Ideal water temp for most power??? #295946
04/22/09 02:49 AM
04/22/09 02:49 AM
East Coast, NJ
fig426 Offline OP
fig426  Offline OP
East Coast, NJ
Is there an ideal water temperature to make the most power?
Chris from New Jersey
Re: Ideal water temp for most power??? [Re: fig426] #295947
04/22/09 03:26 AM
04/22/09 03:26 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
As low as you can get it
AL...
Alan Jones
Re: Ideal water temp for most power??? [Re: LA360] #295948
04/22/09 05:20 AM
04/22/09 05:20 AM
Q
Quicktree Offline
Quicktree  Offline
Q
I like to leave at about 150*
Re: Ideal water temp for most power??? [Re: LA360] #295949
04/22/09 05:59 AM
04/22/09 05:59 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
AL...
And oil as hot as you can get it.
Post deleted by Defbob [Re: Bigcube] #295950
04/22/09 06:06 AM
04/22/09 06:06 AM
Re: Ideal water temp for most power??? #295951
04/22/09 06:34 AM
04/22/09 06:34 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
hot oil , cold motor
well that sounds easy don't it?
Re: Ideal water temp for most power??? [Re: rebel] #295952
04/22/09 07:43 AM
04/22/09 07:43 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Cold engines? Are ring wear and engine longevity not a concern?
Parts I seek: driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set 16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better. 69-73 C-body caliper brackets and/or splashields Send a PM.
Re: Ideal water temp for most power??? [Re: fig426] #295953
04/22/09 07:56 AM
04/22/09 07:56 AM
Sterling Heights, MI
John_T_Brown Offline
Looking over data of about a hundred runs my average has been about 130 degrees at the start and 155 thru the lights. Of course the temperature rise is dictated by many factors including fuel, carb settings, timing, water flow, type of material for engine components, etc., etc. Hope this helps.
If it ain't broke fix it anyway!
Re: Ideal water temp for most power??? [Re: Fury Fan] #295954
04/22/09 08:13 AM
04/22/09 08:13 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
For folks that want the most power, comp, pro stock etc, no...
Re: Ideal water temp for most power??? #295955
04/22/09 08:21 AM
04/22/09 08:21 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Warm engine - cold/cool air inflow. Mine for one won't ET well below 180 engine temp and is more consistent.
Re: Ideal water temp for most power??? [Re: fig426] #295956
04/22/09 08:34 AM
04/22/09 08:34 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Just warm enough to get any cylinder distortion out
of the cylinders and the piston up to diameter, cold
intake charge and oil good and warm
Post deleted by Defbob [Re: rebel] #295957
04/22/09 08:48 AM
04/22/09 08:48 AM
Re: Ideal water temp for most power??? #295958
04/22/09 09:47 AM
04/22/09 09:47 AM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
oil pan heater
Or Dry Sump with seperate oil heater
Re: Ideal water temp for most power??? [Re: Diablo] #295959
04/22/09 03:01 PM
04/22/09 03:01 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
oil pan heater
gas ring from the bbq under the pan?
Re: Ideal water temp for most power??? [Re: rebel] #295960
04/23/09 12:39 AM
04/23/09 12:39 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
We try to have the drag radial car stone cold. Usually about 130 at the end of a run.
Monte
Re: Ideal water temp for most power??? [Re: Monte_Smith] #295961
04/23/09 02:39 AM
04/23/09 02:39 AM
pacific northwest
Stroker Scamp Offline
pacific northwest
Monte
even the oil? or do you heat it?
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Ideal water temp for most power??? [Re: Fury Fan] #295962
04/23/09 02:54 AM
04/23/09 02:54 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I would think the hot oil would help the surface areas of the bores to stay warm and not wear as much as a dead cold engine.
after a day at the dyno, my best pull of the day was when they did 3 back to back pulls, and got the oil up to around 170, then dumped the water, and cooled the block, did the last run with oil at 165 and water at 120, and it was the strongest pull of the day.
**Photobucket sucks**
Re: Ideal water temp for most power??? [Re: Stroker Scamp] #295963
04/23/09 11:44 AM
04/23/09 11:44 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Monte
We warm the car at the beginning of the day and get the oil hot. The rest of the day, we want the water as cold as we can get it. In the process of building a chiller to cool it between rounds. Planning on taking the water pump and radiator out of the car. It only makes about 40 degrees during a run and has no fan now. With the chiller, it won't need the radiator.
Monte
Re: Ideal water temp for most power??? [Re: Monte_Smith] #295964
04/23/09 02:17 PM
04/23/09 02:17 PM
AndyF Offline
AndyF  Offline
I was talking to a SS engine builder the other day and he said they chill the water before pushing to the line. They try to keep the water temp below 100 degrees on the starting line (that is after the burnout). Have to use a 0 weight oil. I've never tried any tricks like that myself but I do know that if you want to make some extra power on the dyno you just crack the valve and let more cold water into the engine. Sometimes if you look at dyno sheets you'll see that people are running the engines at 120 or 130 degrees. I usually run all of my tests at 180 so I guess I'm giving up about 20 or 30 hp.
Re: Ideal water temp for most power??? [Re: AndyF] #295965
04/23/09 02:26 PM
04/23/09 02:26 PM
Connecticut
5126brl No more Offline
Connecticut
Very good info
It makes me wonder why my 10.99 run came after a back to back pass @ 200 degrees?waqs running 11.0s all day then came up the return road no
one in the lanes so I staged at 200.
Re: Ideal water temp for most power??? [Re: 5126brl No more] #295966
04/23/09 10:02 PM
04/23/09 10:02 PM
Mi.
G-Money1320 Offline
G-Money1320  Offline
Mi.
So maybe those old motor home dipstick oil heaters could come in handy at the track after all!!
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out.
11.06 open headers----so far!!
