Re: A-body torsion bar question
[Re: 1970RT]
#2960441
09/02/21 09:06 PM
09/02/21 09:06 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Kinda need to know your intended use.
For non drag use, ANYTHING under 1" dia is a waste of time and rather 70ish, IMO
Just hang around , there many others who originally saw the light on this topic.
Over a decade back, many here were concerned about the "harshness" of going to "HD V8" bars over stock, and that was soon found to be a zero concern.
[Re: 1970RT]
#2960455
09/02/21 09:23 PM
09/02/21 09:23 PM
Posts: 31,049 Oregon
AndyF
I was originally going to put a 340 in my Dart (original 225) and bought a pair of 892/893 small block torsion bars. I ended up changing my plans and am going with a 400 big block instead. In doing some research, I found that a stock 400 is about 95 lbs. heavier than a stock 340. However, my 400 will have aluminum heads. intake and water pump so it should be somewhat lighter. Do you think the 892/893 torsion bars will be O.K. or should I look for a pair of 894/895 383/440 bars? I used a set of 340 bars in my BB Duster. They worked great on the street and the car launched hard.
[Re: 1970RT]
#2960478
09/02/21 10:16 PM
09/02/21 10:16 PM
Posts: 43,223 Bend,OR USA
Cab_Burge
I kept the six cylinder bars in my old pump gas Duster with a 400 stoker 517 C.I. motor, they work fine for me but I'm a old time drag racer that doesn't like getting beat at the track or the street. It ran a best of 9.993 at 134.?? (CRS) MPH with the full 3.0 inch exhaust system on to the rear bumper with the air cleaner on weighing 3450 Lbs. with me in it on 10.x31x15 slicks on ten inch rims, it ran a bunch of 10.00 at 134.+ MPH on a set of M/T ET Street Radials on 12.0 inch rims also I am not a roundy round racer and I don't try to go around every corner faster than the other guys do
[Re: 1970RT]
#2960515
09/03/21 05:48 AM
09/03/21 05:48 AM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
I have PST 1.03" bars in my 451 (lowdeck) A-body. They feel great on the street, firm but not harsh. the 892/3 bars (0.89"?) were way too soft and the front end wallowed. The stiffer bars probably hamper the launch a little despite the Caltracs, but I don't do WOT on public roads anyway. If anyone is watching.
[Re: DrCharles]
#2960536
09/03/21 08:12 AM
09/03/21 08:12 AM
Posts: 43,575 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
I have PST 1.03" bars in my 451 (lowdeck) A-body. They feel great on the street, firm but not harsh. the 892/3 bars (0.89"?) were way too soft and the front end wallowed. The stiffer bars probably hamper the launch a little despite the Caltracs, but I don't do WOT on public roads anyway. If anyone is watching. The small block bars are .87 the big block are .89 and are 894-895. You can't get the .89 anymore, so the 1.03 are the only ones I can find available and are great especially if you have a full iron 440...
JB Rhinehart, Realist
A-Body's RULE!
[Re: Neil]
#2960695
09/03/21 03:36 PM
09/03/21 03:36 PM
Posts: 279 lino lakes, mn
Schultz62
lino lakes, mn
You can run even the smallish bars on your car. No worries. My old Dart had the 6cyl bars when I put in a 360/380 crate motor. Just cranked up the screws. Then when I sold the 6 cyl bars, and they sold within 5 minutes at a swap, I put in 340 bars I got new at the time from Chrysler. My bigger concern was the cradle. The thing was cracked around the lower bolting holes. The car would slide off an on ramp as the wheels changed degrees. p.s I had no front sway bar on my old Dart. It lifted the front tires marginally when leaving from a stoplight. That is after hitting the line loc to annialate the rear tires to get grip. Before taking off. 4 Speed.
[Re: Neil]
#2960826
09/03/21 11:22 PM
09/03/21 11:22 PM
Rhinodart
Rhinotruck
Rhinotruck
That would work if they were IN STOCK! A buddy got a hole of me for some big block bars, and I told him to go to Firm Feel. They said no problem in 6-8 weeks, and that was last year, he is still waiting...
A-Body's RULE!
[Re: Rhinodart]
#2960884
09/04/21 09:10 AM
09/04/21 09:10 AM
Posts: 1,520 West Palm Beach, Florida
Copper Dart
For what it's worth and for what you're paying for , I swapped a bone stock 273/904 2 bbl iron manifolds a/c p/s etc. I installed a 440/727 with aluminum water pump housing, water pump, intake manifold, cylinder heads removed the a/c system up to the firewall and im running headers of course. I did not touch the torsion bar settings and the front end of my '67 Satellite was noticeably higher than before the swap. I dont know the difference in weight but i can imagine it must be substantial to be a visible difference, kinda like when my overweight date gets out and my tires dont rub anymore noticeable lol. Copper
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
