Truck just quits running at a stop #2958463
08/28/21 09:03 PM
08/28/21 09:03 PM
Shopping @ HoBo Fright
340SIX Offline OP
Doc Flappergas's Evil Twin
340SIX  Offline OP
I have not looked at it is my wife's aunt's truck. 1992 or 93 318 magnum auto LE.
Leaning towards it being a 1993, if that matters.
An old lady drove back and forth to a close school as she was a teacher, now retired. So goes to food store once every 2 weeks and church on Sunday. Garaged super clean no rust as we live in the south. I have 1st dibs if she ever gets rid of it.
Said on phone last night runs 100% as it should but when you stop at a red light/stop sign motor turns off. Starts right back up and runs fine.
Last week she had to really drive it to get someones, kids, at school and did not do it the 2 days she used it.
Thoughts on what it could be? Anything common problems with these years and drive lines that go bad?
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Truck just quits running at a stop [Re: 340SIX] #2958472
08/28/21 09:20 PM
08/28/21 09:20 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Battery. Most likely cranks slow and dumps the memory on the first start. If it runs ok with no stalling after 20 minutes I would lean on the battery.
Re: Truck just quits running at a stop [Re: NITROUSN] #2958477
08/28/21 09:31 PM
08/28/21 09:31 PM
340SIX Offline OP
340SIX  Offline OP
Thanks, I will ask her. It will sit a week before she goes to start it again on the norm. She is presently hiding out at someone else's home to ride the hurricane out.
Re: Truck just quits running at a stop [Re: 340SIX] #2958486
08/28/21 09:45 PM
08/28/21 09:45 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Bad battery on the cold crank will dip the voltage to low and the computer will want a total relearn which results in a needed run cycle before the computer is happy,
Re: Truck just quits running at a stop [Re: NITROUSN] #2958571
08/29/21 07:40 AM
08/29/21 07:40 AM
USA
Suregrip391 Online content
Suregrip391  Online Content
USA
Agreed, battery……had the same issue on my 98 318.
Re: Truck just quits running at a stop [Re: 340SIX] #2958573
08/29/21 07:42 AM
08/29/21 07:42 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
If the pintle of the EGR valve is corroded away
so that some exhaust gas keeps flowing when it should not,
the 1992-1995 Magnum V8 engine will stall at stops, then restart.
Re: Truck just quits running at a stop [Re: 360view] #2958583
08/29/21 08:41 AM
08/29/21 08:41 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
That's an LA motor not a magnum, The idle motors wear out and start to fail. If you can still keep it running with your foot on the gas that's the problem. I had 90 that had 60k on the clock when i got it, Had over 200 when i sold it. No major issues other than the trans that had to be rebuilt.
Re: Truck just quits running at a stop [Re: Moparite] #2958591
08/29/21 09:17 AM
08/29/21 09:17 AM
USA
USA
Had the same issue with my 98, I drove it to work trying to keep the idle up by putting my foot on the gas even when braking, was not fun…. Changed the battery and all was good. Let us know how it turns out…..
Re: Truck just quits running at a stop [Re: 340SIX] #2958593
08/29/21 09:24 AM
08/29/21 09:24 AM
IMGTX Offline
IMGTX  Offline
I know the magnums had a problem with the pan on the bottom of the intake leaking causing vacuum leaks and oil issues.
It could be causing a lean condition. Open the throttle blades and look into the bores with a flashlight. If there is excessive oil on the floor of the intake it may need a new pan gasket.
I prefer to replace the factory sheet metal pan with 1/4" thick aluminum plate. I can buy it apiece of aluminum and use the original plate as a template to drill the holes. Best of all, it won't leak.
Several companies sell the prefab plate but it costs more than if I make it myself and it only takes about 20 minutes.
Re: Truck just quits running at a stop [Re: IMGTX] #2958596
08/29/21 09:28 AM
08/29/21 09:28 AM
delhi,il
trw1982 Offline
trw1982  Offline
delhi,il
if it is a 92/93 it is a magnum, if it is a 5.2. 92 5.9 was la. 93 5.9 was magnum. 91 5.2/5.9 was la.
