1959 Fargo (Dodge D100) engine swap #2958551
08/29/21 04:07 AM
08/29/21 04:07 AM
Canada
CrAzYMoPaRGuY Offline OP
Canada
I bought a 1959 Fargo, super clean truck. It's short box, 2wd, 230 flathead 6 and 3 in the tree manual. Engine is PROBABLY not good. Thinking small block or big block, anybody mounted a newer V8 in a 55-60 truck? Mounts off the frame or? Thanks!
CrAzYMoPaRGuY
Re: 1959 Fargo (Dodge D100) engine swap [Re: CrAzYMoPaRGuY] #2958595
08/29/21 09:27 AM
08/29/21 09:27 AM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
They came with an optional V8. A poly headed one, so I imagine there's plenty of room in there. If you decide to get rid of that 230 or have more questions they guys at https://p15-d24.com/forum/4-p15-d24-forum/ would be a good place to go. Always someone looking for a 230 there and they are a fount of info on this era vehicles. They have a truck section.
Re: 1959 Fargo (Dodge D100) engine swap [Re: Sniper] #2958869
08/29/21 10:46 PM
08/29/21 10:46 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
They did indeed come with a V8 option from mid 54 on BUT that early motor mounted off a bracket attached to the front of the motor and had a transmission mounts on side of the bell. That stuff isn't too compatible with the modern engine and transmission mounting systems.
You will likely find that you will be farther ahead to build brackets off the frame (include both the top and the bottom frame flanges) for the motor, and then add a transmission crossmember at the rear end of the trans (if there is not already one there). I had an original V8 54 Dodge pickup (one of the first V8 Dodge pickups in our area), but it was missing the motor & the mounts. The two brackets for the original bell mounting were in the way of easily installing a modern 360/727, so I cut them off at the frame and built motor mount brackets and added a transmission crossmember. My motor & trans sat back a little more then the original V8 did, those original motors are mounted so the motor is centered above the front axle. Setting the motor back required modifying the firewall quite a bit, for engine clearance. I suspect that by 59, that issue may have been solved, my truck was a very early factory V8 truck. Gene
Re: 1959 Fargo (Dodge D100) engine swap [Re: Sniper] #2958890
08/30/21 12:12 AM
08/30/21 12:12 AM
Canada
Canada
Awesome Sniper, thanks!
CrAzYMoPaRGuY
Re: 1959 Fargo (Dodge D100) engine swap [Re: poorboy] #2958891
08/30/21 12:15 AM
08/30/21 12:15 AM
Canada
Canada
Thanks Gene. We are gonna give the flathead 6 one more kick at the can, but then........ lol
CrAzYMoPaRGuY
Re: 1959 Fargo (Dodge D100) engine swap [Re: CrAzYMoPaRGuY] #2958893
08/30/21 12:19 AM
08/30/21 12:19 AM
Canada
Canada
It's nice shape, low miles, I think the rings are stuck. Has a little compression every cylinder, but some are low. Don't think it's the valves.
CrAzYMoPaRGuY
Re: 1959 Fargo (Dodge D100) engine swap [Re: CrAzYMoPaRGuY] #2958943
08/30/21 08:55 AM
08/30/21 08:55 AM
nowhere
nowhere
Sticky rings are not uncommon, especially if they sit forever.. My 51 Plymouth had 50 psi compression in each cylinder when I got it. Changes the oil added MMO and drove it. Two years later she'll still driving. I need to do another compression check.
Re: 1959 Fargo (Dodge D100) engine swap [Re: Sniper] #2959075
08/30/21 04:13 PM
08/30/21 04:13 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Add one pint of old original PB BLASTER to the oil and running it a few hundred miles will also help loosen stuck rings. Garage where I used to work did that on mid 60's little old lady Oldsmobiles and Pontiacs that had problems with slow cranking caused by carbon getting behind the rings. By time for the next oil change, the problem was usually gone.
EDIT: Just add a pint instead of a quart.
Re: 1959 Fargo (Dodge D100) engine swap [Re: John Brown] #2959264
08/30/21 11:23 PM
08/30/21 11:23 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Sold a 50 Dodge panel truck to a guy last fall. Truck sat in my barn for five years. I never tried to turn the engine. Don’t know how many years it sat before I got it. Guy I sold it to put Marvel Mystery oil in the cylinders, replaced the fuel pump and rebuilt the carb. He got it running and is now driving it. Nice truck. up
Re: 1959 Fargo (Dodge D100) engine swap [Re: Dabee] #2959282
08/31/21 01:29 AM
08/31/21 01:29 AM
Canada
Canada
OK dangit I'll try. I was gonna pull the head and put something in the bores, have a look and toss a new gasket in. It ALMOST fired once..... well it barely ran for about 10 seconds. Compression was 60-30-50-25-60-90
CrAzYMoPaRGuY
Re: 1959 Fargo (Dodge D100) engine swap [Re: CrAzYMoPaRGuY] #2959377
08/31/21 10:30 AM
08/31/21 10:30 AM
moparx Offline
moparx  Offline
mix ATF and kerosene 1:1 and dump down the cylinders. smokes like cRaZy, but will free up the rings then the smoke goes away.
i did that on the 99k mile 392 hemi that is on my shelf now. that car sat in the weeds in a guy's yard for 20+ years until i got it.
beer
Re: 1959 Fargo (Dodge D100) engine swap [Re: poorboy] #2959595
08/31/21 04:56 PM
08/31/21 04:56 PM
nowhere
nowhere
Wasn't trying to suggest he put in the optional poly, just that if a poly was optional then the room was there for at least an LA. Though to be honest a 440 ought to fit too, but I am assuming that, lol.
