904 Transmission #2962659
09/10/21 09:41 AM
09/10/21 09:41 AM
ontario canada
426lloyd Offline OP
426lloyd  Offline OP
ontario canada
Can a 904 cracked case which is a lockup , can the internals be transferred to a non lockup case .
Re: 904 Transmission [Re: 426lloyd] #2963345
09/12/21 06:46 PM
09/12/21 06:46 PM
ontario canada
426lloyd Offline OP
426lloyd  Offline OP
ontario canada
Anyone
Re: 904 Transmission [Re: 426lloyd] #2963380
09/12/21 08:02 PM
09/12/21 08:02 PM
A727Tflite Offline
A727Tflite  Offline
Pump to output should transfer over.
The main difference between LU and Non LU is the pump, input shaft and valve body.
If you are moving a LU unit over to the non and it’s an electronic LU you will need to drill for the bulkhead connector. It’s under the extension housing in the main case.
