changed posi , now gears make lots of noise! #296356
04/22/09 02:49 PM
04/22/09 02:49 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
I had a shop change out my posi unit in my 8 3/4 center section. they were quiet when i dropped them off, just didnt spin both tires, now they are loud. they roar so much you have to talk loud in the car to the other person so they hear you.
i pulled them back out and i am not sure what he did. I have only set up one set of gears and they were not noisy at all.
It is a 741 case 3.91 gears, I cant remember if i had him change the yoke or not but it seems a little loose, the yoke and pinion gear has some play in and out. I didnt think there should be any play there is that right?
I am rebuilding the clutch type posi unit to put back in it and want to fix the noise while i am at it. I have some gear grease ordered to check the pattern.
any ideas?
Re: changed posi , now gears make lots of noise! [Re: dirt] #296357
04/22/09 02:54 PM
04/22/09 02:54 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
If it wasn't noisy before it shouldn't be now. Get them to reset it up right. If you wait you won't be able to get it quiet again. There was no reason for them to take the pinion out, all that needed to be removed is the ring gear and the backlash reset.
Re: changed posi , now gears make lots of noise! [Re: MoparforLife] #296358
04/22/09 03:14 PM
04/22/09 03:14 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Pinion should be tight, no slack. Like said above you don't need to mess with the pinion to remove/replace the sure grip.
Re: changed posi , now gears make lots of noise! [Re: 69Cuda340S] #296359
04/22/09 03:24 PM
04/22/09 03:24 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
It was 10 years ago and i am just now getting around to reusing it. i only put about 60 miles on it since the shop worked on it.
what would you torque the pinion bolt to?
I may have had him swap the yoke , that would be the only reason to mess with the pinion nut.
I should be able to torque the pinion nut down and set the lash and it should be good i would think,I remember him telling me he had to change the carrier bearings when he installed the other posi unit. but they were supposed to have been new.
what would you set the lash at for used 3.91 gears?
Re: changed posi , now gears make lots of noise! [Re: dirt] #296360
04/22/09 03:43 PM
04/22/09 03:43 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Just to clear up the terms a little. Chrysler uses the name suregrip. GM is a posi. Some folks get upset when you use a chevy name for a Mopar rearend.
Re: changed posi , now gears make lots of noise! [Re: dirt] #296361
04/22/09 03:53 PM
04/22/09 03:53 PM
California
P
polkat Offline
mopar addict
polkat  Offline
mopar addict
P
California
Some 8-3/4" pinions (sorry, I don't remember which) used a crush sleeve between the pinion races as a sort of adjustable spacer. If the old crush sleeve is reused, it is possible to reach the required torque on the pinion nut (I think it is 185 ftlbs) and still have a loose pinion. For a good discussion of setup see this website:
http://www.moparmusclemagazine.com/howto/mopp_0308_mopar_rear_end_gears_set_up/index.html
Re: changed posi , now gears make lots of noise! [Re: polkat] #296362
04/22/09 04:09 PM
04/22/09 04:09 PM
Western NC
68Bullit Offline
68Bullit  Offline
Western NC
Man I sold a 741 case 3.91 posi that howled pretty bad. It was a good unit as far as I know, and never put any metal in the gear oil, nor did it have any sharp teeth (and I put WELL over 2000 miles on it). I've heard of many of these same cases with the 3.91 gearset that many people say were fine but just howled and were very loud. It's interesting that it didn't start until you removed the old posi for a good working one. FWIW, I'd say the guy set it up correctly
Re: changed posi , now gears make lots of noise! [Re: polkat] #296363
04/22/09 04:13 PM
04/22/09 04:13 PM
Retired now in Tennessee
Chi_Town_Runner Offline
It all depends on the case.
First, only the 489 case used the crush sleeve. The 741 and 742 cases used shim packs to set the pinion depth. On the 741 and 742 case (thanks to Dr. Diff), the pinion nut should be torqued to 140 ftlbs on a 10 spline and 280 ftlbs on a 23 spline.
There should be no play on the pinion. Take it out before you drive it any further and take it back to the guy who built it. The growl you hear could be the rear end eating itself up.
Good Luck,
Frank
Remember - 2 wrongs don't make a right - but 3 rights make a left!
Re: changed posi , now gears make lots of noise! [Re: Chi_Town_Runner] #296364
04/22/09 04:18 PM
04/22/09 04:18 PM
Upper Midwest
Upper Midwest
FWIW I haave a 4.56 set in a 489 case that is set up right with proper backlash and the pattern is a s near perfect as it can get but you can here it above open headers. It still looks good after several seasons. These gears were that way from day 1 new.
But the point of this poster is is that the gears weren't noisy before but they are after the sure grip switch. This shouldn't be.
Re: changed posi , now gears make lots of noise! [Re: 68Bullit] #296365
04/22/09 04:38 PM
04/22/09 04:38 PM
A Banana Republic near you.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
I have 3.91's in my dart , factory gear set,they do not howl , even with the metal particle laced oil because of the POS cone type sure grip .
