ram - crap bolts and ex manifold warpage #2959187
08/30/21 09:03 PM
08/30/21 09:03 PM
md
mopars4ever Offline OP
md
I had two broken exhaust manifold bolts on my 14 Ram 5.7. I checked the manifold and it is warped, Does the manifold warp and then that is what breaks the bolts? Or are they cheap bolts and the manifold warps after the bolts break? Also why are there two different part numbers for the stud bolts that mounts the right side heat shield, They look the same length except the nut portion is slightly different. 2 look like 6510141AA and the other two look like 6509863AA
Re: ram - crap bolts and ex manifold warpage [Re: mopars4ever] #2959200
08/30/21 09:25 PM
08/30/21 09:25 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Just had my right exhaust manifold replaced on my 2015 Ram 2500 5.7 4x4. It was the third time the studs broke and the manifold warped. I have lifetime powertrain warranty but each time cost me $200 deductible. I told them this time I was not paying it to they checked the manifold and it was warped bad. They said because the studs kept breaking it cause the manifold to warp. They replaced the studs and the manifold and so far 2500 miles and no further issues, but I will be watching and listening... scope
JB Rhinehart, Realist
A-Body's RULE!
Re: ram - crap bolts and ex manifold warpage [Re: Rhinodart] #2959217
08/30/21 10:00 PM
08/30/21 10:00 PM
md
md
No warranty on mine. I ordered a new manifold as the manifold end where the bolts were broke was warped bad. I doubt I could of had in machined flat without taking off quite a bit.
Re: ram - crap bolts and ex manifold warpage [Re: mopars4ever] #2959236
08/30/21 10:21 PM
08/30/21 10:21 PM
Laveen, Arizona
GTSDart340 Offline
GTSDart340  Offline
Laveen, Arizona
Very common on all years of the 5.7.
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
Re: ram - crap bolts and ex manifold warpage [Re: GTSDart340] #2959319
08/31/21 08:37 AM
08/31/21 08:37 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Also common on the LS and 4.6/5.4 Ford motors. Don't know why. Expansion difference with aluminum heads? I just replaced the Y pipe to manifold studs on my 2005 Magnum 3.5. 2 were rusted right in half. 2 were not. We are talking a 10mm stud. One on each manifold. How does that happen?
Doug
Re: ram - crap bolts and ex manifold warpage [Re: mopars4ever] #2959348
08/31/21 09:41 AM
08/31/21 09:41 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
If you ever looked at a 5.7 Nissan it looks very similar to the Hemi on the exhaust side of the head. They use much larger studs, so they crack/break the manifold which is also the cat.
The newer rams have a new “brace” on the manifold…. and I’ve seen three of those with cracked manifolds so far.
The broken studs…. I replace all the end studs… even the ones that are not broke often are bent. I’ve also used a step drill bit and enlarged the end holes on the manifold face. The end ports also get a bead of copper RTV around them on both sides of the gasket.
Pretty easy job on the 1500s, but the 2500s can really suck…. As well as the Grand Cherokee and Durango’s…
Re: ram - crap bolts and ex manifold warpage [Re: J_BODY] #2959385
08/31/21 10:49 AM
08/31/21 10:49 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
The manifolds in the old days did not appear to be as prone to cracking and warping like the new ones are. Maybe the metallurgy of the iron in the newer manifolds is just not as good?
Personally I think if a manifold broke it would be time to switch to headers vs buying another manifold again and again.
Re: ram - crap bolts and ex manifold warpage [Re: mopars4ever] #2959388
08/31/21 11:00 AM
08/31/21 11:00 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
318 Poly engines were famous for warping and breaking the driver's side manifold. If you find a Poly in a wrecking yard that still has a driver's side manifold on it, chances are it's cracked. Passenger side rarely cracked so lots of those around.
A seasoned but warped manifold machined flat again has pretty much done all the warping it's going to do and will usually live a long happy life with new hardware, assuming it can be machined back true. A new green casting is just asking for rinse repeat.
