Needing help picking out fuel lines for my Fi Set up #2959505
08/31/21 01:57 PM
08/31/21 01:57 PM
eastern,Ky
70RT Charger Offline OP
eastern,Ky
Just got my complete Holley Sniper X Flow set up for my 70 Charger RT from FASTMAN, just waiting on my Distributor. He recommended 3/8 hardlines front and back as I’m running an in tank pump. So I’m wondering can SS factory bent main line work and also for my return or do I need to do something different? Any help would be appreciated. Thanks!
Re: Needing help picking out fuel lines for my Fi Set up [Re: 70RT Charger] #2959507
08/31/21 02:09 PM
08/31/21 02:09 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
I don't know how much power you plan on making (or E85?)? I use my old stainless steel 3/8" feed line as a return line, I bent a new feed line out of regular 3/8" steel tube. Has worked well with my fuel injection with an intank pump
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: Needing help picking out fuel lines for my Fi Set up [Re: 70RT Charger] #2959508
08/31/21 02:10 PM
08/31/21 02:10 PM
Lake Villa Il
INTMD8 Online content
INTMD8  Online Content
Lake Villa Il
You can use the factory line for most of it. Cut off the flared ends and use a -6 a/n adapter (uses a crush type internal collet). Or just weld on the fittings.
I prefer to use teflon hose for the flexible connections as you don't get any fuel vapor smell from it. (and generally smaller outer diameter and looks nicer, in my opinion)
Re: Needing help picking out fuel lines for my Fi Set up [Re: INTMD8] #2959552
08/31/21 03:26 PM
08/31/21 03:26 PM
eastern,Ky
eastern,Ky
OK thanks. I have a Stainless Steel feed line so that’s good. I’ll just order another SS feed line and order some Teflon hose and some fittings. I’m pushing close to 600 HP and don’t plan on running E85. Thanks!
Re: Needing help picking out fuel lines for my Fi Set up [Re: 70RT Charger] #2959554
08/31/21 03:31 PM
08/31/21 03:31 PM
AndyF Offline
AndyF  Offline
Depends which fuel pump module that you are using. If you use the Holley muscle car module then you don't need a return line. Holley makes a 350 LPH internal pump module which supports 700+ hp and it doesn't need a return line since the return is in the tank. It also doesn't need a regulator since the regulator is in the tank. Just hook up your existing line to the new pump and you're good to go.
https://www.holley.com/products/fue...umps/muscle_car_efi_modules/parts/12-384
Re: Needing help picking out fuel lines for my Fi Set up [Re: AndyF] #2959560
08/31/21 03:45 PM
08/31/21 03:45 PM
eastern,Ky
eastern,Ky
Well for some reason FASTMAN has got me using this pump https://www.holley.com/products/fuel_systems/fuel_tanks/parts/19-168 That pump you’re showing me looks like it could have saved me some work.
Re: Needing help picking out fuel lines for my Fi Set up [Re: 70RT Charger] #2959567
08/31/21 04:01 PM
08/31/21 04:01 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
That 350 lph drop in pump is brand new, I think it's only been out a month or so. Previously the options were a 255 lph drop in pump, or the 400 lph module that also requires the fuel tank to be modified or a replacement tank installed with that sending unit interface on it.
Re: Needing help picking out fuel lines for my Fi Set up [Re: 70RT Charger] #2959577
08/31/21 04:30 PM
08/31/21 04:30 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The higher the tank-mounted pump pressure (modern factory FI is 43.5 psi, or 3 bar), the smaller the feed line can be.
As pressure increases, flow through a fixed line ID increases as the square root of the change. Double the psi raises the flow by 41% (2^.5 = 1.414).
