Should Ballast Resister be bypassed or not? MSD #2961070
09/04/21 09:35 PM
09/04/21 09:35 PM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
My 66 Satellite with a good 440 runs very well, it has an MSD ignition installed by previous owner. In the paperwork it says to bypass ballast. Is that the norm to do? This is a working and running combination so before I do figured I'd ask.
I measured it has one in it that reads 1.9 ohms and thought since the stock point type one is only .5 or so would that be better or just gut the back of it as I've done with other ignitions and solder a 10-12ga. wire behind.
Thanks Ron
Re: Should Ballast Resister be bypassed or not? MSD [Re: RJS] #2961107
09/04/21 11:53 PM
09/04/21 11:53 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
I’ve never left the ballast resistor on any of my MSD installations.
Re: Should Ballast Resister be bypassed or not? MSD [Re: Blusmbl] #2961115
09/05/21 12:19 AM
09/05/21 12:19 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Depends on your coil.
I want my fair share
Re: Should Ballast Resister be bypassed or not? MSD [Re: SomeCarGuy] #2961119
09/05/21 12:44 AM
09/05/21 12:44 AM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Need to bee more specific when you say MSD Ignition
As in
MSD Distributor ? Or
MSD Ignition Box ? Or
MSD Coil ? Or
All of the above
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Should Ballast Resister be bypassed or not? MSD [Re: RJS] #2961128
09/05/21 03:18 AM
09/05/21 03:18 AM
All the MSD race and street ignitions that I've used , 404B to digital 7 non programable with a grid ,require you to eliminate the 12V resistor to the coil scope
The box controls the voltage pulse duration and voltage (WAY higher than 12.25V) to the coil for the multi spark feature scope
DON'T ask me how I know about the voltage to the coils whiney
Re: Should Ballast Resister be bypassed or not? MSD [Re: Cab_Burge] #2961154
09/05/21 08:03 AM
09/05/21 08:03 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
in my opinion this may be one of those "depends" questions. i don't use msd ignitions so my comments may only be relevant to a point. i have used ignition boxes were bypassing the ballast resister was either required or recommended. i never liked the way my engines ran without some resistance in the system. i'm not sure there was ever a performance advantage in my application by bypassing the resister. i know that measuring voltage at the coil with out the resister was pretty high,14-15+ volts using a good coil, your charging system should be checked for voltage output. i use an msd resister, .8 ohm, and have had good luck with them and the engine runs much smoother. i think 1.9 ohms is too much resistance. you may be getting less than 6 volts to the coil. i'm getting 10-11 volts with the msd resister. i'd try the msd resister first and if there's an improvement then take another step to no resister and see how you like that. another thing i'd do is measure plug wire resistance and plug resistance; that all stacks up. an msd requires some resistance. some prefer to put the resistance in the plug wires and plugs.
Re: Should Ballast Resister be bypassed or not? MSD [Re: lewtot184] #2961166
09/05/21 09:26 AM
09/05/21 09:26 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
MSD boxes use battery power so no ballast's are used. It would not hurt to list what specific box/set up you have.
Re: Should Ballast Resister be bypassed or not? MSD [Re: Moparite] #2961180
09/05/21 10:16 AM
09/05/21 10:16 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Try reading the installation instructions.
As far as the coil is concerned, the ballast resister circuit is no longer in play when using an MSD box. The coil gets energized directly from the box and with a 6AL IIRC the capacitor discharges 480 volts to the coil.
I suspect Cab has some first hand personal knowledge about this. eek
Kevin
Re: Should Ballast Resister be bypassed or not? MSD [Re: Moparite] #2961184
09/05/21 10:27 AM
09/05/21 10:27 AM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
OK did some more reading on this myself and know the direction I'm headed but to fill in the blanks:
MSD 6A,
MSD Blaster2 coil,
MSD spiral core wires.
The distributor itself is an MP electronic.
Reading my paperwork a few times I see it says no Ballast is needed (makes sense) but it also said you can leave the stock ballast. Reading about the coil it stated no Ballast needed so I guess they are saying if you are using all of our system remove ballast for our coil to work properly but you can also run this system with a stock coil and then the ballast can stay.
This was an existing set-up put in by previous owner so I would have thought any problems would have arisen already with this Ballast in place.
I am going to bypass it and test from there.
Thanks Ron
Re: Should Ballast Resister be bypassed or not? MSD [Re: RJS] #2961226
09/05/21 12:33 PM
09/05/21 12:33 PM
AndyF Offline
AndyF  Offline
You should be able to figure it out by looking at how your system is wired. If the ballast resistor is just dropping the voltage to the MSD ignition box then it is hurting your performance and it probably isn't extending the life of the MSD box. The ballast resistor was originally designed to protect the points. It was then repurposed in the ECU era to protect the life of the coil. Look at how the last guy wired the ignition in your car. Does the coil get its voltage from the ballast resistor or is it coming from the MSD box?
