255/70/15 #2958663
08/29/21 12:32 PM
08/29/21 12:32 PM
London, England
JFChallenger440 Offline OP
London, England
Is anyone running this size on the rear of their car ? Be interested to see pics ? Also what backspacing would be needed ? I have a 70 Charger with 4” backspacing on the rear, thanks
Re: 255/70/15 [Re: JFChallenger440] #2958668
08/29/21 12:55 PM
08/29/21 12:55 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I've run that size on a '64 Savoy wagon, and the previous owner of my '69 Road Runner did as well.
Both used 8" wheels with the stock 4.25-4.50 BS, no rubbing.
That tire is about 30" tall but not all that wide - I've run 295/50s on a RR before with the same size & BS wheel with no issues.
Re: 255/70/15 [Re: topside] #2958686
08/29/21 01:26 PM
08/29/21 01:26 PM
London, England
London, England
My wheels are 15 x 7 by the way but the backspacing only 4”
So you think they should clear on my Charger ?
Re: 255/70/15 [Re: JFChallenger440] #2958701
08/29/21 02:28 PM
08/29/21 02:28 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Sidewall bulge will be different than what I know about, but likely not much.
Look up the section width, see what rim width it was measured at, and compare to what you have now.
A straightedge and measuring tape might be handy; straightedge against brake drum, measure to springs & inner wheelhouse.
Re: 255/70/15 [Re: JFChallenger440] #2958735
08/29/21 04:15 PM
08/29/21 04:15 PM
Detroit area
6PAX Online content
6PAX  Online Content
Detroit area
These are 255-70-15 on 7" Cragars on the GTX I used to own.
Re: 255/70/15 [Re: JFChallenger440] #2958747
08/29/21 05:30 PM
08/29/21 05:30 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
I run those on my 68 Satellite . I use a 8"rim with 4 1/2"BS . 7"rim will be fine , yes a little more bulge . Good size tyre without looking oversize . Great with my 4.10s
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: 255/70/15 [Re: JFChallenger440] #2959001
08/30/21 12:33 PM
08/30/21 12:33 PM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
That's what I have on the back of my Cuda at the moment. 15x8 wheels but the offset is not optimal. Tight to fender lip, but plenty of room on the inside. 255/60 on the front with 7" wide wheels.
Re: 255/70/15 [Re: JFChallenger440] #2959109
08/30/21 06:07 PM
08/30/21 06:07 PM
TN
1DGEMAN Offline
1DGEMAN  Offline
TN
255 70r 15 tires on 15x7 Rallye wheels. No clearance problems at all. Car is an original owner 440 6bbl 4sp numbers matching.
Real Men shift for themselves
Re: 255/70/15 [Re: 1DGEMAN] #2959249
08/30/21 10:38 PM
08/30/21 10:38 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Just put a set of P255/50R17's on my 51.
I got room for a lot more. Not that it helps. Running 08 Chrysler steelies on it.
Re: 255/70/15 [Re: JFChallenger440] #2959271
08/30/21 11:44 PM
08/30/21 11:44 PM
San Jose,CA
migsBIG Offline
YouTube is my go-to news source
migsBIG  Offline
San Jose,CA
I was just thinking of having 255's put on some 15x7 rims for my 1972 Charger. Thanks for posting pics everyone, all your cars look sweet with that size of rubber.
Re: 255/70/15 [Re: migsBIG] #2959289
08/31/21 04:33 AM
08/31/21 04:33 AM
London, England
London, England
I do like the 70 profile on the rear , surprised it’s not more popular really with most people going for 50 or 60 profile
Re: 255/70/15 [Re: JFChallenger440] #2959591
08/31/21 04:47 PM
08/31/21 04:47 PM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
Interesting post . I need tires this week to get ready for Lebanon Valley Mopar shows Sept 5th and Sept 12th . 69 Coronet with 15 X 7 old school American Racing Torque Thrusts with cooper cobra 275-60-15 on rear . drive think I'm going to try the coopers in the 255-70-15 especially since I have 7" rims . . Nice pictures on all the members cars . wave Have a great , safe Labor Day . Ronnie
Re: 255/70/15 [Re: 1969ronnie] #2960530
09/03/21 07:34 AM
09/03/21 07:34 AM
1969ronnie Offline
1969ronnie  Offline
Hi Moparts , update , I did get my new rear tires in from cooper in the 255-70-15 size , and they are perfect compared to the 275-60-15s i'm replacing . drive The next question is cooper changed the Font of the white letters VS the old tires . and the new tire letters look bigger and slightly slanted . shruggy Here we Go , New White letters out , or Black Side Walls out using American Racing Torque Thrusts Rims mounted on a dark green 1969 Coronet with black vinyl top ?
Re: 255/70/15 [Re: 1969ronnie] #2960540
09/03/21 08:47 AM
09/03/21 08:47 AM
Detroit area
6PAX Online content
6PAX  Online Content
Detroit area
Black walls out would be my choice as I'm not a fan of white letter tires on aftermarket wheels. However, I do prefer white letter tires on factory rally wheels.
Re: 255/70/15 [Re: 6PAX] #2960604
09/03/21 11:45 AM
09/03/21 11:45 AM
moparx Offline
moparx  Offline
black wall out. up
beer
Re: 255/70/15 [Re: moparx] #2960610
09/03/21 12:01 PM
09/03/21 12:01 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
I'm running 295/50/15 on a 15x10 with 5" backspace with no problems. I just went with the dilemma of whites in or out. I ended up with out.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: 255/70/15 [Re: 6PAX] #2960654
09/03/21 01:58 PM
09/03/21 01:58 PM
Phoenix, AZ
Belvedere1 Offline
Belvedere1  Offline
Phoenix, AZ
Do you happen to know what the backspace dimensions were on those 15 x 7s?
Re: 255/70/15 [Re: Belvedere1] #2960686
09/03/21 03:12 PM
09/03/21 03:12 PM
Detroit area
6PAX Online content
6PAX  Online Content
Detroit area
4 1/8"
Re: 255/70/15 [Re: 6PAX] #2960775
09/03/21 08:19 PM
09/03/21 08:19 PM
Phoenix, AZ
Belvedere1 Offline
Belvedere1  Offline
Phoenix, AZ
Thanks. I'm considering that size tire with a Torque Thrust 15 x 7 on my 67 Belvedere but the backspace is limited to 3 3/4 in that wheel width which may prove problematic.
Re: 255/70/15 [Re: Belvedere1] #2961068
09/04/21 09:26 PM
09/04/21 09:26 PM
1969ronnie Offline
1969ronnie  Offline
Hi Belverdere , I just measured mine and second the measurment backspacing of 3 5/8" to the rim flange and 3 3/4" to the outer rim Lip on my 15 X 7s rear Torque Thrusts . drive Happy Labor Day weekend , Ronnie