Kevin
Re: ram - crap bolts and ex manifold warpage [Re: Neil] #2959389
08/31/21 11:01 AM
08/31/21 11:01 AM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Originally Posted by Neil
The manifolds in the old days did not appear to be as prone to cracking and warping like the new ones are. Maybe the metallurgy of the iron in the newer manifolds is just not as good?.
Likely they are using less metal to save weight. Same issue with brake rotors warping--often there is not enough material on them to even turn them.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: ram - crap bolts and ex manifold warpage [Re: Twostick] #2959390
08/31/21 11:02 AM
08/31/21 11:02 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I had the same problem on two of my 5.7 trucks. I cured it by going to shorty headers.
Re: ram - crap bolts and ex manifold warpage [Re: Rhinodart] #2959391
08/31/21 11:03 AM
08/31/21 11:03 AM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Pretty sure they've got that backwards. The manifold warps and breaks the studs.
Kevin
Re: ram - crap bolts and ex manifold warpage [Re: Twostick] #2959395
08/31/21 11:17 AM
08/31/21 11:17 AM
5thAve Offline
5thAve  Offline
You'd think they could use some sort of spacer at the manifold to cushion the heat expansion of the manifold since that's probably what causes the studs to break.
I've never checked mine but it does have the typical tick on cold starts so I wouldn't be surprised if it has a broken stud.
Re: ram - crap bolts and ex manifold warpage [Re: 5thAve] #2959398
08/31/21 11:23 AM
08/31/21 11:23 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
If I had to point a finger somewhere, I would say the manifolds are at fault.
Why? The cars almost never do that, the trucks almost always do it. The manifolds are, of course, totally different.
Rich H.
Esse Quam Videri
Re: ram - crap bolts and ex manifold warpage [Re: ZIPPY] #2959429
08/31/21 12:14 PM
08/31/21 12:14 PM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
Been there done that, 14 RAM w/52k miles. 2 front broken studs on left side and 1 front broken stud on right side. Both manifolds were warped about 1/8". Both left side studs were broken at the head, had to weld nuts to remove them. Not covered under warranty.
Re: ram - crap bolts and ex manifold warpage [Re: ZIPPY] #2959439
08/31/21 12:23 PM
08/31/21 12:23 PM
moparx Offline
moparx  Offline
how thick are the bolt ears ? are there thickness differences in those areas between the truck and car manifolds ?
then, how thick on average are most header flanges ? 3/8 - 1/2" ?
beer
Re: ram - crap bolts and ex manifold warpage [Re: Twostick] #2959498
08/31/21 01:37 PM
08/31/21 01:37 PM
md
md
Kevin
that was what I was thinking. I am surprised they don`t pull the threads out of the heads.
Re: ram - crap bolts and ex manifold warpage [Re: mopars4ever] #2959506
08/31/21 02:05 PM
08/31/21 02:05 PM
N
NITROUSN Offline
NITROUSN  Offline
N
GM 6.0 are no better.
Re: ram - crap bolts and ex manifold warpage [Re: NITROUSN] #2959517
08/31/21 02:24 PM
08/31/21 02:24 PM
P
Pntastar69 Offline
Pntastar69  Offline
P
Pix of the broken studs
Re: ram - crap bolts and ex manifold warpage [Re: Pntastar69] #2959546
08/31/21 03:13 PM
08/31/21 03:13 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Try backing them out with something pointed. Mine came right out. The studs never corroded ito the head. I was very suprised at how easy they came out.
Re: ram - crap bolts and ex manifold warpage [Re: stumpy] #2959568
08/31/21 04:05 PM
08/31/21 04:05 PM
md
md
Mine were broke like in the pic above. One came out with some vice grips and the other didn`t budge. I tried a left handed drill bit but it was not going anywhere. Then the bit broke. So I welded a nut to the broken stud and after three tries I got it out. I bought a China manifold from NAPA since the mopar one was going to take at least a week to get it. Anyone use one of those manifolds? Are they any good? Or should I have waited for a mopar one? It appears the mopar ones aren`t really any better it seems. This one lasted about 70,000 miles.