Did you read all he posted , the pinion is LOOSE , how can you think it's set up correctly if the pinion is loose ?
Re: changed posi , now gears make lots of noise! [Re: JohnRR] #296366
04/22/09 04:58 PM
04/22/09 04:58 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
I run 3:91 gears in a 489 case and they don't make any noise.
And yes the fact that it has slack in the pinion bearings is an issue. If retorquing the nut does not fix it it needs to come apart. No crush sleeve in a 741 case, only the 489 had a crush sleeve.
Re: changed posi , now gears make lots of noise! [Re: JohnRR] #296367
04/22/09 05:25 PM
04/22/09 05:25 PM
Western NC
68Bullit Offline
68Bullit  Offline
Western NC
"Seems" loose, and "some play" are references that the OP used IIRC.
Yeah, I did read all that he posted, and if you would read all of the entire thread you would see that there is uncertainty whether or not the yoke was even removed or not. The problem started after a working posi was installed, NOT before. No, it doesn't sound right that the yoke is loose, obviously. So, why have other units that were setup entirely correctly howled and made noises similar to what the OP described? That was merely what I was trying to point out.
Re: changed posi , now gears make lots of noise! [Re: stumpy] #296368
04/22/09 07:04 PM
04/22/09 07:04 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
In 1966 Dodge called the clutch type LS in my 66 Coronet a "Power Lock"
Re: changed posi , now gears make lots of noise! [Re: JohnRR] #296369
04/22/09 07:20 PM
04/22/09 07:20 PM
Upper Midwest
Upper Midwest
John I too read is post and the previous posts. That is why I made the far previous statement that there should have been no need to take out the pinion to install the sure grip (if it was or is indeed loose), also made the statement that something was misassembled if it was quiet before and not after, and to get it set up right before driving it and a new wear pattern is established and the noise is irreversable. Again I repeat - But that being that these were quiet they need attention. ASAP.
Re: changed posi , now gears make lots of noise! [Re: MoparforLife] #296370
04/22/09 09:40 PM
04/22/09 09:40 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
OK
Unless the bearings have failed, there wasn't enough preload when they changed the yolk(if that was done. The original poster isn't sure)
Remove shims( a little at a time) from behind the outer pinion bearing, and retorque the nut until it has preload again.
Drive it, and see if the noise is gone. Hopefully it is.
If the noise is stil present, it may already be beyond help.
The proper way to install a sure grip carrier on a used set of gears, is ...
1)Measure AND RECORD the backlash setting
2)remove the carrier assembly with the ring gear on it.
3)transfer ring gear to sure grip carrier
4)install new sure grip and gear into center chunk
5)use the adjusters to get the backlash EXACTLY the same as was.
If it's not, the pattern is now off, and it will be noisy.
By not changing pinion depth, and putting the backlash where it was, the original pattern is still intact.
If this procedure wasn't followed, Setting it up, may help, but a worn gear set needs to maintain it's existing pattern to not be noisy. A new pattern means noise.
Pinion depth, should not have been messed with. If the guy who changed the yolk decided to change the depth, and set the pattern up fresh from what it was, it is screwwed, and will always be noisy
Re: changed posi , now gears make lots of noise! [Re: dave571] #296371
04/22/09 10:40 PM
04/22/09 10:40 PM
scratchnfotraction Offline
with stumpy
right there is your prob
you gots a posi were a suregrip should be and its making noise now
sorry,I could not help not saying it
give doctordiff a call he will fix it
Re: changed posi , now gears make lots of noise! [Re: scratchnfotraction] #296372
04/22/09 11:32 PM
04/22/09 11:32 PM
Arkansas
K
kzcountry Offline
kzcountry  Offline
K
Arkansas
with stumpy
I agree give Doctordiff a call. He will make it right. I just got my 489 case back yesterday, it had a howl and now quiet as can be.
Re: changed posi , now gears make lots of noise! [Re: kzcountry] #296373
04/23/09 07:45 AM
04/23/09 07:45 AM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
i did call dr diff, he is sending me a rebuild kit for one of my posi, i mean suregrip units.
I am going to try to set it up myself first and see if it fixes it.
I never knew that posi was a chevy term. everyone around here uses it for any brand of car.
Re: changed posi , now gears make lots of noise! [Re: scratchnfotraction] #296374
04/23/09 08:41 AM
04/23/09 08:41 AM
with stumpy
Life is good
Re: changed posi , now gears make lots of noise! [Re: dirt] #296375
04/23/09 09:26 AM
04/23/09 09:26 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Posi has become a generic term, like Allen wrench or Crescent wrench.
Technically, Spicer sourced Powr-Lok (Power-lock) traction differentials were used from '57-'68 in Mopar 8 3/4" rears. Chrysler called these Sure-Grip.
Powr-Loks were also used from '57-'64 in Chevy passenger car rears. Chevy caled these Posi.
