Re: changed posi , now gears make lots of noise! [Re: DoctorDiff] #296376
04/23/09 10:33 AM
04/23/09 10:33 AM
30 Rock
JS29 Offline
JS29  Offline
30 Rock
Mona Lisa Vito: The car that made these two, equal-length tire marks had positraction. You can't make those marks without positraction, which was not available on the '64 Buick Skylark!
Vinny Gambini: And why not? What is positraction?
Mona Lisa Vito: It's a limited slip differential which distributes power equally to both the right and left tires. The '64 Skylark had a regular differential, which, anyone who's been stuck in the mud in Alabama knows, you step on the gas, one tire spins, the other tire does nothing.
[the jury members nod, with murmurs of "yes," "that's right," etc]
Vinny Gambini: Is that it?
Mona Lisa Vito: No, there's more! You see? When the left tire mark goes up on the curb and the right tire mark stays flat and even? Well, the '64 Skylark had a solid rear axle, so when the left tire would go up on the curb, the right tire would tilt out and ride along its edge. But that didn't happen here. The tire mark stayed flat and even. This car had an independent rear suspension. Now, in the '60's, there were only two other cars made in America that had positraction, and independent rear suspension, and enough power to make these marks. One was the Corvette, which could never be confused with the Buick Skylark. The other had the same body length, height, width, weight, wheel base, and wheel track as the '64 Skylark, and that was the 1963 Pontiac Tempest.
Vinny Gambini: And because both cars were made by GM, were both cars available in metallic mint green paint?
Mona Lisa Vito: They were!
Vinny Gambini: Thank you, Ms. Vito. No more questions. Thank you very, very much.
[kissing her hands]
Vinny Gambini: You've been a lovely, lovely witness.
Re: changed posi , now gears make lots of noise! [Re: JS29] #296377
04/23/09 11:44 AM
04/23/09 11:44 AM
rochester,new york
P
plumebody Offline
plumebody  Offline
P
rochester,new york
My Cousin Vinnie
And she's HOT
Re: changed posi , now gears make lots of noise! [Re: plumebody] #296378
04/23/09 01:52 PM
04/23/09 01:52 PM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
My Cousin Vinnie
And she's HOT
Pic?
Re: changed posi , now gears make lots of noise! [Re: CYACOP] #296379
04/23/09 02:17 PM
04/23/09 02:17 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
My Cousin Vinnie
And she's HOT
Pic?
Just google Marisa Tomei.
Re: changed posi , now gears make lots of noise! [Re: GomangoCuda] #296380
04/23/09 03:00 PM
04/23/09 03:00 PM
scratchnfotraction Offline
Re: changed posi , now gears make lots of noise! [Re: scratchnfotraction] #296381
04/25/09 11:37 AM
04/25/09 11:37 AM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
the yoke was loose!
that could be why the gears made so much noise.
what should it be torqued to? 741 case course spline?
Re: changed posi , now gears make lots of noise! [Re: dirt] #296382
04/25/09 02:02 PM
04/25/09 02:02 PM
Retired now in Tennessee
Chi_Town_Runner Offline
Posted above:
On the 741 and 742 case (thanks to Dr. Diff), the pinion nut should be torqued to 140 ftlbs on a 10 spline
Frank
Re: changed posi , now gears make lots of noise! [Re: Chi_Town_Runner] #296383
04/25/09 07:18 PM
04/25/09 07:18 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
Its tightened up now, rebuilt the suregrip and took it for a test drive and it worked great. 2 of the disc were broke in the suregrip.
it spins both tires and is quiet again.