Re: Truck just quits running at a stop [Re: trw1982] #2958635
08/29/21 11:29 AM
08/29/21 11:29 AM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
IAC Valve
Re: Truck just quits running at a stop [Re: 360view] #2958809
08/29/21 07:54 PM
08/29/21 07:54 PM
West Palm Beach, Florida
Copper Dart Offline
Copper Dart  Offline
This make so much more sense than a bad battery. If the battery was bad, how come it starts fine and restarts just fine after stalling guys? Bad battery would need a jump right?
Just sayn'
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: Truck just quits running at a stop [Re: pushbutton] #2958892
08/30/21 12:16 AM
08/30/21 12:16 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Originally Posted by pushbutton
IAC Valve
This one. You may get by with just pulling it out and cleaning it (and the passage in the throttle body) with carb cleaner, if the stalling continues, replace the IAC valve. The one I just purchased for my 94 (92-96 all the same) was 40 something dollars.
Re: Truck just quits running at a stop [Re: Copper Dart] #2958999
08/30/21 12:25 PM
08/30/21 12:25 PM
moparx Offline
moparx  Offline
Just sayn'
my one minivan would start fine, but would stall after pulling out of the driveway, then start fine again. sometimes it would light the check engine light, sometimes not. when scanned, the trouble codes were always goofy things that had nothing to do with driveability. that battery always started that thing, but it was 7-8yrs old. just for the heck of it, i bought a new battery, put the new battery in the wife's car, and put her 4yr old battery in the "bus". no more stalling, no more check engine lights, nothing goofy thereafter.
the battery obviously was the culprit.
beer
Re: Truck just quits running at a stop [Re: Copper Dart] #2959035
08/30/21 02:15 PM
08/30/21 02:15 PM
USA
3
360view Offline
360view  Offline
3
USA
Just sayn'
I also agree that a bad battery can make Magnum V8 OBD-I systems act “weird” yet the bad battery will start the engine.
Re: Truck just quits running at a stop [Re: 340SIX] #2959041
08/30/21 02:30 PM
08/30/21 02:30 PM
Maine
jerseybud Offline
jerseybud  Offline
Maine
Best to check for codes and fuel pressure. I was going to guess crank position sensor for suddenly dying based on my experience with my trucks. Buts I'm guessing. Would expect a intermittent code 11- not always. Mine used to need 30 seconds and then would start again. Sometimes.
Re: Truck just quits running at a stop [Re: 360view] #2959299
08/31/21 06:37 AM
08/31/21 06:37 AM
USA
3
360view Offline
360view  Offline
3
USA
If the “sock filter” has become clogged at the bottom of the fuel pump assembly submerged in the gasoline tank,
the vehicle will run fine for a length of time,
then suddenly die when the fuel pump suction above the sock filter “cavitates” which makes fuel pressure and volume pumped fall quite suddenly to zero.
After a few minutes of cooling down, typically 10 to 30 minutes, the fuel pump will be able to run again without cavitation for 1 to 4 hours.
This is more likely to happen in hot weather,
but also with varying gasoline chemistry.
Re: Truck just quits running at a stop [Re: Copper Dart] #2959305
08/31/21 07:39 AM
08/31/21 07:39 AM
Between Houston & Galveston TX
SattyNoCar Online work
SattyNoCar  Online Work
Just sayn'
Not necessarily. Late '90's, early 2000's I worked at a Used Car lot. With the Dodge trucks, people would be in and out of them all day, playing with the accessories, starting them, but not running them long enough to charge, and eventually the battery would be low enough that it would still start just fine, but it would stall as soon as put into gear. Charging the battery or swapping in a fresh battery fixed it every time.
popcorn
John
Re: Truck just quits running at a stop [Re: 360view] #2959672
08/31/21 08:21 PM
08/31/21 08:21 PM
340SIX Offline OP
340SIX  Offline OP
Just sayn'
In this case starts right back up and runs fine right away.
But mat stop running when truck stops. If so starts right back up.
It will stay in the garage as her,aera was hit very, very hard by Hurracane Ida.
Thanks for the imput.
