Tunnel Ram hesitation
#2959680
08/31/21 08:30 PM
08/31/21 08:30 PM
Posts: 192 Gravataí, RS, Brazil
360tripleblack77
Hello guys, long time since last post.
I'm having a bad hesitation from the iddle or footbrake to WOT.
There's a 360" SB Mopar, Edelbrock ported heads, weiand Tunnel Ram, 750 annular booster Mighty Demon Carbs, 11.8:1CR, 24° initial timing, 36° Total timing, 96oct pump gas(30% ethanol) . 904 trans, 4200 9.5" converter.
When I installed tunnel ram, I had no issues. 31 nozzle on Both sides, pink cam, 30cc boosters, 3.5 Power valve, 74 primary jet, 82 secondary jet.
No changes and car starts hesitation. Tries to change for 37 primary nozzle and green cam, little bit better but still problem.
Any tips? Really appreciate.
'77 Brazilian Dodge Charger R/T - Street Car Footbrake, Pump Gas, SB Mopar 360" N/A 3300lbs, Leaf Spring + Assassin Bars Best 1/8 mile ET 1.50 60' / 4.31 330' / 6.73@102.54mph
Re: Tunnel Ram hesitation
[Re: 360tripleblack77]
#2959725
08/31/21 10:11 PM
08/31/21 10:11 PM
Posts: 12,386 Taxes & Virus's R-US, NY
Dragula
I am no expert...I like to tinker .....
Those carbs are not known to be lean, especially considering they are annular. But what always gets a car moving is fuel and timing. More timing always gives you a better 60ft, until you go too far. And the more timing, the more fuel the engine will want.
If you comfortable where timing is at, then I suggest squirters...Get a bunch, and tinker. They also make different squirter cams, get a set...Find the best squirters and then tinker with the cams. That is how I do it. I go up in squirter until its too much...No squirter is too big for me...
PS I am anti power valve, so all my stuff is square jetted and easy to figure out. I would go that way to start with, and then if you really like power vales, take out 7 sizes in jet, and put them back in.I do not like them at all.....
[Re: dvw]
#2959747
08/31/21 11:42 PM
08/31/21 11:42 PM
Posts: 4,457 Washington
madscientist
Washington
A 3.5 power valve open way too late. I suspect an 8.5 would be a much better choice.
#2959750
08/31/21 11:53 PM
08/31/21 11:53 PM
Posts: 712 Lake Villa Il
INTMD8
Lake Villa Il
No changes and car starts hesitation. If I'm reading this right it ran well and then had a problem with no changes? To me that means, fix the problem not change the tune-up.
#2959782
09/01/21 05:59 AM
09/01/21 05:59 AM
Posts: 2,915 A shed in England
Tig
A shed in England
We chased a similar problem for months, tried every thing, squirter's, timing, wedge floats, j tubes etc. We knew it was a fuel control issue as the problem never appeared on the dyno and if we induced tyre spin into the chassis it cleared. The O2 data said it was going lean then a rich spike. Turned out it was fuel just sloshing out of the vent tubes, we had to lower the fuel level in the bowls (below recommended) and all was well. This was on 2 x 1150 Dominator's BTW.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: boatracer572]
#2959963
09/01/21 04:11 PM
09/01/21 04:11 PM
Tig
A shed in England
all great comments above... this is a common occurrence in my world (boat drag racing) the first problem i see with your combo is the staggered jetting ,that in its self will cause erratic afr and rich and lean conditions. tunnel rams have equal length runners.. IE jetting should be square to start. the power valves need to be plugged as well.. i have found on 4150 style carbs turning the accelerator cams up side down works great and will save money on cams. squirter wise, i drill out the squirters with a .040" size drill to start out with,.but dont be surprised if you end up going much larger.... try this odds are your problem will be fixed worst case scenario you will need to increase the accelerator size to 50cc Yep It seems entirely feasible that all square jetting and 1 to 1 linkages are the way too go with a TR and that is the way we have it at the moment. But... I'm soon to fit EGT's and a Racepak. It will be interesting to see if we need to treat each cylinder as individual.