Boffin Emeritus
Re: Needing help picking out fuel lines for my Fi Set up [Re: 70RT Charger] #2959614
08/31/21 05:57 PM
08/31/21 05:57 PM
AndyF Offline
AndyF  Offline
Yes, if you have a stock gas tank then the drop in 350 LPH module is the slick way to go. If you have already installed your fuel pump then the question is which regulator you have. If you have an older style billet regulator you put it up front and run full length feed and return lines. If you buy a Holley 12-876 regulator/filter combo then you can put it at the rear of the car with a very short return line. Then you just have one high pressure feed line going to the front. I've plumbed a few cars with the 12-876 and it works pretty good with a 600 to 700 hp engine. https://www.holley.com/products/fue...s/regulators/efi_regulators/parts/12-876
Re: Needing help picking out fuel lines for my Fi Set up [Re: AndyF] #2959625
08/31/21 06:21 PM
08/31/21 06:21 PM
eastern,Ky
eastern,Ky
I ordered an EFi tank with the pump already installed from Holley, all from FASTMAN.I emailed Richard about the 350 pump, waiting for a reply. He sent me this regulator https://www.holley.com/products/fue...lters/filters/efi_filters/parts/162-554. I’m a newb when it comes to EFi but if this 350 pump will work it will save me a lot of work. If there’s a reason he didn’t want me to use it that’s fine also.
Re: Needing help picking out fuel lines for my Fi Set up [Re: 70RT Charger] #2959655
08/31/21 07:29 PM
08/31/21 07:29 PM
eastern,Ky
eastern,Ky
Rich got back with me and he highly recommended me using a return line so I’m going with his advise. Thanks guys!
Re: Needing help picking out fuel lines for my Fi Set up [Re: 70RT Charger] #2959663
08/31/21 07:43 PM
08/31/21 07:43 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
I'll be running OE 3/8 SS line from the tank to engine compartment with E85 on my Barracuda. Hardline + limited restricted fittings, that's a ton of fuel you can move.
Holley has been coming out with a ton of good products lately, but that pump just looks so cheap I have a hard time getting over it. Love how it has everything compressed to one unit tho.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Needing help picking out fuel lines for my Fi Set up [Re: 70RT Charger] #2959713
08/31/21 09:27 PM
08/31/21 09:27 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I am a firm believer in a return set up from front to back, I also have found I had to insulate all my fuel lines & the pressure regulator from heat,if not it heats up the fuel in the tank, I drive my car a lot & its hot here in Southeast Tx , , I have the Tanks Inc 450lph pump & tank. I
Re: Needing help picking out fuel lines for my Fi Set up [Re: CSK] #2959794
09/01/21 07:31 AM
09/01/21 07:31 AM
eastern,Ky
eastern,Ky
What did you use to insulate the lines and regulator with?
Re: Needing help picking out fuel lines for my Fi Set up [Re: A39Coronet] #2959796
09/01/21 07:34 AM
09/01/21 07:34 AM
eastern,Ky
eastern,Ky
That’s the lines I’ll use and I’m going to use the pump that FASTMAN recommended.
Re: Needing help picking out fuel lines for my Fi Set up [Re: CSK] #2959809
09/01/21 08:46 AM
09/01/21 08:46 AM
Lake Villa Il
Lake Villa Il
That is my preference as well.
Regulating inside the tank works of course but doesn't compensate for any pressure drop across the feed line/fittings. So with in tank regulation, you can see pressure drop slightly with higher fuel demands even if it's within the normal capacity of the pump.
Re: Needing help picking out fuel lines for my Fi Set up [Re: 70RT Charger] #2959817
09/01/21 09:17 AM
09/01/21 09:17 AM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
I believe teflon lines use their own AN fittings just as a note. I wish I had gone that route. I went with standard braided and once the ethanol eats thru it, I'll have to redo with all new fittings to go Teflon.
Re: Needing help picking out fuel lines for my Fi Set up [Re: 80fbody] #2959893
09/01/21 12:53 PM
09/01/21 12:53 PM
Lake Villa Il
Lake Villa Il
I like the Goodridge 910 hose/fittings fwiw. Lots of flexibility and easy to work with.
Re: Needing help picking out fuel lines for my Fi Set up [Re: INTMD8] #2959894
09/01/21 12:53 PM
09/01/21 12:53 PM
eastern,Ky
eastern,Ky
If you used the adapters and a return line could you tell me how many adapters you used?
Re: Needing help picking out fuel lines for my Fi Set up [Re: 70RT Charger] #2960200
09/02/21 05:14 AM
09/02/21 05:14 AM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
I used the factory style hard line, Hemi sized 3/8 supply and bought a regular BB/SB 5/16 line for the return and ran them side by side. I flared the factory line with the GM push-on style o-ring fittings and bought the appropriate adapters. For example Russell Performance 644133.
AG.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
