Power steering pump #2957040
08/24/21 07:25 PM
08/24/21 07:25 PM
BDW Online content OP
BDW  Online Content OP
Does the Gen3 Hemi power steering pump work with the old steering boxes?
Wondering what's involved to keep my old steering box.
Re: Power steering pump [Re: BDW] #2958739
08/29/21 04:42 PM
08/29/21 04:42 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
Im certain the modern powersteeringpump puts out way to much preasure,im also certain someone on this board knows of some kind of regulator to make it work. Im interested in the same kind of info.
Re: Power steering pump [Re: 1Fast340] #2958782
08/29/21 07:03 PM
08/29/21 07:03 PM
USA
hudsonhornet7x Offline
USA
These video's may help. One approach is apparently using a Jeep Wrangler power steering pump as they have lower pressure.
https://www.youtube.com/watch?v=zuaBnj8N20c
https://www.youtube.com/watch?v=3eg4Q8bgxbQ
Re: Power steering pump [Re: hudsonhornet7x] #2959013
08/30/21 01:13 PM
08/30/21 01:13 PM
Thx HH!
That's great info, looks like we can easily replace the pressure valve and use the original steering box.
Re: Power steering pump [Re: BDW] #2959184
08/30/21 08:55 PM
08/30/21 08:55 PM
IL
furious70 Offline
furious70  Offline
IL
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Power steering pump [Re: furious70] #2959199
08/30/21 09:24 PM
08/30/21 09:24 PM
I did check out Holley, beyond the $500 price, the "low" pressure still seems too high.
From what what I can find:
New Gen3 pumps ~1600psi
Holley "low" pressure ~ 1200psi
Old Mopar range ~700-1200psi
Toyota pressure valve ~750psi
I did the Mopar Action trick and added a couple of shims to my Saginaw pump valve and it definitely helped.
So I'm thinking I want to keep it in the ~800psi or lower range.
Re: Power steering pump [Re: BDW] #2959223
08/30/21 10:05 PM
08/30/21 10:05 PM
racine,wi
70gtx1 Offline
70gtx1  Offline
racine,wi
For what its worth, I run the stock hellcat PS pump with a Borgeson Steering box unit. No pressure reducing mods. Works great!!
Re: Power steering pump [Re: BDW] #2959308
08/31/21 07:55 AM
08/31/21 07:55 AM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
When I called Mopar performance direct line they had zero clue what PSI those pumps were. At the time I decided to make my own GM type 2 pump adapter with the assistance of a fellow board member. Recently I swapped out my adapter for the off the shelf unit from Holley, and a Jones Racing pump with aluminum reservoir tank. Cheaper than Bouchillion's reduced PSI unit, no gawdy plastic tank to leak, and readily available GM parts so no Mopar tax.
https://youtu.be/L_9nx-FBwQQ
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Power steering pump [Re: 70gtx1] #2959535
08/31/21 02:45 PM
08/31/21 02:45 PM
Borgeson would definitely be smaller, but I'm having a hard time justifying the $1000 cost.
Plan is to stick with to stock box, if at all possible.
This Gen3 swap is looking like its going to cost $10-12k min, my car is only worth $20k frown
Re: Power steering pump [Re: BDW] #2959696
08/31/21 08:55 PM
08/31/21 08:55 PM
IL
furious70 Offline
furious70  Offline
IL
like anything - if you have a completely functional setup the cutover costs really add up. If you don't have a working setup and you're buying stuff either way, it's not so bad.
That's a reason I'm going 5.7 turbo in my Coronet now but stuck with the 383 architecture to do a small upgrade rather than have to rebuild the turbo setup on my Fury. Too much time and cost at the moment for a car that just needed a new shortblock.
70 Sport Fury
68 Charger
69 Coronet
72 RR
