Underhoist Support Jacks #2962314
09/08/21 08:27 PM
09/08/21 08:27 PM
North Dakota
6PakBee Offline OP
6PakBee  Offline OP
North Dakota
I've been looking at the HF 2 ton underhoist safety jacks.
Underhoist Jack
When I looked at them in the store they looked a little chintzy to me. Does anyone have any recommendations as to alternatives? I'm more concerned with quality than price. If a vehicle comes off the lift, I don't move as fast as I used to.
Re: Underhoist Support Jacks [Re: 6PakBee] #2962317
09/08/21 08:35 PM
09/08/21 08:35 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
I have one of these. Probably not what you are looking for.
Re: Underhoist Support Jacks [Re: Dabee] #2962330
09/08/21 09:20 PM
09/08/21 09:20 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I have two of those and see no issues with them.
Re: Underhoist Support Jacks [Re: Dabee] #2962338
09/08/21 09:58 PM
09/08/21 09:58 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
My buddy has one of those lifts at his shop. It doesn't [censored] the best, but it will lift a vehicle off the hoist pads. I've seen them chain a truck frame onto the hoist and compress a coil spring.
Mostly what they use theirs for is support under the rear axle when they put an extended cab truck on the hoist. They make working under those big loads feel a bit safer.
Re: Underhoist Support Jacks [Re: Dabee] #2962363
09/09/21 12:39 AM
09/09/21 12:39 AM
North Dakota
6PakBee Offline OP
6PakBee  Offline OP
North Dakota
What you got?
Re: Underhoist Support Jacks [Re: 6PakBee] #2962598
09/09/21 09:06 PM
09/09/21 09:06 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
IMO they're meant to stabilize the car from rocking while on the lift not support it. So they are probably fine. But I'm sure you can find more expensive versions twocents
Re: Underhoist Support Jacks [Re: 6PakBee] #2962624
09/09/21 10:42 PM
09/09/21 10:42 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
What you got?
Sorry Had a brain fart and forgot to attach the link.
https://norcoindustries.com/product...ist-air-hydraulic-transmission-jack.html
Re: Underhoist Support Jacks [Re: Dabee] #2962631
09/09/21 11:31 PM
09/09/21 11:31 PM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
What you got?
You realize that is not the same thing as what the OP was talking about
Re: Underhoist Support Jacks [Re: 6PakBee] #2962636
09/10/21 02:36 AM
09/10/21 02:36 AM
I've seen those use to hold up a transmission tail shaft so they could remove the cross member to replace the tranny mounts, work good up
Re: Underhoist Support Jacks [Re: Cab_Burge] #2962666
09/10/21 10:12 AM
09/10/21 10:12 AM
North Dakota
6PakBee Offline OP
6PakBee  Offline OP
North Dakota
Thanks for all the comments. up I guess if I get the HF version and I don't like something, that's what a welder, drill press, and bandsaw are for.
Re: Underhoist Support Jacks [Re: Sniper] #2962693
09/10/21 11:55 AM
09/10/21 11:55 AM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
What you got?
Read my original post I wrote “probably not what you are looking for” shruggy
