Original Chrysler starters: was there a difference
#2958323
08/28/21 01:18 PM
08/28/21 01:18 PM
Posts: 5,797 minnarusta
TX9H6E4CUDA
minnarusta
Good afternoon everyone So in my 70 Cuda (383, 4 speed) I have a mini starter in it currently. I am kind of getting nostalgic for the "laughing dolphin" sound of the original Chrysler starter. I'm thinking of putting one back in.
My question is were all original starters the same across the board or were there heavy duty ones? Did industrial or heavy duty applications get a higher torque starter?
Thank you for an help
For the absolute best powder coating go to J.I.T powder coating, contact infomation is in my personal profile..
Re: Original Chrysler starters: was there a difference
[Re: TX9H6E4CUDA]
#2958334
08/28/21 02:03 PM
08/28/21 02:03 PM
Posts: 25,967 Rio Linda, CA
John_Kunkel
Rio Linda, CA
There was a HD version, IIRC the armature and main housing were longer.
[Re: John_Kunkel]
#2958457
08/28/21 08:43 PM
08/28/21 08:43 PM
Posts: 1,411 Central Pa
moparjim79
Central Pa
There was a HD version, IIRC the armature and main housing were longer. This. Side by side the difference will be obvious if you have the two in front of you. Now that I think of it, at some poin t in time I possessed 3 sizes of varying case lengths......
[Re: TX9H6E4CUDA]
#2958520
08/29/21 12:02 AM
08/29/21 12:02 AM
Posts: 8,405 Highland, MI.
Sunroofcuda
Highland, MI.
My old 71 Hemi Charger used to require a starter replacement each summer - probably from the heat. I was getting them from a rebuilder near home - I think he charged me $15.00 for them back in the early 80's. Once I tried a HD version - did not last as long as a standard one! The started also was "protected" by a factory heat shield, which made the starter installation a LOT more difficult. About the third time I did the job, I discarded the OE heat shield. Looking back now, that was probably not a smart thing to do. Does anybody even reproduce them?
[Re: TX9H6E4CUDA]
#2958538
08/29/21 12:59 AM
08/29/21 12:59 AM
Posts: 1,908 Nebraska
4406bbl
Nebraska
To get the original starter sound you need the short case with a shunt coil in it. The original pre electronic ignition starters had 3 pulling coils and one shunt coil in the black part of the case, the shunt coil slows the starter down, and along with the gear reduction gives that sound. Here is the catch, they do not start high compresion engines as well or last as long. The later short starters with 4 pulling coils sound almost the same and start way better, most remans that have the bolt in solenoid will all have 4 pulling coils. The later long starter has 4 pulling coils and has less of a gear reduction so the engine turns over way faster, still sounds like a mopar, just different. The short has almost the same power output as the long, just at a lower rpm. Some of the remans back in the day were really bad, the new stuff tends to have all new coils and solenoid and last pretty good, I do my own but for what a reman costs it is worth it to buy just for all the new parts and use my date coded case.
[Re: 4406bbl]
#2958650
08/29/21 11:54 AM
08/29/21 11:54 AM
Posts: 669 Los Osos, Ca
CKessel
Los Osos, Ca
If my memory is correct, 3250 is the regular unit and 3258 is the HD one. These are parts store rebuilt numbers. The HD unit was used on the FMJ Cop Cars.
Carl Kessel
[Re: moparx]
#2959990
09/01/21 04:48 PM
09/01/21 04:48 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
I have a high torque with a '78 date code and my original '64 starter. Hope this pic works
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