[Re: Tig]
#2960057
09/01/21 06:53 PM
09/01/21 06:53 PM
Posts: 1,823 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
all great comments above... this is a common occurrence in my world (boat drag racing) the first problem i see with your combo is the staggered jetting ,that in its self will cause erratic afr and rich and lean conditions. tunnel rams have equal length runners.. IE jetting should be square to start. the power valves need to be plugged as well.. i have found on 4150 style carbs turning the accelerator cams up side down works great and will save money on cams. squirter wise, i drill out the squirters with a .040" size drill to start out with,.but dont be surprised if you end up going much larger.... try this odds are your problem will be fixed worst case scenario you will need to increase the accelerator size to 50cc Yep It seems entirely feasible that all square jetting and 1 to 1 linkages are the way too go with a TR and that is the way we have it at the moment. But... I'm soon to fit EGT's and a Racepak. It will be interesting to see if we need to treat each cylinder as individual. Tig....in all my years running a tunnelram I've never, ever seen a square jetting.
[Re: mopar dave]
#2960184
09/02/21 12:36 AM
09/02/21 12:36 AM
madscientist
Washington
First, I would double check your ignition system right down to the spark plugs. Something has degraded. Power valves really dont need to be used with tunnel rams IMO. I pissed away 2 months of tuning mine on the street to find square jetting was the answer. Mine ran ok with 6.5 pv's, but the engine woke up a bit accelerating much faster square jetted. If your stuck on pv's, then 6.5-8.5 like madscientist suggested. Tuning a tunnel ram is different than tuning a single carb. Mine starts right up and idles immediately a bit on the lean side and then richens up as the engine gets warm and i am only 1 1/4 turns on the screws. I use #35 squirters and have tried #37 with no change in responsiveness. My carbs have 1.320 venturi if i remember correctly. small 750's was how they were described to me. Soon to get to the track, will see how it performs there. I really suggest square jetting weather racing or street, it just works. The T ram has individual runners and each runner should have the same amount of fuel feeding each individual cylinder. Good luck with your tuning. I’m curious how you keep the cruise AF ratio clean without using a power valve on the primary side? It would seem to me it would be pretty fat if you have enough jet to keep it from going lean at WOT. I forget...did Dom use annular boosters in your carbs or down legs?
[Re: mopar dave]
#2960321
09/02/21 02:48 PM
09/02/21 02:48 PM
Posts: 43,141 Bend,OR USA
Cab_Burge
I Cruises lean if any thing, high 14's to low 15's now with the screws at 1 1/4 turns. Those numbers worked well on my old Duster with the six pack and 440 heads and all three of single dominator carbs I ran on it with the max wedge heads
[Re: madscientist]
#2960571
09/03/21 10:40 AM
09/03/21 10:40 AM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
It's all in the calibration and my 650ish carbs are awesome square jetted as well with no p/v's but the idle and transition circuits need to be tailored to your combo and I'm not a big annular fan either at least with those small venturi's.....
[Re: Tig]
#2961654
09/06/21 06:30 PM
09/06/21 06:30 PM
Posts: 1,049 San Jose Ca.
boatracer572
San Jose Ca.
all great comments above... this is a common occurrence in my world (boat drag racing) the first problem i see with your combo is the staggered jetting ,that in its self will cause erratic afr and rich and lean conditions. tunnel rams have equal length runners.. IE jetting should be square to start. the power valves need to be plugged as well.. i have found on 4150 style carbs turning the accelerator cams up side down works great and will save money on cams. squirter wise, i drill out the squirters with a .040" size drill to start out with,.but dont be surprised if you end up going much larger.... try this odds are your problem will be fixed worst case scenario you will need to increase the accelerator size to 50cc Yep It seems entirely feasible that all square jetting and 1 to 1 linkages are the way too go with a TR and that is the way we have it at the moment. But... I'm soon to fit EGT's and a Racepak. It will be interesting to see if we need to treat each cylinder as individual. I have found EGT’s to give you mixed results ,what has worked best for me has been O2 sensors and every cylinder, If you try biger squirters and Accelerater pump cams and that doesn’t work, you may need to richen up the intermediate circuit with a smaller air bleed.
[Re: merpar]
#2962202
09/08/21 03:01 PM
09/08/21 03:01 PM
Thumperdart
State of confusion
Not necessarily, I run pink cams in the # 1 position with .033 shooters and zero bogs or hesitation anywhere.....