Sounds like that original poly mounts very similar to how the 6 mounts in my 51 Plymouth.
Re: 1959 Fargo (Dodge D100) engine swap [Re: Sniper] #2959632
08/31/21 06:34 PM
08/31/21 06:34 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Actually, 241 Dodge hemi motors were installed in those trucks from the factory at some point in the production cycle. The Hemi motors were available in the big trucks. The available info isn't real clear, maybe the early Hemi was another option above the early poly, or maybe the hemi was the original V8 offered but later Dodge changed to the poly as the standard V8.
At any rate, the early V8 motor & trans mounts were very similar to the flathead 6 motor & trans mounts and may have been the same mounts. I never pursued using the factory mounting system because I was installing a much more modern drive train.
My son bought a 56 Dodge panel that had a 383 Mopar big block & 727 installed with an aftermarket motor & trans mount kit (Cal Custom, or maybe Competition Engineering). That panel was assembled in the early 70s. They hacked out the firewall from about the gas pedal all the way to the right side of the firewall and put in a piece of sheet metal. It was done pretty crudely. The 383 barely turned over and the guy wanted to keep it, so we installed a 360 with a 727 into it, and welded in a firewall that more resembled what would have been closer to original. My son drove that panel all through high school.
I believe the main reason the guy hacked out the firewall was because the 383 still had a car oil pan on it and it sat pretty far back. Gene
Re: 1959 Fargo (Dodge D100) engine swap [Re: poorboy] #2960224
09/02/21 08:31 AM
09/02/21 08:31 AM
Canada
Canada
Wellllllll I got the flathead 6 fired! A night of soaking rings in Liquid Wrench, then tossing a boat gas tank to the fuel pump with new fuel and a carb from a 53 Chevy. Ran for about half an hour. Smoke almost went away, it runs not bad. Compression went from 25-90 to 85-125 worst cylinder to best. Engine might be ok! Truck has 59,000 original miles......
CrAzYMoPaRGuY
Re: 1959 Fargo (Dodge D100) engine swap [Re: CrAzYMoPaRGuY] #2960296
09/02/21 01:18 PM
09/02/21 01:18 PM
nowhere
nowhere
Be careful, next thing you know you will be hopping up the 6. I have a modern, high compression aluminum head, split exhaust and dual carb intake for mine, Going to run Microsquirt controlled dual Weber EFI throttle bodies and am converting the stock points to electronic ignition using a mixture of a slant 6 and original distributor. A reground cam is in the mix as well. Shooting for 150hp. Now I know I could just slap a stock 318 in there and get that with no sweat, but then it'd just be another V8 swap whereas I am looking for a more period look and sound for my 51.
The pretty
http://www.yourolddad.com/bling
The EFI swap, it's in progress
http://www.yourolddad.com/efi
Re: 1959 Fargo (Dodge D100) engine swap [Re: Sniper] #2960367
09/02/21 05:05 PM
09/02/21 05:05 PM
MarkZ Online boogie
Worthy
MarkZ  Online Boogie
Worthy
The pretty
Nothing to add, but damn, this is so cool.
Re: 1959 Fargo (Dodge D100) engine swap [Re: CrAzYMoPaRGuY] #2960475
09/02/21 10:11 PM
09/02/21 10:11 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
That’s great. I love happy endings. bow
Re: 1959 Fargo (Dodge D100) engine swap [Re: CrAzYMoPaRGuY] #2961183
09/05/21 10:27 AM
09/05/21 10:27 AM
Canada
demon Offline
demon  Offline
Canada
I saw that truck for sale on FB, and thought about buying it too. Super clean looking in the pics. nice deal
Re: 1959 Fargo (Dodge D100) engine swap [Re: demon] #2964604
09/16/21 12:47 AM
09/16/21 12:47 AM
napa ca
P
procharged 484 Offline
P
napa ca
If your interested I have a complete 270 turns over . super red ram hemi 4 bbl engine with 3 spd overdrive . complete air cleaner to pan ,generator, pulleys bell housing flywheel clutch . and front motor mount
Re: 1959 Fargo (Dodge D100) engine swap [Re: procharged 484] #2964680
09/16/21 11:52 AM
09/16/21 11:52 AM
moparx Offline
moparx  Offline
it's funny you mentioned the super red ram.
i uncovered a pair of super red ram cylinder heads and valve covers the other day from under the "stuff" pile on the one shelf. i knew they were there, but the shelf needed a super cleaning, so the heads go to another shelf that contains a complete 241 engine i have had for 40 years or so.
my one buddy is building a 34 dodge "jalopy" replica, and will be using my engine.
it's amazing how much "stuff" i know is hidden away in this "pile" i haven't seen for years and years. biggrin
beer
