam lifters [Re: 2JcodeChargers] #2966156
09/21/21 08:55 PM
09/21/21 08:55 PM
PA
Scully Offline
Scully  Offline
PA
They're fine, you could take that off with your fingernail and as pointed out if they're actually old it's a good thing.
