Over sized 727 yoke bushing needed #2960372
09/02/21 05:32 PM
09/02/21 05:32 PM
East Brunswick New Jersey
N
NoFrills Offline OP
NoFrills  Offline OP
N
I am looking for a tighter slip yoke bushing or possibly a exact size bearing. I have a Doug nash it hat uses a standard 727 yoke and bushing. I had a bad vibration and the bushing walked out. Replaced it was tight pushing in but loose on the yoke. I thought the yoke might be to worn so bought a replacement and still feels loose. The tail shaft bearing is tight drive shaft has a good balance. It is going trough the traps at alot of rpm shaft is spinning over 11,000.
Re: Over sized 727 yoke bushing needed [Re: NoFrills] #2960382
09/02/21 06:12 PM
09/02/21 06:12 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I never heard of one. Maybe check your rear trans mount.
Re: Over sized 727 yoke bushing needed [Re: NoFrills] #2960383
09/02/21 06:15 PM
09/02/21 06:15 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
From a bad experience with out of balance driveshafts, the only company that can spin a shaft at the desired rpm is Mark Williams, as one example of my getting the SHAFT LOL, my Strange engineering shaft was only spun up to 500 rpm , thats as fast as they can spin them, after LOTS of wasted money I call MW & they solved my vibration problems & tailshaft bushing problems
Re: Over sized 727 yoke bushing needed [Re: CSK] #2960396
09/02/21 07:05 PM
09/02/21 07:05 PM
A727Tflite Offline
A727Tflite  Offline
11,000 rpm ?
Re: Over sized 727 yoke bushing needed [Re: A727Tflite] #2960408
09/02/21 07:36 PM
09/02/21 07:36 PM
N
NoFrills Offline OP
NoFrills  Offline OP
N
Sorry brain is not working right today it goes through the traps like 9500 rpm in 4th that is 1.2:1 so 7900 rpm and change not 11000
Re: Over sized 727 yoke bushing needed [Re: NoFrills] #2960628
09/03/21 12:29 PM
09/03/21 12:29 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
"Feel" varies with the individual, one man's too loose is another man's OK. Depending on how far the slip yoke extends from the bushing (leverage), it can feel like excessive play but isn't really.
Re: Over sized 727 yoke bushing needed [Re: NoFrills] #2960636
09/03/21 12:55 PM
09/03/21 12:55 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
A lot of Mopars have excessive play at the tail-shaft bushing with new bushings installed.
I researched, found and installed a Teflon coated bushing from a 4L60 in my 2004R trans. It also fits Mopar transmissions. I found them on ebay, but not at any of the normal parts houses. Once installed, the fit was perfect. I realize the bushing went into a 2004R, but my Mopar machinist buddy measured and verified it will fit in Mopar tail-shafts too, although it is just a fraction of an inch shorter.
https://www.ebay.com/itm/272938846373
Try one. It's an inexpensive fix for a common problem. I typically felt the slop when lightly on and off the gas when at freeway speed. This eliminated that.
Re: Over sized 727 yoke bushing needed [Re: CSK] #2960639
09/03/21 01:02 PM
09/03/21 01:02 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
This was an issue for me too. I just ordered a 4 inch bonded aluminum driveshaft with their forged yoke and 1350 joints from them. It wasn't cheap, but it's Critical Speed is nearly 10000 rpm.
Between the old Strange driveshaft and the chattering, clunking Eaton TruTrac being replaced with Dr Diff's new and improved TruTrac 2, I hope to have eliminated my mystery vibration that only occurred from 98 mph on up. My '68's driveshaft is pretty long to begin with.
Re: Over sized 727 yoke bushing needed [Re: jbc426] #2960744
09/03/21 06:52 PM
09/03/21 06:52 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Does that bushing have an oil feed hole at the top?
Re: Over sized 727 yoke bushing needed [Re: John_Kunkel] #2960803
09/03/21 10:00 PM
09/03/21 10:00 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
My thoughts too, also will the nylon wear the yoke?
Re: Over sized 727 yoke bushing needed [Re: John_Kunkel] #2960833
09/03/21 11:56 PM
09/03/21 11:56 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
No, it does not have an oil hole. It would be easy to drill one, but it may not need it. John, you would know if it a pressure fed or drip/weep hole. I can't imagine they would feed pressurized transmission fluid there. The replacement bronze bushings I got from the local parts store did not have oil holes in them, but the ones from Brewers do.
I'll be pulling mine apart to change the driveshaft, gears and differential, and will check for any unusual wear since I installed it last year. It still runs and feels much smoother.
Re: Over sized 727 yoke bushing needed [Re: jbc426] #2960985
09/04/21 03:38 PM
09/04/21 03:38 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The rear bushing is drip fed by the capillary effect of the fluid following the spine rib at the top of the tailhousing (red arrow in pic below). The long length of the TF tail (compared to others) makes lubrication back there a little more critical than other brands with shorter housings.
Re: Over sized 727 yoke bushing needed [Re: John_Kunkel] #2961523
09/06/21 11:28 AM
09/06/21 11:28 AM
moparx Offline
moparx  Offline
if one were to drill a hole in the nylon 4L60 bushing, would that work for lubrication needs of the slip yoke ?
beer
