Re: Fuel in oil.
[Re: Greenwood]
#2962992
09/11/21 02:21 PM
09/11/21 02:21 PM
Posts: 1,363 Out of the State of Confusion
blue_stocker
If you're concerned about compression, do a leak-down test and check your fuel system, especially if you have one of the cheap fuel regulators. I had one that had a leaky diaphragm that ended up with approx 1 qrt of race fuel in my crankcase. The day before going to a test session I had a very hard start and even though I kept smelling gas, I hadn't done basic inspection (look down the throttle bores with the electric pump running) and almost hydrauliced (sic?) a cylinder. The next day I noticed bubbles coming out of the front corner of the oil pan (crankcase pressure) and oil on the trailer deck! So much for that test session, back to the shop! The following day I drained the oil and noticed not only the strong odor of fuel but it was also diluted with gas in the oil pan; glad I didn't make any passes on that fresh engine! Needless to say, I pulled the engine and discovered washed bearings, scuffed cylinder walls but saved myself a big bill from catastrophic engine failure...it's always the little things. Not saying anything about your situation other than, make sure of what you do know so it doesn't bite you!
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them. Thomas Jefferson
Freedom must be repurchased by every new generation General Daniel Jones, WW2 Tuskegee Airmen
Re: Fuel in oil.
[Re: Greenwood]
#2963005
09/11/21 03:03 PM
09/11/21 03:03 PM
Posts: 14,504 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The jetting seems kinda big for a 780 Holley.
If you have a mechanical pump, I’d could have a diaphragm that’s failing and letting fuel pass through it.
If electric, what’s the pressure set at?
Re: Fuel in oil.
[Re: fast68plymouth]
#2963068
09/11/21 07:02 PM
09/11/21 07:02 PM
Posts: 343 Red Deer, Alberta
Greenwood
Red Deer, Alberta
Electric pump. 7-8 psi.
Re: Fuel in oil.
[Re: Greenwood]
#2963082
09/11/21 07:37 PM
09/11/21 07:37 PM
Posts: 1,824 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
Electric pump. 7-8 psi. Drop it to 5.5 to 6psi. Secondaries seem too rich. Check your #5;6,7,8 plugs