You have to actually study how the system before you'll know what the last guy did. He might have bypassed the ballast but just left it there or perhaps he didn't read the instructions and he actually wired it up so the MSD box isn't receiving a full 12 volts. Anything is possible when dealing with backyard mechanics.
Re: Should Ballast Resister be bypassed or not? MSD [Re: AndyF] #2961234
09/05/21 12:54 PM
09/05/21 12:54 PM
N
NITROUSN Offline
NITROUSN  Offline
N
As far as I know the MSD box it drawing all power from the large wires they want going to the battery. The small wire is just a trigger source to activate the box. It will trigger off very low voltage so it really does not matter if you hace a resistor or not. I would prefer a direct battery voltage trigger.
Re: Should Ballast Resister be bypassed or not? MSD [Re: NITROUSN] #2961263
09/05/21 03:04 PM
09/05/21 03:04 PM
AndyF Offline
AndyF  Offline
OP didn't post any pictures or describe what the ballast resistor was doing so we're just guessing. The car would be wired with the ballast resistor in the power circuit for all we know.
Re: Should Ballast Resister be bypassed or not? MSD [Re: AndyF] #2961292
09/05/21 05:25 PM
09/05/21 05:25 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
No ballast with MSD stuff.
Re: Should Ballast Resister be bypassed or not? MSD [Re: CMcAllister] #2961343
09/05/21 07:59 PM
09/05/21 07:59 PM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
No the system is stand alone, the MSD goes straight to bat+ at starter solenoid and is grounded to the engine block. The dist. leads go right to the dist. and the the orange and black go to the coil so i would have to say the ballast isn't hurting anything as it is or am I incorrect on that?
Ron
Re: Should Ballast Resister be bypassed or not? MSD [Re: RJS] #2961351
09/05/21 08:13 PM
09/05/21 08:13 PM
Rittman Ohio
fourgearsavoy Online tonguue
fourgearsavoy  Online Tonguue
Rittman Ohio
It sounds like what some guys like to leave all the factory wiring installed just in case the MSD failed. You are correct in your description that is sounds like it's wired as a stand alone unit. You should be fine the way it's wired as long as you keep the connections clean and tight. loose or dirty connections are what kills MSD boxes twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: Should Ballast Resister be bypassed or not? MSD [Re: RJS] #2961354
09/05/21 08:22 PM
09/05/21 08:22 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Ron
Unless MSD has changed their install instructions, the big black and red wires go DIRECTLY to the battery. I'm surprised it runs if you have it wired otherwise as I've seen it happen.
The wire that normally goes to the + on the coil is what is usually used to signal the on/off wire to the MSD box and that is why you need to bypass the ballast resister so that signal wire sees 12V.
Kevin
Re: Should Ballast Resister be bypassed or not? MSD [Re: RJS] #2961392
09/05/21 09:23 PM
09/05/21 09:23 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
MSD6AL 2
Ballast Resistor: If your vehicle has a ballast resistor in-line with the coil wiring, it is recommended to bypass it
That’s why I was asking what box you where running or what/all components
So another words you want a full 12-14.5 Volts to the positive side of your Blaster 2 Coil with the engine running using the MSD6AL Box
Peace
Siberian Huskies
Re: Should Ballast Resister be bypassed or not? MSD [Re: Twostick] #2961398
09/05/21 09:30 PM
09/05/21 09:30 PM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
Ron
Kevin
In all my years this is the first car I have with an MSD so pardon my ignorance. But isn't having the large RED to the starter solenoid the same as running it to the battery terminal? I have the large BLACK to engine block and also a jumper from there to firewall.
The one wire I forgot to talk about is the small RED which I guess is the trigger you guys were speaking of and yes that goes to the blue wire that used to go to + at coil. So is that why it's best to jump the ballast resister?
Thanks Ron
Re: Should Ballast Resister be bypassed or not? MSD [Re: Twostick] #2961399
09/05/21 09:30 PM
09/05/21 09:30 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Ron
Kevin
X2
Siberian Huskies
Re: Should Ballast Resister be bypassed or not? MSD [Re: bee1971] #2961401
09/05/21 09:34 PM
09/05/21 09:34 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Orange
This wire connects to the coil positive (+) terminal. This is the ONLY wire that makes electrical contact with the positive coil terminal.
Is this wire directly going to the positive side of the coil ? Make sure this is the only wire
Siberian Huskies
