What valve retainer #2958242
08/28/21 10:39 AM
08/28/21 10:39 AM
Texas
dannysbee Offline OP
Texas
My friend is rebuilding his 360 magnum in his 2001 ram. He bought new heads and a mild cam from Hughs. It is supposed to use the Hughs retainer HUG 1278. Hughs is out of them and doesnt know when they will have any. Does anyone know of a replacement he could use?
http://www.hughesengines.com/Upload/Misc_Parts/HUG1278dims.jpg
Getting old just means you were smarter than some and luckier than others.
Re: What valve retainer [Re: dannysbee] #2958278
08/28/21 11:33 AM
08/28/21 11:33 AM
St.Pete,Florida
lancer493 Offline
lancer493  Offline
St.Pete,Florida
Isky cams has a great selection of valvetrain parts with many retainer options. Very helpful people, but you will need all your demensions and specs. Many steel or lightweight steel options as well. Bill
Re: What valve retainer [Re: dannysbee] #2958373
08/28/21 04:06 PM
08/28/21 04:06 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Why not ask Hughes ... they should understand if they're out of them !!
Re: What valve retainer [Re: Stanton] #2958502
08/28/21 10:45 PM
08/28/21 10:45 PM
Texas
Texas
Hughes has been no help. Took the order without anything in stock and then
Shipped the rest of the parts without the retainers. Now they say looks like October.
Re: What valve retainer [Re: dannysbee] #2958585
08/29/21 08:48 AM
08/29/21 08:48 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Finding a retainer shouldn't be hard. You know all the specs on the springs and the valve stem diameter, just go through a Comp Cams catalog and find the ones you need. Piece of cake.
Re: What valve retainer [Re: Stanton] #2958678
08/29/21 01:17 PM
08/29/21 01:17 PM
iagree scope wrench up
I would look for a tool steel set myself up
Re: What valve retainer [Re: dannysbee] #2958720
08/29/21 03:26 PM
08/29/21 03:26 PM
B.C. Canada
hankcrank Offline
hankcrank  Offline
B.C. Canada
The problem is a stock magnum head will have 8mm dia.valve stems so the keepers will have to match the retainers. I went through this a while back and wished I had not used a magnum head. Huges was the only place at that time that had a complete HP spring kit that dropped right in with no machining of the heads.Even Mopar did not have a "drop"in HP valve spring for the Magnum head.
Re: What valve retainer [Re: hankcrank] #2958765
08/29/21 06:24 PM
08/29/21 06:24 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
What's the big deal, 8mm is 5/16" !!!
Re: What valve retainer [Re: Stanton] #2958772
08/29/21 06:39 PM
08/29/21 06:39 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The spring's specific outside diameter is machined into the cylinder head to create the valve's spring seat. This is usually prevalent in two closely related engines: the 1967-92/93 A-engine (small block) and the 1992/93-2003 Magnum (small block). The A-engine springs have a 1.50″ OD while the Magnum uses 1.42″ OD.
In my brief search I could only find retainers with 10 degree locks for that size spring and stem.
Re: What valve retainer [Re: Stanton] #2959026
08/30/21 01:40 PM
08/30/21 01:40 PM
moparx Offline
moparx  Offline
well, sorta.
5/16" = .3125
8mm = .315
now with that said, i have no idea how .0025 larger diameter retainers would fit the 5/16" valve stem tolerance wise. or the other way around. plus, how the retainers would fit the spring retainers being used.
it "could" work, or "not" work, caused by however the retainer grooves were cut in the stem, and how the holes were machined in the spring retainers.
without knowing the +/- tolerance on the valve stem grooves and the same on each type of retainer, i would not recommend interchanging the two types.
that is just my 45+yr machinist career talking, and NOT any experience interchanging 5/16" and 8mm valves and retainers.
also, i'm not bashing any engine builders, as they have WAY more experience than i do !
beer
Re: What valve retainer [Re: moparx] #2959097
08/30/21 05:40 PM
08/30/21 05:40 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
If the valves have the OE style keeper groove, in the factory location, you’re going to find there are very few retainer and lock options that will work.
Re: What valve retainer [Re: moparx] #2959125
08/30/21 06:43 PM
08/30/21 06:43 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
I know its a technicality BUT ... we're talking valve "locks" - not "retainers".
And since you point out the difference I'm guessing the 5/16 locks won't fit an 8mm stem
Re: What valve retainer [Re: Stanton] #2959127
08/30/21 06:46 PM
08/30/21 06:46 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Try these guys. I don't think their chit comes from offshore.
Re: What valve retainer [Re: Stanton] #2959169
08/30/21 08:27 PM
08/30/21 08:27 PM
St.Pete,Florida
lancer493 Offline
lancer493  Offline
St.Pete,Florida
Dannysbee, you have a PM
Re: What valve retainer [Re: Stanton] #2959872
09/01/21 12:06 PM
09/01/21 12:06 PM
moparx Offline
moparx  Offline
Quote
i got the terminology wrong, but i was describing the "locks" [the two little pieces that surround the valve stem]. could these be also called "keepers" in some parts ?
"retainers" would be the round item on the top of the valve spring that the "locks" fit into, thereby "keeping" the valve and spring assembly together in the head, correct ?
sorry if i screwed up the nomenclature. it was not my intent, and i'm glad i was corrected. thanks ! up
beer
