Re: Dyno Dissappointment
[Re: 70VERT]
#2958005
08/27/21 01:48 PM
08/27/21 01:48 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Without knowing the exact cam specs I don't think the results are far off from what the combo should make, it's probably closer to 375 at the flywheel, some fine tuning may net a small handful of HP but not a ton. The next thing I would upgrade would be some bigger valves and decent amount of porting in the heads (or sidewinder or edelbrocks) and at least a performer RPM intake as the regular performer is barely any better than stock. Heads or intake upgrade alone would not net much as the other would still be the choke point, doing both together should wake it up.
[Re: 70VERT]
#2958006
08/27/21 01:51 PM
08/27/21 01:51 PM
Posts: 43,127 Bend,OR USA
Cab_Burge
What RPM did it make peak HP and peak torque? What was the weather that day?
[Re: 70VERT]
#2958007
08/27/21 01:51 PM
08/27/21 01:51 PM
Posts: 9,099 Rogue River, OR
Jeremiah
Rogue River, OR
I've had a blast restoring my 70 Challenger Vert. Originally a 318/727 car I cloned it into a 440 RT/ 4 speed. Started with a 440 Truck engine out of a motor home, kept the cast crank, bored 15 thou over. had the heads totally rebuilt and taken down 50 thou, steel head gaskets, edelbrock performer intake, Hedman Headers. MSD dist, single wire Powermaster alt and Blaster coil. Just had it Dynoed at 304 HP at the wheels. Really disappointed ----- Thoughts?????. I know I can spend big bucks from here, but I was expected more at this point I have a similar 451 with 906's, performer, and stock big block a body exhaust manifolds. It makes right at 300hp to the wheels on a chassis dyno as it is driven off the street, heat soaked and all. Uncorking the 2.25" repro exhaust is work 20rwhp. If you have a smaller cam (xe294h w/ 1.6's here) and headers compare to my manifolds I'd guess you might find 15-25 tops at the wheels. What RPM did you pull it to? The 451 in my dart made a hair under 500hp/500tq on a realistic engine dyno with a Performer RPM and 1-7/8" dyno headers. I figured the manifolds -50hp, intake -15, full exhaust -25hp, factory magnum air cleaner -10hp and don't forget the accessory drives for a very believable 100hp loss at the flywheel. That leaves us with 400hp going into the clutch. 400x.80=320rwhp on a perfect day. Take a car driven in off the street (heat soaked) on an 85 deg. day and 300ish at the wheels isn't out of the ball park.
[Re: Jeremiah]
#2958015
08/27/21 02:50 PM
08/27/21 02:50 PM
Posts: 16,923 NC
440Jim
NC
I like Jeremiah's post. Realistic, although approximate, numbers for various parts & factors.
[Re: DusterKid]
#2958019
08/27/21 03:06 PM
08/27/21 03:06 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
...... Never understood building a 500+ HP for a street cruiser. I totally agree with your sentiment. 500 hp is not nearly enough! I find 650+ is approaching enough power, but I'm thinking 800hp is just about right. I'm limited due to running a stock 440 block, or I would have added a 150hp shot of N2O for use in second gear on up on my street/highway cruiser.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: 70VERT]
#2958022
08/27/21 03:25 PM
08/27/21 03:25 PM
Posts: 14,493 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The two things that stick out to me are: - no mention of any head porting or oversized valves - “Performer” manifold. If it’s the std Performer, not the Performer RPM there is some potential power left on the table there........ especially if the heads get reworked. If the motor has stock heads with no porting and the std Performer, I can see where you’d have an under 400hp(at the crank) combo.
I find chassis dyno results can have an even bigger swing from facility to facility than engine dynos(and different engine dyno results can vary quite a bit). So, without having something to compare to off that dyno...... your 304rwhp is just an arbitrary number to me. Maybe the dyno service could give you some numbers from bone stock modern muscle to use as a comparison.
