928 ways to lose at bracket racing
#2962956
09/11/21 01:18 PM
09/11/21 01:18 PM
Posts: 34,933 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
When your opponent loses his harmonic balancer, it hits your car .. starter thinks it comes off your car and shuts you off at the line ..
I have more, add yours
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: 928 ways to lose at bracket racing
[Re: A/MP]
#2962986
09/11/21 02:06 PM
09/11/21 02:06 PM
Posts: 20,192 Park Forest, IL
slantzilla
Park Forest, IL
Went to the Twin 10K race at 41 last year. Ran the Blind Squirrel race Friday night, car ran great. Unloaded Saturday morning and warmed the car up. Get the call for our only time shot and head to staging. Shut the car of and get my belts and helmet on. Fire the car to pull up and the trans now has all neutrals. Broke the lugs off the pump gear.
Hoping for better luck this year.
[Re: bigdad]
#2963002
09/11/21 02:50 PM
09/11/21 02:50 PM
Posts: 5,991 Anoka County, MN
Leigh
Anoka County, MN
Neutral safety switch harness boot got hard, and would wiggle loose. I added a ground wire while waiting for the replacement harness. Got the call for my round, car won’t crank. I use the aforementioned external ground, and cranked the car reaching in from the outside. Oops, neutral wiring is fine, THE CAR WAS IN GEAR. Fortunately, it only went driverless for 10 feet and didn’t hit anything.
[Re: dvw]
#2963066
09/11/21 06:55 PM
09/11/21 06:55 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
Used to run Ram puck style disc and came out of the water a little hot and a piece of the sintered bronze disc jammed between the plate and disc. Car stuck in gear and no clutch pedal. Had to abort start and lost going into third round after having near perfect runs in the first 2 rounds. Stopped using a Ram puck style disc Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: bigdad]
#2963071
09/11/21 07:11 PM
09/11/21 07:11 PM
Posts: 1,113 Usa
A39Coronet
Usa
Twice in one weekend in Ohio...missed a dial in board error, and next day misread my TT ticket and dialed a tenth off.
[Re: A39Coronet]
#2963105
09/11/21 08:47 PM
09/11/21 08:47 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
Not me but a good friend of mine has run out of the gas in the final more than once!
68 Barracuda Formula S 340
[Re: Bad340fish]
#2963134
09/11/21 11:16 PM
09/11/21 11:16 PM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
red light ....... .0004 4th number
[Re: jwb123]
#2963141
09/12/21 12:37 AM
09/12/21 12:37 AM
Posts: 3,089 Michigan
A727Tflite
Final for a $2,000.00 purse. My opponent's car would not start when it cam time to do the burn out. So being the sportsman, I told his pit crew to get it going, they jumped it and it fired. I reached up and hit my start switch, Click , click, The guy shrugged his shoulders and pulled into the burnout box. Seen this happen way too many times. Nice guys always seem to take it in the shorts. But when it works to your favor you can stand even taller.
[Re: bigdad]
#2963537
09/13/21 10:37 AM
09/13/21 10:37 AM
Posts: 1,365 Out of the State of Confusion
blue_stocker
How about...having gone 3 rounds at Pomona in class eliminations, meeting up with the slowest car in the class and having him covered by +.3, cut the light and have him by a car length at the tree and pulling only to shift into 4th and have the rear u-joint fail and roll the drive shaft...he passes at the 1st mph light and BING, you lost! That being the pits, same car goes into the finals for an Eliminator runner-up...GRRR!!!! Hahaha, that's racing!
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them. Thomas Jefferson
Freedom must be repurchased by every new generation General Daniel Jones, WW2 Tuskegee Airmen
[Re: bigdad]
#2963583
09/13/21 12:23 PM
09/13/21 12:23 PM
Posts: 43,237 Bend,OR USA
Cab_Burge
I have more, add yours I am sure there are closer to 10,000 ways to lose a drag race I'm up to # 8999,, I think
