93 D350 Cummins W/Overdrive Issues ??? #2961114
09/05/21 12:13 AM
09/05/21 12:13 AM
Louisville, KY
E
E-Ticket Offline OP
E-Ticket  Offline OP
E
Louisville, KY
OK, so, I went through several pages on this truck forum and only found one question regarding the OD transmissions but didn't really apply to my question.
The truck is a 93 D350, Cummins, 2WD with an OD trans. When the OD doesn't work, is it alright to wire the switch to stay activated ??? I've driven the truck with the switch wired/bypassed and it seems to be alright that way ??? Before we wired it direct to stay on ... the trans would buck & kick like it couldn't see the signal to go in overdrive ?? I've occasionally seen posts regarding the OD on this era of truck but never paid any attention to the details because I've mostly had stick trucks ...
Thx in advance ... up
"Fat drunk and stupid is no way to go through life son......"
http://www.youtube.com/watch?v=bK-Dqj4fHmM
Re: 93 D350 Cummins W/Overdrive Issues ??? [Re: E-Ticket] #2961124
09/05/21 02:39 AM
09/05/21 02:39 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
On my 92 I got tired of changing out the od switch ($100 if I remember right and didn’t last long) so I put an on off switch on the gear selector arm, I’d cut it off once truck gets back to a stop turn back on once it was in third. Never any issues with shifting
Re: 93 D350 Cummins W/Overdrive Issues ??? [Re: cudaman1969] #2961126
09/05/21 03:04 AM
09/05/21 03:04 AM
Louisville, KY
E
E-Ticket Offline OP
E-Ticket  Offline OP
E
Louisville, KY
[Sort of what we did to see if it would drive out like that but went through the button on the dash to stay on all the time when driving and no problems. My concern is for long-term driving on trips of 500 - 1000 miles and so ??
quote=cudaman1969]On my 92 I got tired of changing out the od switch ($100 if I remember right and didn’t last long) so I put an on off switch on the gear selector arm, I’d cut it off once truck gets back to a stop turn back on once it was in third. Never any issues with shifting [/quote]
Re: 93 D350 Cummins W/Overdrive Issues ??? [Re: E-Ticket] #2961152
09/05/21 07:56 AM
09/05/21 07:56 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
The factory dash switch is to turn off OD. It sends a signal to the computer to lock out OD.
You can indeed wire the solenoid for manual control. It won't hurt the transmission.
Angry white pureblood male
Re: 93 D350 Cummins W/Overdrive Issues ??? [Re: ruderunner] #2961176
09/05/21 10:03 AM
09/05/21 10:03 AM
Louisville, KY
E
E-Ticket Offline OP
E-Ticket  Offline OP
E
Louisville, KY
OK, thx ... That is my main concern. As long as we keep the switch on/wired to bypass and operating as an on/off switch, t seems to be alright.
Re: 93 D350 Cummins W/Overdrive Issues ??? [Re: E-Ticket] #2961208
09/05/21 11:34 AM
09/05/21 11:34 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
All the switch on the dash does is disconnect the ground(from the pcm when od is engaged) to keep it out of od. If you plan to use a switch just to supply a ground(not from the pcm) for the od to engage is another story. You will engage the od with the switch regardless of what gear you are in. Pcm engages and disengages the od as needed.
Re: 93 D350 Cummins W/Overdrive Issues ??? [Re: Moparite] #2961268
09/05/21 03:25 PM
09/05/21 03:25 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I ran it that way 7 years till it was sold became second nature like shifting a stick.
Re: 93 D350 Cummins W/Overdrive Issues ??? [Re: E-Ticket] #2961275
09/05/21 04:02 PM
09/05/21 04:02 PM
Guitar Jones Offline
It certainly won't hurt it, but it is a PITA. You have to turn it off if you want the trans to downshift and if you leave it on when coming to a stop it stays locked up, shudders and shakes until it shifts to first. 99% of the time O/D shifting hunting or inoperative conditions are caused by the TPS. Could also be a CKPS or a VSS. If it was a crank sensor though the A/C compressor won't kick on. If it's a VSS then the cruise won't work. I know the TPS isn't cheap but it isn't super expensive either. Geno's Garage carries them.
Re: 93 D350 Cummins W/Overdrive Issues ??? [Re: Guitar Jones] #2961462
09/06/21 06:48 AM
09/06/21 06:48 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
I don't think OD engagement will cause a shake, TCC will. Iirc the internal plumbing prevents OD engagement in first and second, the OD solenoid doesn't get pressurized oil until the transmission reaches 3rd gear. This seems like it effectively keeps the transmission a 3 speed but with a really wide spread between 2nd and OD as it basically would skip 3rd altogether.
Re: 93 D350 Cummins W/Overdrive Issues ??? [Re: ruderunner] #2961470
09/06/21 07:49 AM
09/06/21 07:49 AM
You are correct, mine has lockup and I was thinking like that.
