1968 Dart Hood Insert Attaching Hardware #2964554
09/15/21 09:40 PM
09/15/21 09:40 PM
TN
JS29R0B Offline OP
JS29R0B  Offline OP
TN
Hey A body experts I need to know where to get the correct attaching nuts for this Dart hood insert. The Dorman brand at auto parts stores
doesn't seem to be the right size. Thanks in advance.
Re: 1968 Dart Hood Molding Attaching Hardware [Re: JS29R0B] #2964587
09/15/21 11:12 PM
09/15/21 11:12 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
That is a hood insert, the hood molding goes on the front of the hood. wave I have dozens of them laying around, if you can't find them let me know..
JB Rhinehart, Realist
A-Body's RULE!
Re: 1968 Dart Hood Molding Attaching Hardware [Re: Rhinodart] #2964642
09/16/21 09:45 AM
09/16/21 09:45 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Is that how the reproduction hood inserts come?(all chrome and no textured argent on the sides)
The original inserts have tapered "pins" so the speed nuts will start easily. It looks like the reproduction mounting "pins" aren't tapered. This makes getting the speed nuts to start more difficult. I just ran into this with the reproduction 68 Dart console top plates. I had to use a nut driver and put a fair amount of pressure on the speed nuts to get them to start. Once they started, they went on fine though.
Re: 1968 Dart Hood Molding Attaching Hardware [Re: JS29R0B] #2964653
09/16/21 10:12 AM
09/16/21 10:12 AM
Clinton, NJ
N
njmopar Offline
njmopar  Offline
N
Clinton, NJ
I got the correct ones from AMK that have dumb dumb in them. I cant recall which part number it was though, I used an old one to get the dimensions and matched.
Re: 1968 Dart Hood Molding Attaching Hardware [Re: njmopar] #2964658
09/16/21 10:29 AM
09/16/21 10:29 AM
TN
JS29R0B Offline OP
JS29R0B  Offline OP
TN
Yes these are repops. I didnt get any with the car so I had no choice. I will check AMK thanks.
Re: 1968 Dart Hood Molding Attaching Hardware [Re: JS29R0B] #2964661
09/16/21 10:43 AM
09/16/21 10:43 AM
Clinton, NJ
N
njmopar Offline
njmopar  Offline
N
Clinton, NJ
You should build a shopping list for AMK, since you need an order minimum of like $30. Which you can pretty easily reach if you start looking around, so much in there.
Re: 1968 Dart Hood Molding Attaching Hardware [Re: njmopar] #2964983
09/17/21 12:39 PM
09/17/21 12:39 PM
TN
JS29R0B Offline OP
JS29R0B  Offline OP
TN
Thanks for the info!