A pretty basic pump gas 440 with say...... 9.5cr, a mid-sized hyd cam, some mild head work to factory heads, headers, intake, carb, etc will be in the 425-450hp range at the crank.
[Re: 70VERT]
#2958074
08/27/21 07:00 PM
08/27/21 07:00 PM
Cab_Burge
All chassis dyno give you the net reading (true HP to the rear wheels), not the gross reading like the factory uses on there adds to the flywheel. My last pump gas street car had a 517 C.I. 400 block stroker motor that made 612 HP at 5500 RPM and 644 Ft. Lbs. torque at 4500 RPM with a set of ported 906 heads with big valves with 9.25 to 1 compression ratio and big solid lifter roller cam on a DTS brand engine dyno with a low deck six pack set up tune to the max, that motor made right at 500 HP net at 5000 RPM peak with a 10 inch custom converter on a local chassis dyno, that is 19.4 % loss with 4.10 gears in the rear end On your deal you may have more power in the engine that is not getting to the rear wheels because it is running out of fuel above 5000 RPM, been there done that If I was you I would make sure that the motor is not going lean above 4500 RPM at wide open throttle in high gear, look at buying and using a good wide ban O2 exhaust system so you can see real time air fuel ration while driving
[Re: 70VERT]
#2958093
08/27/21 07:57 PM
08/27/21 07:57 PM
Posts: 12,036 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Late model motor home heads are a real cork with any cam at all. Lots of good suggestions above.
I only have one question; how far down in the hole are the pistons? Of better yet, what is your cranking compression?
Master, again and still
[Re: Cab_Burge]
#2958110
08/27/21 08:51 PM
08/27/21 08:51 PM
Posts: 8,163 Plymouth, MI
Blusmbl
Plymouth, MI
All chassis dyno give you the net reading (true HP to the rear wheels), not the gross reading like the factory uses on there adds to the flywheel. Sorta. Gross and net refer to the test conditions when they were originally rated- net is still a flywheel number, but it includes things like the alternator, the water pump, the fan, the full exhaust system with representative backpressure, etc.. The gross ratings were not realistic. Both of them will still be higher than the rear wheel horsepower number. Depending on manual vs. auto, or the type of converter, you could see losses in the vehicle anywhere from 12% to 22+%, below the net rating. Dynos also have 2 correction factors - SAE and standard. SAE is also more representative of real world conditions. STD corrects to completely dry, 60* air, with a density altitude of near 0, so the STD number will always be higher than the SAE. SAE corrects to 77* air, a little lower barometer, and more reasonable humidity (it's closer to 2000' density altitude). This applies to both engine dynos and chassis dynos.
[Re: DaveRS23]
#2958154
08/28/21 12:14 AM
08/28/21 12:14 AM
Posts: 2,070 CA
crackedback
CA
Missed the motor home part, saw truck engine. DOH!!!!
[Re: crackedback]
#2958167
08/28/21 01:19 AM
08/28/21 01:19 AM
Posts: 4,848 Memphis
HemiRick
Memphis
pair of Edelbrock heads would wake this engine up I bet !
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#2958171
08/28/21 01:40 AM
08/28/21 01:40 AM
Posts: 707 California
BigDaddy440
California
Without knowing your cam specs, I think 300ish RWHP is about right, that's about 380hp. 440's especially with stock heads are just not big HP makers. They don't make good dynamic compression (comparatively to other rod stroke combos) and the factory heads can't breathe.
I had a strong running 440 (.030 over) with flat tops, a Hughes solid flat tappet cam and Edelbrock performer heads with 1 7/8" headers. The engine made 360 RWHP (or 450HP). I also was disappointed but the 3700lb B body ran 11.90s @ 115mph.
Bottom line: 440s make a ton of torque and that's why they were feared on the street, they got things moving in a hurry.
1969 A12 Roadrunner 1970 Plymouth Cuda 1968 Dodge Dart
