Ideal water temp for most power???
#295946
04/22/09 02:49 AM
04/22/09 02:49 AM
Posts: 2,103 East Coast, NJ
fig426
East Coast, NJ
Is there an ideal water temperature to make the most power?
Chris from New Jersey
Post deleted by Defbob
[Re: Bigcube]
#295950
04/22/09 06:06 AM
04/22/09 06:06 AM
Re: Ideal water temp for most power???
#295951
04/22/09 06:34 AM
04/22/09 06:34 AM
Posts: 4,647 aotearoa
rebel
aotearoa
hot oil , cold motor
well that sounds easy don't it?
[Re: fig426]
#295953
04/22/09 07:56 AM
04/22/09 07:56 AM
Posts: 176 Sterling Heights, MI
John_T_Brown
Looking over data of about a hundred runs my average has been about 130 degrees at the start and 155 thru the lights. Of course the temperature rise is dictated by many factors including fuel, carb settings, timing, water flow, type of material for engine components, etc., etc. Hope this helps.
If it ain't broke fix it anyway!
[Re: Fury Fan]
#295954
04/22/09 08:13 AM
04/22/09 08:13 AM
Posts: 3,517 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
Cold engines? Are ring wear and engine longevity not a concern?
For folks that want the most power, comp, pro stock etc, no...
#295955
04/22/09 08:21 AM
04/22/09 08:21 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Warm engine - cold/cool air inflow. Mine for one won't ET well below 180 engine temp and is more consistent.
[Re: fig426]
#295956
04/22/09 08:34 AM
04/22/09 08:34 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Just warm enough to get any cylinder distortion out of the cylinders and the piston up to diameter, cold intake charge and oil good and warm
[Re: rebel]
#295957
04/22/09 08:48 AM
04/22/09 08:48 AM
#295958
04/22/09 09:47 AM
04/22/09 09:47 AM
Posts: 1,106 Quebec, Canada
Diablo
Quebec, Canada
oil pan heater
Or Dry Sump with seperate oil heater
[Re: Diablo]
#295959
04/22/09 03:01 PM
04/22/09 03:01 PM
rebel
aotearoa
oil pan heater
gas ring from the bbq under the pan?
[Re: Fury Fan]
#295962
04/23/09 02:54 AM
04/23/09 02:54 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I would think the hot oil would help the surface areas of the bores to stay warm and not wear as much as a dead cold engine.
after a day at the dyno, my best pull of the day was when they did 3 back to back pulls, and got the oil up to around 170, then dumped the water, and cooled the block, did the last run with oil at 165 and water at 120, and it was the strongest pull of the day.
**Photobucket sucks**
[Re: Stroker Scamp]
#295963
04/23/09 11:44 AM
04/23/09 11:44 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
We try to have the drag radial car stone cold. Usually about 130 at the end of a run.
Monte
even the oil? or do you heat it?
We warm the car at the beginning of the day and get the oil hot. The rest of the day, we want the water as cold as we can get it. In the process of building a chiller to cool it between rounds. Planning on taking the water pump and radiator out of the car. It only makes about 40 degrees during a run and has no fan now. With the chiller, it won't need the radiator.
Monte
[Re: AndyF]
#295965
04/23/09 02:26 PM
04/23/09 02:26 PM
Posts: 1,946 Connecticut
5126brl No more
Connecticut
Very good info It makes me wonder why my 10.99 run came after a back to back pass @ 200 degrees?waqs running 11.0s all day then came up the return road no one in the lanes so I staged at 200.
