72-93 bench seat questions
#2963153
09/12/21 02:00 AM
09/12/21 02:00 AM
Posts: 20,643 in a cattle trailer down by th...
Guitar Jones
I'm looking to buy seat upholstery for the rear seat in my 74 crew cab. I have 93 Ram Charger seats in the front. I would like to match the style with the fronts so I'm wondering if the rear bench is the same basic size and shape as the front bench seat in the later years. I don't have anything to compare it to as the RC didn't have a rear seat in it when I bought it and my 92 has buckets in it also. I can buy kits for front and rear seats of a RC but aren't the RC rear seats smaller than a front bench seat? TIA.
Re: 72-93 bench seat questions
[Re: NITROUSN]
#2963287
09/12/21 04:36 PM
09/12/21 04:36 PM
Posts: 5,887 ohio
ruderunner
ohio
Even easier. Go to Stockinteriors.com. and check out covers for 79 to 83 Dodge trucks. The bench seat cover will fit the crewcab bench. One section wraps around differently than the original design but it's invisible and pretty self explanatory.. Then check their listing for Ramcharger buckets. They probably offer matching material for both sets.
Matching seat covers for mismatched seats doesn't get any easier.
Also, go ahead and order carpet, strongly recommend the mass backing for noise reduction.
Angry white pureblood male
[Re: Guitar Jones]
#2963323
09/12/21 06:03 PM
09/12/21 06:03 PM
Posts: 2,115 Byron, NY
W.I.N. Racing
Byron, NY
The rear bench in a crew cab is the same as a regular cab seat (unfinished on the back of the seat). The Crew cab front seat back was a full cover (front and back of seat). Since they pretty much used the same material fro D/W series and RC you should be able to just get Front seat coves adn a std cab rear cover.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#2963341
09/12/21 06:36 PM
09/12/21 06:36 PM
Guitar Jones
Thank you guys for the info, but I'm not putting carpet in this truck. It is used off road and in the winter around here so it would be trashed anyway. I have a really nice interior in my '92, new carpet headliner, etc., but can't seam to stop the water leaks. I'm to the point now where I have slowed it down but not stopped it. The unavailability of vent window seals is a major hurdle. I don't use this truck off road or in the winter mainly because it will get stuck on wet grass, but it is fine in the nicer seasons to pull my trailer and make grocery and hardware store runs, and the A/C works great.
[Re: Guitar Jones]
#2967672
09/26/21 11:50 PM
09/26/21 11:50 PM
Posts: 516 ND
dodgedon
ND
I had an 85 crew cab. I installed 90 Ramcharger seats in the front. They were that grey fuzzy type material (Factory). I then went back to the salvage and found the same seat material in a 93 D150 standard cab pickup. Bought the whole seat and installed it in the rear of the crew cab.. Both seats were really nice condition and matched each other perfectly. I may have a picture here yet too
67 Charger 383 auto 75 Dodge CNT 800 CAT Diesel 2012 Ram Crew cab 5.7 4x4
[Re: dodgedon]
#2968261
09/28/21 09:53 PM
09/28/21 09:53 PM
Guitar Jones
That looks nice. I just bought a new seat cover for the rear. Went right on and looks pretty good, I'm happy with it.
