Need help identifying these brakes #2965013
09/17/21 02:37 PM
09/17/21 02:37 PM
Mission BC
10sec440 Offline OP
10sec440  Offline OP
Mission BC
Hello, I'm working on a 69 Dart and I have to get the correct lower ball joints. The front calipers look similar to a 73 and up setup but it has pins instead of sliders. I think they are Diplomat brakes? If so does anyone have an idea what knuckles would be used to put these on a Dart? Thanks in advance.
Re: Need help identifying these brakes [Re: 10sec440] #2965078
09/17/21 07:52 PM
09/17/21 07:52 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Could be FMJ body brakes or 70 74 B E body.
Or an aftermarket swap that used Ford calipers.
Pics will help.
Angry white pureblood male
Re: Need help identifying these brakes [Re: ruderunner] #2965085
09/17/21 08:07 PM
09/17/21 08:07 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Don't think FMJ's ever came with pin type calipers.
Some pictures and maybe the measurement between the mount holes would help.
The are only lower ball joint I am aware of that will work on an A body using later stock mopar 4.5" bolt pattern discs is the 73 and up disc brake ball joints.
Re: Need help identifying these brakes [Re: 10sec440] #2965104
09/17/21 08:48 PM
09/17/21 08:48 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I have 73 Charger brakes on my Savoy and they are pin type calipers.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Need help identifying these brakes [Re: fourgearsavoy] #2965118
09/17/21 09:48 PM
09/17/21 09:48 PM
Mission BC
10sec440 Offline OP
10sec440  Offline OP
Mission BC
Thanks guys, I do have a pic but I can't seem to figure out how to post it.
Re: Need help identifying these brakes [Re: 10sec440] #2965124
09/17/21 10:08 PM
09/17/21 10:08 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I believe all of the late rear wheel drive cars used the slider calipers. The pin type were early 70s B/E as I understand it.
Re: Need help identifying these brakes [Re: Jim_Lusk] #2965137
09/17/21 11:31 PM
09/17/21 11:31 PM
n.c.
geo. Offline
geo.  Offline
n.c.
last to use both may have been '75- B bodies, I found my 11.75" set up on a '76 2 door Fury with pin type calipers.
The '73- A body pin types had smaller pistons than the 2.75" E and B bodies.
Re: Need help identifying these brakes [Re: geo.] #2965175
09/18/21 07:17 AM
09/18/21 07:17 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
I took pin type off a 77 B when I did my swap to big rotors.
Re: Need help identifying these brakes [Re: geo.] #2965177
09/18/21 07:30 AM
09/18/21 07:30 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
73 A bodies did not use pin type calipers. Sliders only. Pre 73 did use a pin type, but that would be the 4" bolt pattern setup
Re: Need help identifying these brakes [Re: Sniper] #2965210
09/18/21 10:55 AM
09/18/21 10:55 AM
Central Michigan
N
nuthinbutmopar Offline
N
Central Michigan
This is one of those places where the RockAuto online catalog is an asset. You can start picking a likely suspect (say a '75 Charger), drill down to the likely part (brake pads), and look at pics to see that according to the parts shown, they apparently went from a base number 39 pin-type pad to a base number 84 slider-type pad (some say 5/75, some say 11/75). Then click on the part number to see that the 84 slider pad fits everything from a '73 A to and '89 M-body. The 39 pin-type fits everything from a '66-78 B-body to a Bricklin to a Gremlin to a '72 D300 and a 1010 IHC truck. It's GREAT for figuring interchange on mechanical parts, especially on oddball stuff.
Re: Need help identifying these brakes [Re: Sniper] #2965319
09/18/21 06:21 PM
09/18/21 06:21 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
You can mix and match pin and slider calipers and caliper adapter bracket on 73-76 A-body/73-74 E-body spindles. Same for FMJ spindles.
So you really need to examine part for part what you have. Look for the Mopar Action Disc-O-Tech brake swap article online.
