90 degree oil filter adapter small block #2963560
09/13/21 11:25 AM
09/13/21 11:25 AM
St. Louis, MO
moparbuff Offline OP
St. Louis, MO
Later versions have two”fingers” coming from the housing. What ii their purpose?
Re: 90 degree oil filter adapter small block [Re: moparbuff] #2963562
09/13/21 11:31 AM
09/13/21 11:31 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
They align on a tab cast into the block.
Re: 90 degree oil filter adapter small block [Re: Sniper] #2963687
09/13/21 03:31 PM
09/13/21 03:31 PM
Lombard, IL
rictek Offline
rictek  Offline
Lombard, IL
They don't align with anything on a 360 block so I drilled and tapped a hole between the fingers for a 10-32 capscrew.
It keeps the oil adapter from turning, loosening the big bolt in the center and causing a leak.
71 Charger R/T
70 Duster 340
12 Ram Express
Re: 90 degree oil filter adapter small block [Re: rictek] #2964591
09/15/21 11:25 PM
09/15/21 11:25 PM
5thAve Offline
5thAve  Offline
I think my 360 had something cast there but it was a different spot then where the 318 had it so I put it on roughly angled the way it was on the 318. 22 years later still no leak so I did something right.
